Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
91 registered members (5azzmonkey, 2K2AcuraTL, 1WildPig, -SyN-, 11 invisible), 2,168 guests, and 35 spiders.
Topics295,224
Posts4,930,428
Members66,716
Most Online2,553
Oct 27th, 2018
Zinc and Phosphorus Levels in UOAs #4681392
03/01/18 10:08 AM
03/01/18 10:08 AM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Hello all,
In looking at my past oil analysis results, I was curious about Zinc and Phosphorus levels. See link for UOA below.
https://www.bobistheoilguy.com/forums/ub...owe#Post4355305
My UOA with Valvoline 5w-40 (CJ-4) showed Zinc at 1,340 and Phosphorus at 1,065
My UOA with Delvac 5w-40 (CJ-4) showed Zinc at 977 and Phosphorus at 878.
Both are CJ-4 so why did Delvac show lower numbers? Is Zinc and Phosphorus sacrificial? My Delvac 5w-40 is from 2016 so I doubt they bottled CK-4 in it. Wear numbers are good with Delvac especially since I towed vs not towed on Valvoline. What do you all think?
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: Zinc and Phosphorus Levels in UOAs [Re: mbacfp] #4681415
03/01/18 10:50 AM
03/01/18 10:50 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Has delvac both SN & CJ-4 certificates? If so...that is your answer for why lower ZDDP levels...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Zinc and Phosphorus Levels in UOAs [Re: mbacfp] #4681420
03/01/18 10:58 AM
03/01/18 10:58 AM
California
mbacfp Offline OP
mbacfp  Offline OP
California
I checked the current CK-4 spec sheet and both have SN. Found both CJ-4 spec sheets and both don't meet SN. Thanks for the idea.
Re: Zinc and Phosphorus Levels in UOAs [Re: mbacfp] #4681434
03/01/18 11:11 AM
03/01/18 11:11 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Api Cy... HDEO
Api Sy + whatever... PCMO
Cheers1
Re: Zinc and Phosphorus Levels in UOAs [Re: Kamele0N] #4681619
03/01/18 04:15 PM
03/01/18 04:15 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
For API SN the Phos & Zinc levels are restricted for 30 & 20 grade oils and lower, but for 40 grades and higher there is no restriction.
I'm using Penrite 10W40 and it has 1200 ppm zinc and it's rated API SN.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Zinc and Phosphorus Levels in UOAs [Re: Kamele0N] #4681713
03/01/18 06:38 PM
03/01/18 06:38 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Here, it would be C first, then S, which allowed the phosphorus waiver for ILSAC grades at the time.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Zinc and Phosphorus Levels in UOAs [Re: mbacfp] #4683073
03/03/18 09:53 AM
03/03/18 09:53 AM
New York
jeff78 Offline
jeff78  Offline
New York
CJ-4 requires that phosphorous levels be between 600 and 1200 ppm, so the Rotella and Delvac are both in spec.
They're different to each other because they're different oils.
