Vornado fan
by Throt
07/15/18 11:19 PM
Wash Pads - Tried Three
by JHZR2
07/15/18 09:24 PM
Which UTF/UTHF for Allis Chalmers D17?
by SOHCman
07/15/18 09:16 PM
98 leaves needs work or 02 taurus,which one?
by ziggy
07/15/18 09:06 PM
equinox 0W40
by mobilaltima
07/15/18 09:00 PM
New/Old F1 guy?
by Camprunner
07/15/18 08:28 PM
Schaeffer's on "Wicked Tuna"
by salesrep
07/15/18 08:14 PM
AMSOIL Euro Classic 5W-40 (EFM)
by The Critic
07/15/18 06:27 PM
Occasional battery dummy light
by dja4260
07/15/18 05:59 PM
Weird experience with old separating brake grease
by d00df00d
07/15/18 05:54 PM
Ceiling Finish Help
by coopns
07/15/18 05:10 PM
Thunderbird to Outlook Converters??
by doitmyself
07/15/18 04:41 PM
Blaines does it again
by Nitronoise
07/15/18 04:40 PM
BMW E34/M60 Water Pump Replacement
by kschachn
07/15/18 03:30 PM
Okra: how do you make it and like it?
by car51
07/15/18 03:28 PM
2005 Sienna trans issue
by i6pwr
07/15/18 01:46 PM
How is your MLB baseball team doing
by car51
07/15/18 01:02 PM
(8) WIX 57356 + (4) Fram Ultra XG7317
by redhat
07/15/18 12:51 PM
Royal Purple oil filter
by 4WD
07/15/18 12:43 PM
Elon Musk calls Thai Rescue Diver a "Pedo Guy"
by DoubleWasp
07/15/18 12:27 PM
Teggy695, DrDanger, XCIDMigs, DONWATERS, VWhite
65487 Registered Users
53 registered (bbhero, bdcardinal, Brigadier, 10WSmuckers, 555, Ag76, 3 invisible), 1202 Guests and 44 Spiders online.
65487 Members
67 Forums
287085 Topics
Page 1 of 3 1 2 3 >
#4679346 - 02/27/18 12:30 AM When was the Last Time You Used an Inch wrench ?
andyd Offline
Loc: Marshfield , MA
Everything I work on is metric but the Ariens.
Thick oil is better grin2
#4679347 - 02/27/18 12:41 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
Silk Offline
Loc: New Zealand
Probably today. I live in a metric country working on metric vehicles...but still use a bit of SAE. I don't have 16mm spanners, so use a 5/8, don't have a 21mm, so use 13/16. I do have metric in other sizes, but will bring out3/4, 7/8, 15/16 etc because the tools may be a better fit for the job at hand. I keep my Whitworth stuff at home, and some of that gets used on metric as well.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
#4679351 - 02/27/18 01:35 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
das_peikko Offline
Loc: San Antonio, TX
Briggs & Stratton still uses inches; and then you have GM which uses both.
#4679371 - 02/27/18 04:33 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
Dave9 Offline
Loc: Cincinnati, USA
All the time. Old things need worked on. Old things have standard fasteners. Granted I often reach for a metric socket first and if it fits good I use it, or then grab the corresponding metric wrench.
#4679374 - 02/27/18 04:42 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
Shannow Online   content
Loc: 'Stralia
Replaced all the tap washers in my house last weekend.
But like Silk, if you own stuff other people ave worked on, the best fit is the best fit.
#4679375 - 02/27/18 04:52 AM Re: When was the Last Time You Used an Inch wrench ? [Re: Silk]
NGRhodes Offline
Loc: West Yorkshire, UK
Handy to keep imperial spanners and sockets around for removing worn/rusty metric nuts along with a manchester screwdriver, though this is less of an issue in the last decade.
#4679388 - 02/27/18 05:54 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
demarpaint Offline
Loc: NY
Yesterday, and I will be using one today as well.
God Bless Our Troops
#4679410 - 02/27/18 06:41 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
Trav Offline
Loc: MA, Mittelfranken.de
Not very often.
#4679419 - 02/27/18 07:08 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
Astro14 Offline
Loc: Virginia Beach
All the time.
All of my major woodworking machines use inch fasteners (tablesaw, drill press, jointer). Check out my signature. One of those is certainly NOT metric.
The tonneau cover I just put on the Tundra used all inch fasteners.
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
16 Tundra 1794 5W30 Valvoline
#4679429 - 02/27/18 07:23 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
novadude Offline
Loc: Shippensburg, PA
All the time. No metric on my '65 Chevy Nova.
#4679436 - 02/27/18 07:32 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
Snagglefoot Offline
Loc: SE British Columbia, Canada
Just plumbing.
#4679437 - 02/27/18 07:34 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
DBMaster Offline
Loc: DFW
Toilet bolts, two weeks ago.
#4679452 - 02/27/18 07:59 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
Alex_V Offline
Loc: Campbellsville, KY
All the time... because this is the view in my shop lot.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
#4679456 - 02/27/18 08:07 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
motor_oil_madman Offline
Loc: Houston, Texas
You mean SAE?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4679462 - 02/27/18 08:25 AM Re: When was the Last Time You Used an Inch wrench ? [Re: andyd]
NYEngineer Offline
Loc: NY, NY
Last week. I had to change an injector in one of my Cat 3516s at work. 9/16 to remove the valve cover, 5/8 12 point to remove the rocker shaft and 5/8 six point to remove the injector hold down.
First time in quite a while though... Usually I work on bicycles. Metric everything.
Page 1 of 3 1 2 3 >
