Best recommendation for Honda 10w30 trans
by Pepsibottle1
06/25/18 01:55 PM
Mills Fleet Farm Roadrunner batteries - who makes?
by volk06
06/25/18 01:09 PM
Honda ATF DW1 bottle stamp decoding
by parshisa
06/25/18 12:03 PM
How to lower throttle sensitivity?
by NICAT
06/25/18 11:41 AM
That's some service! (New Central AC...)
by xBa380
06/25/18 11:13 AM
Valvoline 2 Cycle TC-W3 Marine Oil - 6qt - $20
by Jimzz
06/25/18 10:45 AM
Plumbing/Bldg Experts: Cause of Wet Slab?
by LoneRanger
06/25/18 10:13 AM
How to CONFIRM the Country of Manufacture
by Ed_Flecko
06/25/18 09:58 AM
Replacing trans oil seal
by redhat
06/25/18 09:50 AM
VW diesels sitting in huge lots waiting......
by ZZman
06/25/18 09:09 AM
DTD/DT Independence Day Promos
by Sayjac
06/25/18 08:39 AM
It's AMSOILŪ, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
87 registered (AndyB, 4WD, badtlc, 87sammy, aquariuscsm, 9050lx, 11 invisible), 1685 Guests and 34 Spiders online.
65319 Members
67 Forums
285971 Topics
#4680406 - 02/28/18 08:44 AM Maruyama 2 cycle oil
doolah02 Online   content
Loc: FL USA
I replaced my Stihl BG55 blower with the Maruyama BL32. Should I stick with
a Maruyama Blue Shield 2 cycle oil? The BL32 is a good blower and I would to
use the best 2 cycle oil.
#4680447 - 02/28/18 09:39 AM Re: Maruyama 2 cycle oil [Re: doolah02]
Rab6715 Offline
Loc: Midwest
Nice blower. I was thinking about purchasing one prior to buying my Husqvarna 525BX. The primary reason I chose the Husky was parts sourcing long term. I understand you comment about wanting to use the best 2 cycle oil:
I would ONLY use certified JASO-FD oil in any 2 cycle equipment. If not JASO-FD, I wouldn't use it. This might make the Amsoil guys mad, since their 2 cycle stuff is not JASO-FD certified.
The Maruyama blue shield is JASO-FD certified and is a synthetic blend. If your looking for Full Synthetic 2 cycle oil, with JASO-FD rating, you could use VP Racing 2 cycle oil. I've been using this for a while. KLOTZ and MOTUL also make 2 cycle full synthetic oil, with JASO-FD ratings, but its pricey and harder to find. There are a lot of semi-synthetic 2 cycle oils with JASO-FD ratings, like Echo power blend, husky, red armor. I don't like the Sthil 2 cycle full synthetic oil, because it only carries a JASO-FC rating. It might be D rated, now but wasn't last year.
Bottom line, all the semi and full synthetic JASO-FD oils I listed are good, probably won't tell the difference between them, but I would strongly encourage you to stick with a JASO-FD oil. You will probably "void" the warranty if you claim you didn't in a warranty situation.
I would love to hear a write up of the good/bad about your blower with some pics. Thanks.
#4680466 - 02/28/18 10:04 AM Re: Maruyama 2 cycle oil [Re: Rab6715]
krismoriah72 Offline
Loc: wv
I agree. I dont care what brand I use as long as its JASO-FD. THe Stihl HP ultra is now JASO FD.
For me it boils down to where I shop.
Walmart- VP
Home Depot- Echo
Lowes- Husvarna
From what i can tell the VP from Walmart is the bargain. Its in the Garden section..not in the oil aisle with the rest of the 2 cycle oil.
#4680469 - 02/28/18 10:12 AM Re: Maruyama 2 cycle oil [Re: krismoriah72]
Loc: wv
On the new JASO List http://www.jalos.or.jp/onfile/pdf/2T_EV_LIST.pdf
Line 317 lists MARUYAMA SMOKELESS 50DX as the only one with JASO FD.
#4680471 - 02/28/18 10:17 AM Re: Maruyama 2 cycle oil [Re: krismoriah72]
Rab6715 Offline
Loc: Midwest
Walmart- VP
Home Depot- Echo
Lowes- Husvarna
Agree. I usually pick up the VP from local Walmart for like $2 for 1 gallon 50:1 mix. Very cheap. I was going to try some MOTUL, but I can only get 1 quart volume on-line. It would take me 7 years to burn through that much 2 cycle mix. I feel better using fresh/sealed bottles.
#4680575 - 02/28/18 12:38 PM Re: Maruyama 2 cycle oil [Re: Rab6715]
Loc: wv
The VP 2 gallon mix is on clearance at both my local walmarts. $2/2 gallon. I bought 6 or 7..should last me a couple of years i hope.
#4680920 - 02/28/18 06:54 PM Re: Maruyama 2 cycle oil [Re: krismoriah72]
jakewells Offline
Loc: Cave City KY
Walmart- VP
Home Depot- Echo
Lowes- Husvarna
poulan synthetic is jaso FD rated now and at walmart.
1994 Ford F150 302 4R70
Chevron Delo SAE 30 CF/SL Fram XG8A
1978 Chevy Nova 250 I6 3 on the tree.
Rotella 10W40 Fram TG30
