Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
jmd, alexislaborda, tbann, LisaMC, chops
67556 Registered Users
122 registered members (53' Stude, AandPDan, 28oz, 928, 2015_PSD, 12 invisible), 2,226 guests, and 52 spiders.
Topics286,076
Posts4,902,082
Members67,556
Most Online2,967
Mar 10th, 2019
What causes alignment to go out of spec? #4680404
02/28/18 09:42 AM
02/28/18 09:42 AM
Canada
johnnyh55 Offline OP
Canada
I know that wheel alignment goes out of spec after bushings, tie-rods, ball joints and other suspension components wear out and they have more and more play in them but what I am wondering is what causes the alignment to change after hitting a pothole? If nothing is bent, the adjustement of the tie rod doesn't actually move after hitting the pot hole right? So if the tie rods stay locked to the previous position when the wheel alignment was fine, what causes it to change after hitting a pothole?
Re: What causes alignment to go out of spec? [Re: johnnyh55] #4680419
02/28/18 10:03 AM
02/28/18 10:03 AM
NY
demarpaint Offline
demarpaint  Offline
NY
If nothing is bent, broken, jarred loose, or knocked out of adjustment then nothing would change after hitting a pot hole. In other words in order for the alignment to go out, something in the front end has to change.
God Bless Our Troops
Re: What causes alignment to go out of spec? [Re: johnnyh55] #4680443
02/28/18 10:32 AM
02/28/18 10:32 AM
Indianapolis, IN
09_GXP Offline
09_GXP  Offline
Indianapolis, IN
Sometimes a bushing can be bound up after and alignment and when you hit the pot hole it gets knocked loose. This is more common on alignment settings at the far end of specs but can happen to any unit.
Alternatively, you can hit a pot hole hard enough that the bushing temporarily deforms and then becomes bound up. Bolts will also slip a bit with the high point loads from pot holes and other factors.
2017 Miata Global Cup Car #02 - Castol A3/B4 5w30 w/ OEM Fitler
2017 Miata RF - PP 0w20 w/ M1 Filter
2015 F-150 2.7L Ecoboost - PPPP 5w30 w/ MC
Re: What causes alignment to go out of spec? [Re: demarpaint] #4680444
02/28/18 10:35 AM
02/28/18 10:35 AM
Ohio
jjjxlr8 Offline
jjjxlr8  Offline
Ohio
...or the back end.
1993 Toyota MR2 Turbo
2008 Mazdaspeed3
2014 Toyota Highlander XLE
Re: What causes alignment to go out of spec? [Re: johnnyh55] #4680445
02/28/18 10:38 AM
02/28/18 10:38 AM
Ohio
jjjxlr8 Offline
jjjxlr8  Offline
Ohio
How would you know that "nothing is bent?" Slightly bent components are difficult to detect., except with alignment rigs. There can also be measurement errors caused by the tech setting up the equipment that could be causing the change.
2008 Mazdaspeed3
Re: What causes alignment to go out of spec? [Re: jjjxlr8] #4680454
02/28/18 10:49 AM
02/28/18 10:49 AM
Canada
Canada
Well if the tech at the alignment shop says the alignment is out so it needs to be aligned but he doesn't mention any components needing to be replaced, wouldn't that mean nothing is bent? Or that would mean something is bent but he can get it back to spec without changing whatever componnent that is bent? So the alignment will be in spec with a bent componenent.
Re: What causes alignment to go out of spec? [Re: johnnyh55] #4680490
02/28/18 11:37 AM
02/28/18 11:37 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
What about alignment cams used on control arms?
Re: What causes alignment to go out of spec? [Re: johnnyh55] #4680498
02/28/18 11:57 AM
02/28/18 11:57 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
We were on our honeymoon, 4yrs after getting married. "66 Bug. In Utah on I 80 we hit a dollop of asphalt about 3" high going 60. It bent something and knocked the toe out. Badly enough to see shreds of rubber when we stopped for gas. It was re-aligned by adjusting the tie rods. Between the 4 ends, there is wide range of adjustment.
Thick oil is better grin2
Re: What causes alignment to go out of spec? [Re: johnnyh55] #4680512
02/28/18 12:15 PM
02/28/18 12:15 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Just a new car "settling" in from welding stresses can go out. It can constantly pop in and out if it was not jigged right. Many mac struts don't have brake reaction rods so, you can slam on a brake and put the toe out of spec. The lower swing arm bushings can be very compliant. Garbage mac strut bolted to floppy sheet metal.
Ackermann steering geo is not great, IMO.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: What causes alignment to go out of spec? [Re: johnnyh55] #4680530
02/28/18 12:33 PM
02/28/18 12:33 PM
Tn.
CourierDriver Offline
Tn.
Those darn potholes in Michigan will do it,, or the railroad tracks..imho
Look into Forks Over Knives Official Plant-Based Group if you want to change your way of eating.
Re: What causes alignment to go out of spec? [Re: johnnyh55] #4680541
02/28/18 12:51 PM
02/28/18 12:51 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
If you hit a pothole and it knocks the alignment out something did get bent. Don't take much.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: What causes alignment to go out of spec? [Re: johnnyh55] #4680542
02/28/18 12:56 PM
02/28/18 12:56 PM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
On a Renault Megane, I had a shorter distance between front and rear wheels on one side of the vehicle. I donít know if it was a pothole or the rear-ended crash Iíve been involved in, but after changing 4 corners arms, it stayed the same. Bent body?
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealerís overfilled, 16000 Km
Re: What causes alignment to go out of spec? [Re: johnnyh55] #4680554
02/28/18 01:06 PM
02/28/18 01:06 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I've discovered that alignment issues suddenly occur after lending my cars out.
Re: What causes alignment to go out of spec? [Re: Cujet] #4680566
02/28/18 01:20 PM
02/28/18 01:20 PM
Utah, USA
28oz Online content
28oz  Online Content
Utah, USA
You too? eek
1990 Nissan 300zx VG30DE - PP Euro 0W-40
2004 Nissan Quest VQ35DE - PP Euro 0W-40
2003 Ford Excursion 7.3 PSD - Rotella T6 5W-40
2005 Ford Taurus 3.0 Vulcan - Havoline HM 5W-20
Re: What causes alignment to go out of spec? [Re: johnnyh55] #4680599
02/28/18 02:18 PM
02/28/18 02:18 PM
Ohio
jjjxlr8 Offline
jjjxlr8  Offline
Ohio
No, the tech won't be able to tell if some component is 'tweaked' slightly. Yes, it is possible to get the alignment back with slightly bent components. Yes, the alignment that is measured on the alignment rigs can be adjusted to be in spec with slightly bent components.
Sometimes new cars come with out of spec alignments. I've seen "non-adjustable" rear suspensions that are out of spec on a new vehicle. Camber bolts or other suspension kits are required to get them back in spec in those situations. Assuming that the car was built with non-bent components, it might have been just a stack up of tolerances during manufacturing or just a defect. It doesn't take much to change the alignment!
2008 Mazdaspeed3
