Tire on Church 15 Passenger Van
by Gebo
06/20/18 11:58 AM
Battery Disconnect Switch?
by Pike51
06/20/18 11:35 AM
03 Maxima Cam sensor questions
by LeakySeals
06/20/18 11:09 AM
Wood Fairing?? Yes, and it's beautiful!
by webfors
06/20/18 11:08 AM
2006 Prius
by Kira
06/20/18 11:06 AM
Amsoil XL 5w30, 10K OCI, 2006 Expeditition
by meborder
06/20/18 10:18 AM
Mouse Visiting Car
by Ifixyawata
06/20/18 10:07 AM
Hit a shopping cart at 30mph
by LeakySeals
06/20/18 10:00 AM
Let's Talk Bed Pillows
by LoneRanger
06/20/18 09:21 AM
Changed Speedo Gear on 700r4 Tailshaft
by Pike51
06/20/18 09:20 AM
Which do you prefer: ZL-1 Camaro or GS Corvette ?
by Mr Nice
06/20/18 08:41 AM
CVT Discussion
by Sierra048
06/20/18 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Need mini grease gun
by Duffyjr
06/20/18 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
06/20/18 06:57 AM
Brake Bleeder
by supton
06/20/18 06:56 AM
As close to blowing out as you can get
by wwillson
06/20/18 06:04 AM
changing tranny filter
by Dennisistheman
06/20/18 06:04 AM
From small things...
by Silk
06/20/18 05:57 AM
Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
83 registered (AndyB, 03s, billt460, ARB1977, BillyTheKid, 13 invisible), 1640 Guests and 36 Spiders online.
65276 Members
67 Forums
285649 Topics
#4679693 - 02/27/18 01:23 PM Where Measure Engine Temp. with IR
doitmyself Offline
Loc: MI
4 cyl. Ford Engine on Kohler Standby Generator. VERY stout radiator/cooling fan system. My service tech. shot a few IR readings around the thermostat and got 130F +/- and said the unit is running low and needs a hotter thermostat. I shot the oil filter at 175F and the oil pan at 185F.
Where is the best place to take IR readings on an engine to determine and/or interpret if it is operating at the correct temperature?
Thanks
#4679700 - 02/27/18 01:30 PM Re: Where Measure Engine Temp. with IR [Re: doitmyself]
Snagglefoot Offline
Loc: Alberta
Certainly the oil pan and oil filter will be hotter than the coolant. I believe the service tech took the readings at the correct spot, that is at the thermostat. I'm not sure what Kohler suggests but if this was a car engine 175-195 F would be more appropriate and if was a modern GM V8 it would be 210 F.
#4679719 - 02/27/18 01:44 PM Re: Where Measure Engine Temp. with IR [Re: doitmyself]
CT8 Offline
Loc: Idaho
The oil filter will give you close to the oil temps in the oil filter. The oil pan will give you close to the oil temps in the oil pan. The radiator will give you close to the coolant temps in the radiator area where you shoot the temps and the T stat housing the temps of the coolant in that area. I would guess the t stat should be 160* f or higher. The tech is telling you the coolant temps are too low. Why measure the oil temps?
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4679721 - 02/27/18 01:48 PM Re: Where Measure Engine Temp. with IR [Re: doitmyself]
doitmyself Offline
Loc: MI
The thermostat housing sits on the engine front, perched up a bit, directly in front of the cooling fan. It gets bathed in cool air and I wonder how much effect that has on the IR reading. Ford VSG-413 engine:
Good pic here if my link doesn't work: https://www.manualslib.com/manual/805435/Ford-Vsg-411.html#product-VSG-413
#4679731 - 02/27/18 02:04 PM Re: Where Measure Engine Temp. with IR [Re: doitmyself]
69GTX Offline
Loc: Connecticut
From my use of an IR gun on super-heated steam boilers and combustion furnaces, the air temp has little to no bearing on metal surface temps. If I were doing it, I'd also want to know the highest temp on the engine block/heads.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4679744 - 02/27/18 02:18 PM Re: Where Measure Engine Temp. with IR [Re: doitmyself]
Chris142 Offline
Loc: Deplorable in apple valley, ca
Don't take the temp on shiney or unpainted surfaces
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4679759 - 02/27/18 02:38 PM Re: Where Measure Engine Temp. with IR [Re: Chris142]
GravelRoad Offline
Loc: Virginia
I doubt that a temp is spec using an IR gun anywhere on that generator. So no real answer can be given.
I assume it was under load and fully warmed-up before IR temp reading? Is the mechanic trying to say it has a bad T-Stat, low on coolant (air pocket), bad water pump or bad design? If he's using and IR gun, he should be able to tell you why it's running cool since he "knows" it's running cool.
Seems a water cooled generator should have a temp gauge. shrug
2016 Subaru Outback Premium. PUP 5w30 oem filter
2013 Hyundai Elantra loaded. lifetime free oil/filter change
#4679847 - 02/27/18 05:30 PM Re: Where Measure Engine Temp. with IR [Re: doitmyself]
Traction Offline
Loc: iowa
Probably not an accurate way to measure internal coolant temps, since IR is measuring the radiated surface temperature.
Tire Industry Association Certified Tire Service Instructor since 2009
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
12 Camry
81 Camaro
55 Chevy C4
#4679912 - 02/27/18 06:36 PM Re: Where Measure Engine Temp. with IR [Re: doitmyself]
ZeeOSix Offline
Loc: PNW
A thermocouple taped onto the surface with aluminum tape will give a better temperature reading. IR gun will most likely be low because it assumes a black body radiating surface.
