Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
I Had To Tell Somebody- Banquet
by Zee09
06/22/18 05:13 PM
Xfinity mobile cell service
by jay929
06/22/18 04:37 PM
Fuse "failure"
by dlundblad
06/22/18 04:32 PM
Do you Bluetooth your phone and car?
by ZZman
06/22/18 04:20 PM
Hastings air filters
by Spitter
06/22/18 04:18 PM
2011 Town and Country remote started itself.
by mrsilv04
06/22/18 04:06 PM
Vaughan Hammer and Superbar $10 Sam's
by hatt
06/22/18 04:03 PM
Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
Bench Drill Press
by Propflux01
06/22/18 02:30 PM
IAT Sensor
by artbuc
06/22/18 02:26 PM
2013 Nissan Rogue, 5,100 miles, Supertech Conv
by TheOilWizard
06/22/18 01:46 PM
NC License Plates
by Zee09
06/22/18 01:31 PM
BITOG Hotline!
by Duffyjr
06/22/18 01:30 PM
Switching Additives: Flush/Rinse?
by Phishin
06/22/18 12:46 PM
increasing viscosity
by VQLT
06/22/18 12:31 PM
Who's up on their metallurgy?
by earlyre
06/22/18 11:56 AM
Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
84 registered (Bandito440, andyd, 2015_PSD, 93cruiser, ammolab, Astro14, 13 invisible), 1548 Guests and 52 Spiders online.
65294 Members
67 Forums
285789 Topics
#4678319 - 02/26/18 01:14 AM Has anyone mixed Hyundai PSF-3 with something else
TheMidnightNarwh Offline
Loc: Gatineau QC Canada
Has anyone mixed Hyundai/Kia PSF-3 with something else without issues? Let me explain.
I want to change my PS fluid with the turkey baster method so it's not 100% flush. Dealer told me they sell PSF-4 now. He said it's fine to mix for small topoff only and told me it cannot mix if doing turkey baster change.
I don't want to do whole flush as per manual because complicated and lines are rusty and old. Car is a 2006 Hyundai Tucson if it matters.
So anyone here mixed it with something else and ran it in their car with no issues?
Edited by TheMidnightNarwh (02/26/18 01:20 AM)
#4678376 - 02/26/18 05:37 AM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: TheMidnightNarwh]
JC1 Offline
Loc: Oshawa, Ontario Canada
May I ask why you want to flush the power steering lines? Are you having issues or just doing preventative maintenance?
Sounds like you need to get a fluid extractor and disconnect the lines going to the reservoir to get the old fluid out.
I've never done this on a Hyundai, but I cannot see this fluid change causing big issues.
You may need to fill and remove a few times to get most of the old stuff out.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4678453 - 02/26/18 07:50 AM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: TheMidnightNarwh]
knerml Offline
Loc: NE Ohio
You can get PSF-3 online at Amazon and Ebay.
I have been using RAVENOL J1B1031, which is PSF-3 compatible. Best price on Ebay from Blauparts, a VW/Audi parts supplier I have been using for 15 years.
RAVENOL lists J1B1001 for PSF-4, so I am not mixing PSF-3 and PSF-4.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T GDI Castrol Edge 5W40 & OEM/Mann W811/80 Filter
#4678461 - 02/26/18 08:04 AM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: TheMidnightNarwh]
Jimzz Offline
Loc: NoVA
PSF-3 was just their name for Dexron 2. Just use any good transmission fluid that meets Dex3 or better and you will be fine. The steering system is not that picky.
yup
#4678480 - 02/26/18 08:41 AM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: TheMidnightNarwh]
wymi516 Online   content
Loc: Illinois
I use Valvoline Maxlife ATF in my neighbors 07 Sonata for pump and dumps every other oil change, no issues after 3 years.
2016 KIA Forte SX 1.6L T-GDI Daughter
2013 Chevy Impala LT 3.6L GDI Mine
2014 Chrysler 200S 3.6L PFI Wife
#4678485 - 02/26/18 08:44 AM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: TheMidnightNarwh]
mrdctaylor Offline
Loc: McGregor TX
I had to have the power steering pump replaced on my 2003 Santa Fe at around 208K miles. I asked the mechanic (who is very reliable/conscientious) what type of fluid he used. He said he looked it up and it specifically called for ATF in this year/model. So I'm assuming that whoever is saying PSF3 is just ATF is pretty much correct. It has been running just fine since I had the power steering pump changed out.
But one word of warning: aftermarket power steering pumps are a [censored]. He put a couple of them on that were insanely noisy, so I found an OEM one online that works perfectly.
02 Tacoma 3.4L, 215K, Magnatec 10W30
02 Trailblazer 4.2L, 174K, Magnatec 5W30
12 Highlander 3.5L, 88K, M1 EP 0W20
17 Escape 2.0L, 31K, Hav ProDS 5W30
#4678717 - 02/26/18 01:12 PM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: wymi516]
pandus13 Offline
Loc: Chicago,IL,USA
This ^^^ (Valvo Maxlife ATF) and Castrol Import Multi-vehicle ATF, I used in my former '04 Elantra.
The change to new fluids cured the whine noise in cold mornings. Also it seem to move more freely.
I had it for 7.5 years and 74k miles.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
#4678730 - 02/26/18 01:28 PM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: TheMidnightNarwh]
SHOZ Offline
Loc: Illinois
If you can get to the cooler you can drain 95% of the oil out. Easy hose clamp set up.
I went to Prestone with stop leak. $5 a quart at Walmart for the fill. Works great.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4678837 - 02/26/18 03:02 PM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: JC1]
I wanted to change because it's dark ish and probably was never changed. My pump also did some whine one morning.
Like I said I don't want to flush. My plan to change it was suck some out of the reservoir, fill it back. That's it. Do that few days a week until it's more clear.
#4678838 - 02/26/18 03:03 PM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: knerml]
They don't sell the fluid on Amazon or Ebay Canada.
#4678839 - 02/26/18 03:04 PM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: wymi516]
But was it mixed with the old fluid in there or you made a flush first then put whole new liquid?
#4678840 - 02/26/18 03:05 PM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: SHOZ]
Like I said I don't want to flush. Just suck out of reservoir and put some new until it's clear.
#4678841 - 02/26/18 03:06 PM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: pandus13]
Did you do complete flush than new though or it was mixed with the PSF-3 in there?
#4679482 - 02/27/18 08:50 AM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: TheMidnightNarwh]
pandus13 Offline
Loc: Chicago,IL,USA
Pull fluid from the reservoir and refill every weekend until color was the same as in the bottle.
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
#4682462 - 03/02/18 04:08 PM Re: Has anyone mixed Hyundai PSF-3 with something else [Re: TheMidnightNarwh]
Loc: Illinois
It was a mix at at the start of me doing that. It's pretty much all Valvoline now. Mixing didn't seem to matter.
