Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
130 registered members (14Accent, 2015_PSD, 86lxjunker, 01rangerxl, 17 invisible), 1,948 guests, and 57 spiders.
Topics286,163
Posts4,903,356
Members67,569
Most Online2,967
Mar 10th, 2019
Standardized Efficiency Testing for Air Filters #4681534
03/01/18 02:51 PM
03/01/18 02:51 PM
Illinois, U.S.A
RamFan Offline OP
RamFan  Offline OP
Illinois, U.S.A
I've not been able to find an answer to this, so if anyone has a source, please direct me there and we can just shut this thread down.
Finding an oil filters efficiency rating is rather easy as MOST manufacturers will post the ISO 4548-12 results. However, air filters don't seem to get the same treatment. I know that ISO 5011 exists, but I've not seen that actually cited on MANY air filters. A few examples of language can be found below. Does anyone have an answer as to why this hasn't been standardized like it has with oil filtration? Considering as how air filtration is far more important, it would seem like those numbers being readily available would be most beneficial to the consumer.
Fram EG - "2x engine protection"
Fram TG - "Traps double the dirt"
PureOne - "Traps upto 99% of damaging debris" (Based on ISO 5011 for A24278, no micron rating given)
STP - "Air filters are ISO 5011 tested to meet or exceed OEM fit and quality requirements"
18 Giulia Ti Sport Q4
+2.0l turbo - 8k - PP Euro LX 0w30 - Mopar - 10k/1yr
16.5 CX-5 Touring AWD
+2.5l - 54k - SynPower w/ Maxlife 0w20 - PureOne - 8k/1yr
Re: Standardized Efficiency Testing for Air Filters [Re: RamFan] #4681548
03/01/18 03:21 PM
03/01/18 03:21 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Originally Posted By: RamFan
... Finding an oil filters efficiency rating is rather easy as MOST manufacturers will post the ISO 4548-12 results. However, air filters don't seem to get the same treatment. ... Does anyone have an answer as to why this hasn't been standardized like it has with oil filtration? Considering as how air filtration is far more important, it would seem like those numbers being readily available would be most beneficial ...
Good question! I think they don't won't us to know. None of the vague advertising claims you quoted make a lick of sense, except possibly STP's.
2011 Toyota Prius now at 97K
Re: Standardized Efficiency Testing for Air Filters [Re: CR94] #4681561
03/01/18 03:36 PM
03/01/18 03:36 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
thumbsup
That correct they don't like posting the truth about their products. They need a little help it needs to be standardized and require the results printed on the products box.
2004 Corolla 129987
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Standardized Efficiency Testing for Air Filters [Re: RamFan] #4681716
03/01/18 07:39 PM
03/01/18 07:39 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
"Considering as how air filtration is far more important, it would seem like those numbers being readily available would be most beneficial to the consumer."
I think that might be a clue as to why they aren't.
Plus there's the cost of testing. Its conceivable that some manufacturers who aren't OEM suppliers don't actually know (or particularly care) how well the product works, since they get little back pressure from the consumer.
Re: Standardized Efficiency Testing for Air Filters [Re: RamFan] #4681721
03/01/18 07:43 PM
03/01/18 07:43 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
From K&N...
https://www.knfilters.com/faq.htm#5
5. What is the micron rating and efficiency of a K&N air filter?
Automotive air filters are not rated by micron size, they are rated by efficiency. K&N tests the filtering ability of our air filters using the ISO 5011 test procedure. In general, most K&N air filters will test between 97%-99% efficiency. Some air filters have their air filter test data published in the Available Information section of the product details page for that part number.
6. What are the air filtration requirements for my vehicle?
We are unaware of any vehicle manufacturer having published specific filtration requirements for any of their vehicles. As per the rights guaranteed under the Magnuson-Moss Warranty Act, consumers are free to use any brand of replacement part in their vehicle, without affecting the vehicle's warranty. Having specific filtration requirements would limit consumers' choices, and would not be viewed favorably by the Federal Trade Commission.
7. Some air filter companies tout their high filtration levels in the 99th percentile. Doesn't higher filtration mean a better air filter?
Not necessarily. 99% filtration efficiency is certainly a very good achievement. However, filter efficiency is just one statistic of filter performance which is measured (but is also the statistic most commonly published). The other air filter performance statistics measured are: capacity, restriction, and service life. These other factors reflect the amount of dirt the filter can hold, how easily air can flow through the filter, and how long the filter can be used before servicing. If one particular brand of filter consistently achieves 99%+ efficiency, it would be interesting to know if they also excel in the other performance areas, or are sacrificing one statistic to help increase another.
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
Re: Standardized Efficiency Testing for Air Filters [Re: RamFan] #4681772
03/01/18 08:44 PM
03/01/18 08:44 PM
Pocatello, Idaho
compratio10_5 Offline
Pocatello, Idaho
Perhaps air filter efficiency is not published because dry air filter efficiency is not constant. Initial efficiency with a new filter is the lowest and it improves as the filter is used, up to the design differential pressure. So if you change out your filter at 12000 miles or 1 year as many manufacturers recommend, then your realized efficiency is lower than if you run it out to the recommended DP. Any published efficiency number would have to specify whether is was initial, average or final and then the manufacturer would be liable to recommend a filter life that might reach the published efficiency number. Filter life without a "Filter Minder" gauge is tough to determine because ambient dust loading can vary by several orders of magnitude. I still do not understand why all vehicles are not equipped with "Filter Minders" from the factory but you can retrofit most vehicles with a gauge and it will save you money in filter changes and extend the life of your engine. A win-win situation.
