PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on ‚Äúclearance‚ÄĚ at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
124 registered members (2015_PSD, 01rangerxl, 2K2AcuraTL, 12 invisible), 2,023 guests, and 61 spiders.
Topics286,162
Posts4,903,342
Members67,569
Most Online2,967
Mar 10th, 2019
Stanadyne Performance Formula ?? #4678513
02/26/18 10:15 AM
02/26/18 10:15 AM
Colorado
huntsonora Offline OP
Colorado
I have a 1998 Dodge 2500 4x4 with a 12 valve cummins. Usually Iíll run ashless ST 2 stroke oil at about 1/2-1 oz per gallon of diesel.
Yesterday, I was at a farm and ranch store and they had Stanadyne Performance Formula in a 5 gallon pail marked down to $79 so I bought it. [censored], the 1/2 gallon was $30 so it seemed like a bargain
Anybody use this stuff? Any recommendations? Use it by itself or with 2 stroke for added lubricity? Would using them together eliminate any of the advantages of either product?
Re: Stanadyne Performance Formula ?? [Re: huntsonora] #4678526
02/26/18 10:24 AM
02/26/18 10:24 AM
Houston, TX
2015_PSD Online content
2015_PSD  Online Content
Houston, TX
I use it regularly in my PSD, but I use it for water in the fuel and lubrication versus any potential performance gains. You did get a very good deal on it and Stanadyne has been on clearance for a while due to a rebranding of the product.
As an aside, I have found no valid information that 2 cycle oil increases lubricity in the slightest. I posted something on this a few months ago, give a quick search and you should be able to find it.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: Stanadyne Performance Formula ?? [Re: 2015_PSD] #4678548
02/26/18 10:59 AM
02/26/18 10:59 AM
Colorado
Colorado
Looked and couldnít find it....
Re: Stanadyne Performance Formula ?? [Re: 2015_PSD] #4678566
02/26/18 11:18 AM
02/26/18 11:18 AM
Cincinnati, OH, USA
bullwinkle Online confused
bullwinkle  Online Confused
Cincinnati, OH, USA
It definitely helped on my '02 Ram's VP44, before it got bad enough & I could shop enough Dodge dealers to get it replaced under 100K engine warranty. My Stanadyne mechanical IPs seem to like an occasional quart in winter, when the ULSD is drier than usual. I don't use it in CR diesels, though, just PS silver bottle.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Stanadyne Performance Formula ?? [Re: huntsonora] #4678573
02/26/18 11:21 AM
02/26/18 11:21 AM
St. Louis
MONKEYMAN Offline
MONKEYMAN  Offline
St. Louis
Used it on my stepfather's '95 Chevy with the 6.5 Turbo diesel. It ate injection pumps. Many replaced under extended warranty. After Performance Formula used religiously, zero injection pump failures. It was worth the price since truck was past extended warranty.
Truth alone triumphs, not untruth.
2017 Elantra SE
Re: Stanadyne Performance Formula ?? [Re: huntsonora] #4678601
02/26/18 11:46 AM
02/26/18 11:46 AM
Houston, TX
Houston, TX
Here is a link to the report that I posted: 2-Stroke Oil In Diesel Ė A Technical Study
Re: Stanadyne Performance Formula ?? [Re: huntsonora] #4678664
02/26/18 12:49 PM
02/26/18 12:49 PM
Colorado
Colorado
Interesting! I know for a fact that it quiets down my old 12 valve. Those 12 valves will run on about anything though.
Regardless, I can buy B20 here close and I could buy 30 gallons at a time in 5 gallon Scepter cans and put 5 gallons in at each fill up and itíll be better than 2stroke and have been considering doing that anyway
Re: Stanadyne Performance Formula ?? [Re: 2015_PSD] #4680858
02/28/18 06:52 PM
02/28/18 06:52 PM
Colorado
Colorado
Looked at that study and they were running JASO-FC oil through common rails and not the ashless TCW-3. JASO-FC oils have higher levels of zinc donít they?
Re: Stanadyne Performance Formula ?? [Re: huntsonora] #4681189
03/01/18 04:09 AM
03/01/18 04:09 AM
California
CleverUserName Offline
California
It may be old stock. The PF has a temperature dependant shelf life, I think they only guarantee the effectiveness for 2-3 years from date of production.
Source: Called stanadayne and asked about age degradation. I was given 1 gallon of the PF by a co-worker for free, it is 8-10 years old but I've been using it with no ill effects.
Re: Stanadyne Performance Formula ?? [Re: huntsonora] #4681390
03/01/18 11:03 AM
03/01/18 11:03 AM
Houston, TX
Houston, TX
I have not found any evidence in all of my searching that TCW (2-Cycle Oil) improves lubricity in the fuel in a modern diesel engine. I wish it did, 2-Cycle oil is much cheaper than Stanadyne, Diesel Kleen, Howe's, and the like.
Re: Stanadyne Performance Formula ?? [Re: 2015_PSD] #4681824
03/01/18 09:44 PM
03/01/18 09:44 PM
Colorado
Colorado
But the 2 stroke used in the study wasnít the TCW-3 that is recommended. I can tell you for a fact that my 12 valve is quieter and smoother when it has the TCW-3 added to the fuel
Re: Stanadyne Performance Formula ?? [Re: huntsonora] #4681842
03/01/18 10:32 PM
03/01/18 10:32 PM
Kentucky
Ramblejam Offline
Ramblejam  Offline
Kentucky
Looked at a few TC-W3 oils; anywhere from 30 - 50 cSt @ 40įC
Per Chevron, ULSD is 2.6 cSt @ 40įC
Makes sense that when adding a exponentially more viscous component to the base fuel you're seeing quieter operation.
https://www.chevron.com/-/media/chevron/operations/documents/diesel-fuel-tech-review.pdf
Re: Stanadyne Performance Formula ?? [Re: huntsonora] #4681973
03/02/18 06:51 AM
03/02/18 06:51 AM
Houston, TX
Houston, TX
I understand, but I am saying I have not found any evidence that any form of two stroke oil increases lubricity in diesel fuel. If you have found some, please share--it would be great to use that instead of the other additives, although lubricity is only part of it, I also want to control water in the fuel.
Re: Stanadyne Performance Formula ?? [Re: huntsonora] #4691887
03/11/18 08:23 PM
03/11/18 08:23 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
OP's truck is a 1998 which I don't think it is categorized as the modern diesel.
So, any diesel additive including 2 cycle oil is probably good.
I have a 95 6.5L Turbo Diesel and I used the 2 cycle mix with diesel additive with good results.
Now, the results are not scientific but I had the diesel for more than 12 years now and the IP is still good.
  • 2017 Toyota Sienna
Re: Stanadyne Performance Formula ?? [Re: huntsonora] #4693146
03/13/18 07:06 AM
03/13/18 07:06 AM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
The Stanadyne stuff is good enough that when VW released a TSB around 2004 about fuel gelling in the winter, that was the approved product sold at VW dealerships.
Stanadyne is a demulsifier, so it will cause the water in the fuel to separate, hoping that it happens at the fuel filter (where it could be drained), but, usually occurs in the fuel tank instead.
Of course, I couldn't pay for marked up items, so I just used PowerService Diesel Fuel Supplement, which is a lot less expensive at that time for me. PowerService is a solubilizer, where the water is mixed into the diesel.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
