(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
89 registered members (Baracoa, advocate, 14Accent, 2015_PSD, Astro14, ArrestMeRedZ, 10 invisible), 1,637 guests, and 36 spiders.
Topics296,757
Posts4,958,275
Members66,964
Most Online2,577
Jan 14th, 2019
Need floor jack that can use Pinch Weld adaptor #4678034
02/25/18 07:10 PM
02/25/18 07:10 PM
Ypsilanti, MI
MI_Roger Offline OP
MI_Roger  Offline OP
Ypsilanti, MI
Ok, I have one of these Pinch Weld Adapters and need it when lifting any of my three cars, as well as my son's car.
This adapter fits by removing the steel cup on my old jack and placing the pin in the mounting hole for the cup. It seems that all current jacks use a rubber lifting pad that is not removable, thus no mounting pin hole for the Body Pinch Weld Adapter.
Any good, and affordable, jack recommendations for a D-I-Y'er that allows use of a pinch weld adapter/protector?
Thanks,
Re: Need floor jack that can use Pinch Weld adaptor [Re: MI_Roger] #4678042
02/25/18 07:14 PM
02/25/18 07:14 PM
out there
spasm3 Online content
spasm3  Online Content
out there
Hockey puck with a slot. Or what i do. A piece of oak with a slot cut across the grain.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: Need floor jack that can use Pinch Weld adaptor [Re: MI_Roger] #4678066
02/25/18 07:35 PM
02/25/18 07:35 PM
WI
HoosierJeeper Offline
WI
I use a piece of oak with a slot. Works perfectly.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Need floor jack that can use Pinch Weld adaptor [Re: MI_Roger] #4678104
02/25/18 08:09 PM
02/25/18 08:09 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
you just need a jack with an adjustable height they are screw in and removable
This kind may not work
the screw in kind will.
Re: Need floor jack that can use Pinch Weld adaptor [Re: spasm3] #4678144
02/25/18 08:37 PM
02/25/18 08:37 PM
South Carolina
eyeofthetiger Offline
South Carolina
Or, the best idea yet, use a wooden hockey puck! grin
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Need floor jack that can use Pinch Weld adaptor [Re: MI_Roger] #4678172
02/25/18 09:06 PM
02/25/18 09:06 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
Thanks,
If you go to a shop they will lift by the flat part of the arm on their lift. It will hit the bottom edge of the pinch weld.
If you use the vehicle jack, you may find out it lifts on either side of the pinch weld but only uses the pinch weld to hold the jack from shifting. Thats the way it is on my Subaru.
Or use a lift spot on the vehicle that is made for a floor jack.
2015 Ford F250 w/Powerstroke
Re: Need floor jack that can use Pinch Weld adaptor [Re: MI_Roger] #4678311
02/26/18 12:22 AM
02/26/18 12:22 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
A hockey puck with no slot works just as well.
Re: Need floor jack that can use Pinch Weld adaptor [Re: MI_Roger] #4678432
02/26/18 07:20 AM
02/26/18 07:20 AM
northern NY
Driz Offline
Driz  Offline
northern NY
Donít all the jacks tend to have that small center locator hole that the cradle sits in? I would think theyíre all pretty generic. My chosen method nowadays is a block of 6 inches worth of 2 x 4 which I wrapped a piece of steel around most of the way and screwed on. Thatís the only way to keep it from splitting. I prefer the wood to something like that simply because youíre not scraping the paint off of that metal to metal contact on nothing but sheet metal. If I was going to use one of those I get some old carpet and stuff it in that crack and let it hang out both sides.
Itís funny all these years Iíve managed to not have to make anything like that until I got a recent Hyundais and use just plain nowhere underneath there to find a reasonable place to steal the pick the car up. I suspect Iíll be making them out of beer cans and tinfoil next.
Re: Need floor jack that can use Pinch Weld adaptor [Re: spasm3] #4678435
02/26/18 07:26 AM
02/26/18 07:26 AM
NY
demarpaint Offline
demarpaint  Offline
NY
That's what I use with a 3 ton Sears floor jack and a HF 4 ton floor jack. The puck works great. If I need to get the puck a little higher I have a 3/4" plywood disk I cut to put under it. I also have a 3/4" plywood disk with carpet glued to it if I'm worried about scratching the chassis, pumpkin, or anything else for that matter with the metal cup on the jack.
God Bless Our Troops
Re: Need floor jack that can use Pinch Weld adaptor [Re: MI_Roger] #4679076
02/26/18 06:57 PM
02/26/18 06:57 PM
Woodbridge, NJ
Dadillac Offline
Dadillac  Offline
Woodbridge, NJ
I don't use anything. My jack has a rubber pad. I just put it under the pinch weld and jack it up. Haven't damaged a pinch weld yet.
Don
Re: Need floor jack that can use Pinch Weld adaptor [Re: MI_Roger] #4679580
02/27/18 10:44 AM
02/27/18 10:44 AM
Illinois
javacontour Offline
javacontour  Offline
Illinois
Got these from Amazon
I think they are about 3" in diameter and fit in the cup of my floor jack.
network down, IP packets delivered via UPS -BOFH
Re: Need floor jack that can use Pinch Weld adaptor [Re: MI_Roger] #4680475
02/28/18 10:24 AM
02/28/18 10:24 AM
alabama
wayne50 Offline
wayne50  Offline
alabama
What about getting a hockey puck or round piece of wood for that matter, drill a hole for your pinch weld adapter, and then place it on the jack.
Re: Need floor jack that can use Pinch Weld adaptor [Re: MI_Roger] #4681357
03/01/18 09:22 AM
03/01/18 09:22 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Thanks,
Where did you get this piece? I need one.
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
