Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
105 registered members (1WildPig, 2012AccentSE, 2K2AcuraTL, 69Torino, 1leater, aircooled, 10 invisible), 2,130 guests, and 172 spiders.
Topics286,196
Posts4,903,998
Members67,576
Most Online2,967
Mar 10th, 2019
CLP-4 #4680298
02/28/18 07:53 AM
02/28/18 07:53 AM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
I recently placed an order on Amazon and threw this in my cart:
CLP-4
I was thinking that the next time I change the plugs in my Accord (which I plan to drive FOREVER), I'd give each cylinder an 1 ounce of this solvent and let it sit over night. My goal would be to do some cleaning/freeing up of the rings and ring lands. Obviously, I'd hope to prevent this car from becoming an oil burner somewhere down the line.
What do you think? Good idea? Bad idea?
Do you have a general procedure that you'd recommend? I was thinking I'd remove the plugs while the engine was cold and simply pour 1 oz. into each cylinder and let it sit over night. With the plugs out, and a towel over the spark plug holes, I'd crank the car over for a few seconds and let it set another few hours. Then re-install the plugs and drive as normal. That's what I had in mind....
I always keep a few cans quarts of Kreen around. Every year, the Accord get 1 pint in crankcase and a pint in the tank. I thought about using Kreen as a preventative soak, but I've so many great things about this CLP-4 solvent.
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: CLP-4 [Re: Phishin] #4680310
02/28/18 08:06 AM
02/28/18 08:06 AM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
If the rings are stuck due to carbon build-up, you would have better luck using Berryman B-12 Chemtool as an overnight soak. You would need to change the oil immediately afterwards and again shortly after that, but the carbon would be long gone.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: CLP-4 [Re: 2015_PSD] #4680338
02/28/18 08:30 AM
02/28/18 08:30 AM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
Nothing is stuck. I'm just looking to do a little PM to prevent such a thing from happening.
Re: CLP-4 [Re: Phishin] #4680391
02/28/18 09:25 AM
02/28/18 09:25 AM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
Doubt it will do much. I use that on my all my firearms and it works great but itís not magic. If you have baked on carbon it still requires scrubbing and/or a stronger solvent (Iím looking at you 11-87 gas piston). That said Iíd love to hear about your results. Are you looking to reduce oil consumption or blow by? Can you do a before and after bore scope?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: CLP-4 [Re: buck91] #4680472
02/28/18 11:18 AM
02/28/18 11:18 AM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
I don't really think there will be any "results"....right now, my car only burns maybe 1/3 of a quart in 8-9k miles. Virtually nothing. I'm not trying to "fix" anything. I'm only looking to maybe keep the rings in as good as condition as I can to prevent troubles down the road.
My friend has a bore scope. I might look at the piston tops next time I remove the plugs and see what it looks like in there.
Re: CLP-4 [Re: Phishin] #4680559
02/28/18 01:09 PM
02/28/18 01:09 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Sounds like a complete waste of $7 to me.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: CLP-4 [Re: Phishin] #4681190
03/01/18 04:14 AM
03/01/18 04:14 AM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
MMO should do the same thing you want to do with the clp-4, just cheaper.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: CLP-4 [Re: bubbatime] #4681554
03/01/18 03:27 PM
03/01/18 03:27 PM
Indiana
Phishin Offline OP
Phishin  Offline OP
Indiana
Hard to "completely waste" $7?
Re: CLP-4 [Re: Phishin] #4681556
03/01/18 03:31 PM
03/01/18 03:31 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
Why do you want to put Teflon in the combustion chamber?
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: CLP-4 [Re: UG_Passat] #4863674
09/08/18 06:59 PM
09/08/18 06:59 PM
Ga
Buzzsaw Offline
Buzzsaw  Offline
Ga
Breakrfee hasn't had PTFE in the formulation in a number of years.
Re: CLP-4 [Re: Phishin] #4864812
09/09/18 10:53 PM
09/09/18 10:53 PM
Holly Springs, NC USA
jim302 Offline
jim302  Offline
I'll use Breakfree CLP on my firearms for routine cleaning and lubrication as well as rust prevention... but if they are real dirty I'll do a two step process with a solvent then lubricant. It certainly wouldn't do anything for an engine that had serious buildup and I have my doubts that it would prevent any buildup either, since modern oils are pretty good about keeping engines clean in the first place. Sounds like a good test for that guy that runs the Project Farm channel on YouTube though.
I guess I might put some into the cylinders of an engine that had sat for a while to provide a little extra lubrication on startup but that's only because I have it around. I wouldn't buy it for this purpose though since there are other products designed for this purpose that probably would do a better job.
