Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
90 registered members (BamaE92, ARCOgraphite, billt460, Bailes1992, andyd, 14 invisible), 1,752 guests, and 67 spiders.
Topics286,446
Posts4,908,449
Members67,626
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
Recommend an oil/weight for Lawn Tractor #4679555
02/27/18 11:11 AM
02/27/18 11:11 AM
San Antonio, Texas
sasilverbullet Offline OP
San Antonio, Texas
2014, 22 H.P. Briggs & Stratton V-twin, using a WIX oil filter running a 42" cutting deck.
High dust, high heat, six hours mowing at a time every 3 weeks or so.
What brand/weight of oil would you guys recommend?
Oh, and anyone know a link to the specs from Briggs & Stratton? I searched high and low and couldn't find any.
03 Porsche 911 Liqui Moly Leichtlauf High Tech 5w-40 & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 0W-20 & WIX XP
02 Chevy 5.7L van-GTX HM 10W-40 & WIX filter
Re: Recommend an oil/weight for Lawn Tractor [Re: sasilverbullet] #4679558
02/27/18 11:18 AM
02/27/18 11:18 AM
Canada
expat Offline
expat  Offline
Canada
Rotella or Delvac 15w-40
Re: Recommend an oil/weight for Lawn Tractor [Re: expat] #4679566
02/27/18 11:32 AM
02/27/18 11:32 AM
Virginia
GravelRoad Offline
GravelRoad  Offline
Virginia
Almost all our customers summer equipment get 30w API CH4/SJ above 40f. Except the engines that require 20w50.
2016 Subaru Outback Premium 2.5. PP 5w30 oem filter
2018 Hyundai Kona 1.6T. Lifetime dealer free oil/filter change
Re: Recommend an oil/weight for Lawn Tractor [Re: sasilverbullet] #4679571
02/27/18 11:38 AM
02/27/18 11:38 AM
Virginia
mattwithcats Offline
Virginia
Use a longer filter.
The OEM filter is around two inches long
A Fram 3614 (Wix 51348) is three and a half inches long, and holds four more ounces of oil...
A Fram 3600 (Wix 51516) is five, and holds eight more....
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Recommend an oil/weight for Lawn Tractor [Re: sasilverbullet] #4679577
02/27/18 11:40 AM
02/27/18 11:40 AM
maple ridge, bc
2004tdigls Offline
2004tdigls  Offline
maple ridge, bc
Re: Recommend an oil/weight for Lawn Tractor [Re: expat] #4679578
02/27/18 11:41 AM
02/27/18 11:41 AM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
X2, plus in a dusty setting I would be more concerned with the air filtration than the oil weight. Add a prefilter if it doesn't have one and clean often. These Briggs engines will run forever on most any oil.
Re: Recommend an oil/weight for Lawn Tractor [Re: sasilverbullet] #4679583
02/27/18 11:49 AM
02/27/18 11:49 AM
Virginia
Virginia
For oil, Shell Rotella T6, in 5W-40.
The new CK formula has less additives than the old CJ spec,
so I would put in 2-4 ounces (quarter to half cup) Mobil 1 Racing 0W-30.
This has double the normal levels of additives...
https://www.walmart.com/ip/Mobil-1-Racing-Synthetic-Motor-Oil-0W30-1-Quart/55502854
A cheaper alternative would be Rotella T5, in 10W-30,
but that should be changed at 50 hours,
verses yearly (100-200 hours) for the T6...
2009 Smart Pure
Re: Recommend an oil/weight for Lawn Tractor [Re: 2004tdigls] #4679605
02/27/18 12:10 PM
02/27/18 12:10 PM
San Antonio, Texas
San Antonio, Texas
Just ordered a six pack of the Castrol HD40, and I'll use the Wix 51516 for more capacity.
Thanks for the help everyone!
Oh, link to Brigss & Stratton specs? Anyone?
Re: Recommend an oil/weight for Lawn Tractor [Re: sasilverbullet] #4679606
02/27/18 12:10 PM
02/27/18 12:10 PM
N.H, U.S.A.
ARCOgraphite Online content
ARCOgraphite  Online Content
N.H, U.S.A.
I think when I hit 60 year old I stopped worrying as much.
Mercury Marine 4stroke 25w-40
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Recommend an oil/weight for Lawn Tractor [Re: sasilverbullet] #4679638
02/27/18 12:46 PM
02/27/18 12:46 PM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Recommend an oil/weight for Lawn Tractor [Re: sasilverbullet] #4679649
02/27/18 01:00 PM
02/27/18 01:00 PM
NJ
JLawrence08648 Offline
NJ
30 wt
Re: Recommend an oil/weight for Lawn Tractor [Re: sasilverbullet] #4679656
02/27/18 01:10 PM
02/27/18 01:10 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
I run RT6 5W40 because that's what I have around, but I would run 15W40 if I had that too.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Recommend an oil/weight for Lawn Tractor [Re: ARCOgraphite] #4679657
02/27/18 01:12 PM
02/27/18 01:12 PM
Canada
boraticus Offline
boraticus  Offline
Canada
Ain't that the truth!
At that age, just about any new machines will likely outlast us, so why worry?
I know guys in their 60s who've actually gotten worse. Serious OCD issues at that age can really compromise one's enjoyment of life.
Life's too short for that nonsense and the older we get, the more valuable our time. No sense getting wound up about stuff.
Re: Recommend an oil/weight for Lawn Tractor [Re: sasilverbullet] #4679710
02/27/18 02:38 PM
02/27/18 02:38 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
M1 15W-50 and Fram PH8170 on my Intek.
No need to go to a bigger filter. The PH8170 is built tough.
"Zed's dead baby, Zed's dead."
Re: Recommend an oil/weight for Lawn Tractor [Re: sasilverbullet] #4679734
02/27/18 03:06 PM
02/27/18 03:06 PM
Georgia
MParr Offline
MParr  Offline
Georgia
2013 KIA Optima EX 2.4L. Now: Unknown &OE filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Page 1 of 5 1 2 5
