Hail damage means newer vehicle time!
by ZZman
06/20/18 03:39 PM
Trouble with Grease Gun
by tc1446
06/20/18 02:30 PM
Toyota brand conventional (TGMO)
by Jaha24k
06/20/18 01:45 PM
Any synthetic oil rebates currently or soon?
by 07Piloteer
06/20/18 01:32 PM
2018 Hyundai elantra motor oil
by kapama
06/20/18 01:00 PM
SN Plus on shelves
by 03s
06/20/18 12:23 PM
Group 90 Battery - 45 vs 60aH rating
by The Critic
06/20/18 12:19 PM
Tire on Church 15 Passenger Van
by Gebo
06/20/18 11:58 AM
Battery Disconnect Switch?
by Pike51
06/20/18 11:35 AM
03 Maxima Cam sensor questions
by LeakySeals
06/20/18 11:09 AM
Wood Fairing?? Yes, and it's beautiful!
by webfors
06/20/18 11:08 AM
2006 Prius
by Kira
06/20/18 11:06 AM
Amsoil XL 5w30, 10K OCI, 2006 Expeditition
by meborder
06/20/18 10:18 AM
Mouse Visiting Car
by Ifixyawata
06/20/18 10:07 AM
Hit a shopping cart at 30mph
by LeakySeals
06/20/18 10:00 AM
Let's Talk Bed Pillows
by LoneRanger
06/20/18 09:21 AM
Changed Speedo Gear on 700r4 Tailshaft
by Pike51
06/20/18 09:20 AM
Which do you prefer: ZL-1 Camaro or GS Corvette ?
by Mr Nice
06/20/18 08:41 AM
CVT Discussion
by Sierra048
06/20/18 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Ilia, nmac9, Theraven, battleman13, Shassis
65278 Registered Users
82 registered (28oz, ARB1977, A310, ag_ghost, Aero540T, 1998CamryCE, 11 invisible), 1710 Guests and 25 Spiders online.
65277 Members
67 Forums
285656 Topics
Page 1 of 2 1 2 >
#4679897 - 02/27/18 06:19 PM 1997 Chevy cavalier 2.2 auto maintenance
97prizm Offline
Loc: USA
Hi all,
The Pontiac vibe I had was totalled and am now getting a 97 cavalier automatic. It's rough with 143,000 on the odometer. New oil and stp filter. I detest automatic transmissions but need a car so. Anything to look for on this vehicle? No drain plug on the radiator and I can't find the atf plug. Thanks. Hope to get some money saved as the sister didn't take care of it.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm
1984 Mazda RX-7 Spec 7
#4679902 - 02/27/18 06:22 PM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: 97prizm]
eljefino Offline
Loc: ME
Frame rust over the rear axle. I'd come up with more but "USA" is too general a location.
The 3t40 tranny in these is actually pretty good. Change its fluid and filter, adjust the TV cable, and you're mint. drive
#4679917 - 02/27/18 06:41 PM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: 97prizm]
HangFire Offline
Loc: Central Maryland
Rather solid little cars. EGR Valve tends to freeze up at high mileage/age, and you get a code. They're not cheap about $150-$200, but they are right on top and easy to replace.
Various musings: http://hangfire.net
#4679923 - 02/27/18 06:52 PM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: 97prizm]
clinebarger Offline
Loc: Fort Worth, Texas
Didn't some of those have a 4T40E?
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
#4679940 - 02/27/18 07:21 PM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: clinebarger]
FordBroncoVWJeta Offline
Loc: KS
Yes, 2001 it became standard.
17 Volkswagen Jetta 1.4T
15 Honda CRV 2.4
12 Volkswagen Jetta 2.0
01 Pontiac Sunfire 2.2
#4679943 - 02/27/18 07:26 PM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: 97prizm]
eyeofthetiger Offline
Loc: South Carolina
If it was mine, I'd take a chance and service the transmission. I might even unplug the TCC and fill it with Type F. But don't do that. popcorn2
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
#4680028 - 02/27/18 08:48 PM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: 97prizm]
slacktide_bitog Offline
Loc: USA
Unfortunately, Dorman does not make an aftermarket pan with a drain plug for the 3-speed auto.
Now, if you had the 4-speed auto 4T40E, then you could get a Dorman pan for it.
#4680076 - 02/27/18 09:31 PM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: 97prizm]
14Accent Offline
Loc: MN
Maintenance?! It's a 2.2 cavalier! As long as it isn't rotten underneath (check the subframe and steering rack mounts CLOSELY), then you're pretty much good to go. Either a 3t40 or 4t40 will be bulletproof (the 2200 doesn't make enough power to hurt a fly), and the 2200 is almost impossible to kill. Just change the major fluids and call it good.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
#4680092 - 02/27/18 09:48 PM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: 14Accent]
clinebarger Offline
If it is a 4T40E, The shift solenoids sit above the fluid level & can burn up causing the trans to miss 2 gears. This can make owners think the trans is bad when it just needs shift solenoids & a internal harness.
#4680136 - 02/27/18 11:04 PM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: 97prizm]
dishdude Online   content
Loc: Phoenix
These things run forever with about zero maintenance. Keep oil, coolant and ATF in it and there isn't much you can do to kill it. The weakness is if you get the engine remotely warm, you'll kill the headgasket. Even if you do that, it's a 2 hour job. Buy a 6 pack and start drinking when you start, you'll have 5 left over when you finish!
2018 Challenger SRT
#4680174 - 02/28/18 12:20 AM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: dishdude]
daves87rs Offline
Loc: Michigan
This!
Coming together is a beginning; keeping together is progress; working together is success.
Henry Ford
#4680255 - 02/28/18 05:56 AM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: daves87rs]
Silverado12 Online   content
Loc: Central Virginia
This!
Might have 5 left over if I started with a 12 pack lol.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
16 Challenger R/T Shaker 5.7 manual B5 blue
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
#4680261 - 02/28/18 06:03 AM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: 97prizm]
SteveSRT8 Offline
Loc: Sunny Florida
We had 3 different versions of these cars when my kids were young. Whether it's a Pontiac Sunturd or a Chevy Cavalier (Caval-ee-AY) it is an incredibly durable car. Parts can practically be found on the side of the road, driving dynamics are very poor, noises are unsophisticated.
But IME they run nearly forever and are very cheep to keep...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#4683503 - 03/03/18 06:48 PM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: 97prizm]
Nick R Offline
Loc: Albany, NY
Most of the people in this thread are right, but I don't miss mine. I had to put so much money and work into it in the one year I owned it I was glad to see it go. Late 90s GM nickle and diming at it's finest (worst?)
2013 Ford Focus SE 2.0L/100,000mi/Pennzoil Platinum 0W-20/Fram Extendedguard
#4684630 - 03/04/18 09:23 PM Re: 1997 Chevy cavalier 2.2 auto maintenance [Re: 97prizm]
artificialist Offline
Loc: Florida
Sometimes a rattling noise will be caused by a failing timing chain and chain hardware. Good thing this is an OHV engine, SOHC and DOHC engines usually require more labor time to do the job.
2010 Lancer Ralliart Sportback
Page 1 of 2 1 2 >
