voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Geardaddies, tedonom, 01ws666, ariefnrst, tcoffin014
66658 Registered Users
101 registered members (4WD, 28oz, 2008wrx, 2004tdigls, 13 invisible), 1,864 guests, and 35 spiders.
Topics294,978
Posts4,925,312
Members66,658
Most Online2,553
Oct 27th, 2018
lawn boy tecumseh to briggs swap? #4679150
02/26/18 08:04 PM
02/26/18 08:04 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
i have a 1994 silver series lawn boy . it has a 4 cycle 5.5 hp tecumseh engine in it. after all these years the engine died. the body and drive is still in good shape.
my neighbor has a mower with a briggs 6 hp engine on it. the drive is shot, but the engine runs.
so i am wondering if i can swap that engine into the lawn boy. anyone do a tecumseh to briggs swap? do they use the same bolt pattern?
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679170
02/26/18 08:20 PM
02/26/18 08:20 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
That's why God invented the 3/8 drill grin2
Thick oil is better grin2
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679220
02/26/18 08:58 PM
02/26/18 08:58 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Get a Harbor freight vertical shaft engine instead.
Only: $119.99 (Compared to $369.99, Honda GXV160)
https://www.harborfreight.com/55-hp-173cc-ohv-vertical-shaft-gas-engine-carb-69731.html
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679227
02/26/18 09:01 PM
02/26/18 09:01 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679231
02/26/18 09:07 PM
02/26/18 09:07 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Hmmmmm......
https://www.ebay.com/itm/271932531668
NEW 140cc OVERHEAD VALVE VERTICAL SHAFT GAS ENGINE MOTOR 7/8"
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679235
02/26/18 09:09 PM
02/26/18 09:09 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Even cheaper!
https://www.ebay.com/itm/5HP-140cc-Press...ft/282632524952
5HP 140cc Pressure Washer Tiller Log Splitter Engine DJ1P65F 7/8" Shaft
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679239
02/26/18 09:11 PM
02/26/18 09:11 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
HEY!!
Here's a Honda!!
The price is RIGHT!!!
https://www.ebay.com/itm/GCV-190-Honda-6...e-/281880370047
GCV 190 Honda 6hp Over Head Cam Motor 7/8" x 1-7/8" Vertical Shaft Engine
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679241
02/26/18 09:12 PM
02/26/18 09:12 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
This Honda is cheaper yet!
https://www.ebay.com/itm/GCV-190-Honda-6...e-/282316203043
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679242
02/26/18 09:14 PM
02/26/18 09:14 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
The HF Predator engine can be bought for even cheaper if you use a 20% off coupon.
I installed one on an old Craftsman 22" push mower and it fit right on. Started on the 1st pull too, every time.
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679249
02/26/18 09:21 PM
02/26/18 09:21 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
They guy asked if he could swap the engines not where to get a new one.
If the holes aren't there drill them. It will work with a little work.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679256
02/26/18 09:30 PM
02/26/18 09:30 PM
USA
mk378 Offline
mk378  Offline
USA
It's probably the same mounting bolt pattern. The bigger question is the shaft size.
I have had a lot of trouble with the mounting bolts being stuck in the engine and breaking off trying to remove old Briggs engines. Also blade adapters rusted onto the shaft.
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679293
02/26/18 10:16 PM
02/26/18 10:16 PM
South Florida
bubbatime Online shocked
bubbatime  Online Shocked
South Florida
It will bolt right on. The shafts have to be the same length, otherwise you will never find the proper adapter to get the blade in the right spot. If the shafts are not the same size, forget it.
Shaft diameter is either 7/8 or 25mm. Length of shaft is usually 3 5/8, but not always.
Getting the rusted blade adapter off can be impossible.
It might be easier/cheaper to rebuild the drive components on your neighbors mower. Or buy a used mower off Craigslist.
And almost every one of those engines posted above by a well intentioned poster would not even come close to working.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Maxlife Syn 5W30
06 GMC Sierra Nextgen 10W30
Re: lawn boy tecumseh to briggs swap? [Re: bubbatime] #4679305
02/26/18 10:51 PM
02/26/18 10:51 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
it actually died at the end of the summer last year. i was able to to find a 2000 toro super recycler for $60 that i will use this year. i really just want to do this as a fun project. i am hoping that i can use the engine and if possible the pulleys from the other mower to work the drive on the LB. i don't plan to throw too much money at it . if it does work i might give to someone in need .
these offset wheel Lawn boys seem to have a collector following .
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679310
02/26/18 11:03 PM
02/26/18 11:03 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
To answer the original question: As long as the bolt pattern and crankshaft length are the same, it'll work.
Re: lawn boy tecumseh to briggs swap? [Re: WhyMe] #4679331
02/26/18 11:36 PM
02/26/18 11:36 PM
Cave City KY
jakewells Offline
jakewells  Offline
Cave City KY
Briggs engine will fit the deck just make sure that shaft isn't to long or you got to shim the engine with round washers. You will also have to use a universal 21'' blade.
1994 Ford F150 302 4R70
Chevron Delo SAE 30 CF/SL Fram XG8A
1978 Chevy Nova 250 I6 Borg Warner T5
Rotella 10W40 Fram XG5
