Looked at a bottle today of CLP LP. On the back it noted Solids and Solid Boundry Lubrication. Been using LM Ceratec. Does this mean there is a place for solids? Had great success with Archoil 9100,9300 and Ceratec in my car.
Incorrect and if correct...not good: "Boundary lubrication is lubrication by a liquid under
conditions where the solid surfaces are so close together that appreciable contact between opposing asperities is possible."
I believe that until recently Break-Free CLP (IS that the CLP you are speaking of??) used colloidal PTFE in their formulation. With the somewhat recent milspec changes, BF CLP has cut loose with the PTFE and now meets the spec.