It's not what you don't know that hurts, it's what you think you know that ain't so. Will Rogers
Re: Standardized Efficiency Testing for Air Filters [Re: RamFan] #4681775
03/01/18 08:48 PM
03/01/18 08:48 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Originally Posted By: wemay
From K&N...
Indeed it is interesting.
As a defence, though, (sounds defensive to me, anyway) its weakened a bit by the (only?) available comparative study using ISO 5011, which shows the KnN filter tested to be worst or 2nd worst on ALL these parameters except maximum flow rate, which was in excess of anything likely to be needed or useable.
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
Re: Standardized Efficiency Testing for Air Filters [Re: compratio10_5] #4681818
03/01/18 09:31 PM
03/01/18 09:31 PM
Illinois, U.S.A
RamFan Offline OP
RamFan  Offline OP
Illinois, U.S.A
I understand what you're saying, but that's the point of ISO 5011. It addresses, among other things, the efficiency rating of air filters. This rating would be valuable to know.
Re: Standardized Efficiency Testing for Air Filters [Re: RamFan] #4681826
03/01/18 09:50 PM
03/01/18 09:50 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
...and even in that nicoclub study, K&N finished with 96.8% efficiency. The graph bars make it look much worse than the actual numbers.
M1HM 10W30, OEM
PPeL 5W30, OEM
Re: Standardized Efficiency Testing for Air Filters [Re: wemay] #4681835
03/01/18 10:19 PM
03/01/18 10:19 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
IIRC, the Donaldson PowerCore is 99.98% or something insane. So while I wouldn't necessarily describe the 96.8% as "awful", there are significantly better filters available, many (most?) of them which primarily focus on big breathers like Diesels.
2016 Grand Cherokee SRT - Castrol Edge 0w-40, FRAM Ultra
Re: Standardized Efficiency Testing for Air Filters [Re: wemay] #4681852
03/01/18 10:55 PM
03/01/18 10:55 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
I don't think so. They're tricking you into looking at the significant numbers backwards. 3.2% (=100%-96.8%) of dust getting through is 3.2 times worse than (for example) 1% (=100%-99%) getting through. Even 1% would be too much, if it's ordinary silica dust. We need more detail on the test method.
Re: Standardized Efficiency Testing for Air Filters [Re: RamFan] #4681887
03/02/18 12:01 AM
03/02/18 12:01 AM
Pocatello, Idaho
Pocatello, Idaho
Yes, CR94 is right. You need to compare how much dust is passing through the filter when making comparisons. Penetration = 1-efficiency so:
1-0.99= 0.01
1-0.98= 0.02 (twice the wear rate)
1-0.97= 0.03 (3 x the wear rate)
So small changes in efficiency can have a large effect on engine wear rate. I too would like to know more about filter performance but the manufacturers do not cooperate for us light duty folk. SAE paper #952557, "Total Filtration: The Influence of Filter Selection on Engine Wear, Emissions, and Performance" contains figure 7 which indicates that engine wear decreases by a factor of 10 from a new air filter to a well used air filter. This paper was written by Marty Barris of Donaldson Company pertaining to heavy duty (Diesel) engines but I believe that it applies to light duty engines as well.
Re: Standardized Efficiency Testing for Air Filters [Re: RamFan] #4681928
03/02/18 02:12 AM
03/02/18 02:12 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
As a layperson (99.9% of consumers are) 99% to 96.8% is a very small difference in the case of this filter. I'm not going to extrapolate and disect those numbers to glean anything more than that. I've seen other paper filters say less than 95% (current STP in my Santa Fe, for instance, says 90% efficiency). And I've seen K&N have higher than 96% too. As with many topics on BITOG, we'll just agree to cordially disagree. The K&N option will not ruin your vehicle and is a viable choice for many.
M1HM 10W30, OEM
PPeL 5W30, OEM
Re: Standardized Efficiency Testing for Air Filters [Re: wemay] #4681943
03/02/18 04:07 AM
03/02/18 04:07 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
For me, the K&N idea has somewhat outlived its usefulness. As I've posted before, I've used them in the past, and quite gladly. When air boxes were that junky and sitting above a carb, and filters had some pretty pathetic build quality, they were a viable option. When I had my Town Car with the new fangled (at the time) square filter box and those filters cost a pile of money, a K&N that could go for 100,000 km before being cleaned, and ten times that before being replaced, was a very attractive option.
Now, with the G37, and me being able to toss on two filters every couple years at $12 or so a piece, and some well built stuff, it's not so bad.
Plain, simple Garak.
Re: Standardized Efficiency Testing for Air Filters [Re: RamFan] #4681966
03/02/18 06:28 AM
03/02/18 06:28 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Completely understand, Garak. That point of view has it's merits. The air filter for my Sonata costs $20. I picked up the K&N for $65. To me, getting the K&N was worth it. But i know it isn't so for everyone.
M1HM 10W30, OEM
PPeL 5W30, OEM
