STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
106 registered members (ARCOgraphite, Ag76, Altima2, AZjeff, acme, 2012AccentSE, 10 invisible), 1,965 guests, and 64 spiders.
Topics286,230
Posts4,904,734
Members67,582
Most Online2,967
Mar 10th, 2019
Recommended oil for a Cummins Onan 4000k generator #4680187
02/28/18 01:54 AM
02/28/18 01:54 AM
Roseville, CA
trod30 Offline OP
trod30  Offline OP
Roseville, CA
Amsoil small engine 10w40 or Shell Rotella T6 or whatever else you recommend. It sounds like some guys use diesel oil. I think it takes a quart or less so price is not an issue.
Re: Recommended oil for a Cummins Onan 4000k generator [Re: trod30] #4680200
02/28/18 02:50 AM
02/28/18 02:50 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Factory rec is 15w-40 diesel oil, but Amsoil small engine would be phenomenal for that engine due to its super low noack and it just being a great oil in the first place.
Re: Recommended oil for a Cummins Onan 4000k generator [Re: trod30] #4680203
02/28/18 03:20 AM
02/28/18 03:20 AM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
What kind of engine? What does the manual say?
Re: Recommended oil for a Cummins Onan 4000k generator [Re: trod30] #4680221
02/28/18 05:11 AM
02/28/18 05:11 AM
wi
dave123 Offline
dave123  Offline
wi
Amsoil be my first pick as always in the small stuff that formulation is strong.
Re: Recommended oil for a Cummins Onan 4000k generator [Re: trod30] #4680352
02/28/18 08:45 AM
02/28/18 08:45 AM
Texas (south)
FermeLaPorte Offline
Texas (south)
Chevron DELO would be a better fit since diesel oil is HDEO, AMsoil is boutique meaning just for show
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Recommended oil for a Cummins Onan 4000k generator [Re: trod30] #4680446
02/28/18 10:38 AM
02/28/18 10:38 AM
Virginia
mattwithcats Offline
Virginia
Shell Rotella T6, in 5W-40
If it has a filter, and you can squeeze it on, the Fram 3600 / Purolator 20195 / Wix 51516 is 5 inches long,
verses 3 and a half for the 3614...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Recommended oil for a Cummins Onan 4000k generator [Re: mattwithcats] #4680515
02/28/18 12:19 PM
02/28/18 12:19 PM
NM, USA
pkunk Offline
pkunk  Offline
NM, USA
This. Those little filters are h**l to get off. Most any 0-40 or 5-40 diesel oil is fine. The Onan runs hot especially those in a RV compartment.
8200 ft elevation in the Sangre de Cristos
2008 Mini Cooper Clubman (toad)
2000 Mercedes ML320
1994 Dodge 2500 Cummins
1999 Ford F53 V10 Coachman Motorhome 34ft
Re: Recommended oil for a Cummins Onan 4000k generator [Re: trod30] #4680555
02/28/18 01:06 PM
02/28/18 01:06 PM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
I ran M1 0w40 in my onan 4K "microquiet" as its pretty cheap and I always have a lot on hand.
Rotella will be fine if not great
No filter on that genset - splash only lubrication.
It does have a nice altitude adjustment on the carb.
It drinks like a sailor consuming about 1/3 GPH at a constant 3600 RPM even idling.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Recommended oil for a Cummins Onan 4000k generator [Re: UncleDave] #4680568
02/28/18 01:25 PM
02/28/18 01:25 PM
NM, USA
pkunk Offline
pkunk  Offline
NM, USA
UD
Mine is the 5500, has a filter and runs at 1800 rpm. Much more effecient and quieter
2000 Mercedes ML320
Re: Recommended oil for a Cummins Onan 4000k generator [Re: FermeLaPorte] #4680922
02/28/18 07:55 PM
02/28/18 07:55 PM
Duvall WA - Pacific NW USA
Pablo Offline
Pablo  Offline
Why do you think this?
Let's get a fix on exactly what this engine is, and I can recommend an Amsoil oil that is very stout and more suited to the exact generator application than a generic HDEO.
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: Recommended oil for a Cummins Onan 4000k generator [Re: Pablo] #4681081
02/28/18 11:07 PM
02/28/18 11:07 PM
Roseville, CA
trod30 Offline OP
trod30  Offline OP
Roseville, CA
Id love to hear your recommendation. I'm guessing your Small Engine oil?
Re: Recommended oil for a Cummins Onan 4000k generator [Re: trod30] #4681084
02/28/18 11:11 PM
02/28/18 11:11 PM
Pablo Offline
Pablo  Offline
I apologize if you wrote it, but exactly what engine?
Re: Recommended oil for a Cummins Onan 4000k generator [Re: pkunk] #4690329
03/10/18 10:02 AM
03/10/18 10:02 AM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
UD
You sure about that?
The 5500's Ive run are 2400 RPM units.
Quieter nicer and a big step up from that 4K for sure, but I didn't think it had an 1800 RPM head ??
UD
Uncle Dave
Re: Recommended oil for a Cummins Onan 4000k generator [Re: trod30] #4691492
03/11/18 01:15 PM
03/11/18 01:15 PM
Cave City KY
jakewells Offline
jakewells  Offline
Cave City KY
Schaeffer 9000 5W40.
1994 Ford F150 302 4R70
Chevron Delo SAE 30 CF/SL Fram XG8A
1978 Chevy Nova 250 I6 Borg Warner T5
Rotella 10W40 Fram XG5
Re: Recommended oil for a Cummins Onan 4000k generator [Re: trod30] #4697628
03/17/18 01:47 PM
03/17/18 01:47 PM
Michigan born but my heart bel...
JR Offline
JR  Offline
Any 15w-40, sae30 or 20w-50 will serve you well. It is all I use in onans.
I do not own your model, but I do one two.
The one is a 4.5kw the other a 5.5kw. both have quite a few thousand hot hard florida hours on them.
I only used sae40, 15w-40, or 20w-50. Ran "3600" filters and did 150hr drains.
harvey
97 F250HD 7.3 320K 01 Astro 220K
93 metroXFi 94.5K
01 Impala 300K
04 RTV900R 1150hrs
