Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
70 registered members (ammolab, aaronc7, allgm59, 97prizm, Aichiguy, 2010Civic, 4 invisible), 1,213 guests, and 63 spiders.
Topics286,216
Posts4,904,445
Members67,579
Most Online2,967
Mar 10th, 2019
What type of material for oil drain plug & washer? #4677497
02/25/18 11:41 AM
02/25/18 11:41 AM
Canada
twj348 Offline OP
twj348  Offline OP
Canada
Is it okay to use an aluminum drain plug in a steel oil pan? What about using a stainless steel drain plug in an aluminum oil pan? I'm assuming that mixing two different materials may cause corrosion. Also, I've noticed drain plug washers come in steel, aluminum, and copper, but I'm not sure which is best to use.
Re: What type of material for oil drain plug & washer? [Re: twj348] #4677516
02/25/18 11:47 AM
02/25/18 11:47 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Iím thinking itís coated in oil enough to never corrode.
If you want the job done right......do it yourself.
Re: What type of material for oil drain plug & washer? [Re: twj348] #4677526
02/25/18 11:50 AM
02/25/18 11:50 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
You can use both those in the applications you posted, Personally I am not a fan of aluminum drain plugs or plastic washers. Aluminum and copper washers are good the steel ones I have seen have some sort of rubber seal and are also okay, if it were just plain steel I wouldn't use it.
Re: What type of material for oil drain plug & washer? [Re: twj348] #4677528
02/25/18 11:52 AM
02/25/18 11:52 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
In salt water - do not mix.
In an oil pan threads - Corrosion will never ever ever ever ever ever ever happen. Ever.
Re: What type of material for oil drain plug & washer? [Re: Trav] #4677559
02/25/18 12:09 PM
02/25/18 12:09 PM
Texas
4WD Offline
4WD  Offline
Texas
Yes Ö I buy copper washer assortment packs Ö canít go wrong if you donít over torque them Ö
Can be handy for wiring too Ö
Re: What type of material for oil drain plug & washer? [Re: twj348] #4677646
02/25/18 01:38 PM
02/25/18 01:38 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
I've had cars with plain steel, plain aluminum, and plastic-coated aluminum drain washers. None ever leaked or required replacement for any other reason. The plain aluminum one gradually became thinner, so after several hundred thousand miles, it couldn't fall off the plug---a good thing.
2011 Toyota Prius now at 97K
Re: What type of material for oil drain plug & washer? [Re: twj348] #4677764
02/25/18 03:32 PM
02/25/18 03:32 PM
Margate England
Claud Offline
Claud  Offline
Margate England
Some of the recent cars on the European market have plastic drain plugs. Guess what happens when you try to undo it on a hot engine?.
Nice scam methinks....
Claud.
Re: What type of material for oil drain plug & washer? [Re: twj348] #4677789
02/25/18 04:04 PM
02/25/18 04:04 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
I've used aluminum drain plug gaskets in the last six Toyotas and Hondas and corrosion is not a problem. Use a new gasket, torque to 33 ft.lbs. or whatever and no problems,never.
Re: What type of material for oil drain plug & washer? [Re: Claud] #4677792
02/25/18 04:07 PM
02/25/18 04:07 PM
Vancouver, Canada
jaj Offline
jaj  Offline
Vancouver, Canada
Originally Posted By: Claud
Some of the recent cars on the European market have plastic drain plugs. Guess what happens when you try to undo it on a hot engine?...
Let me guess... it comes off and oil comes out?
I've got a 2016 Ford Mustang V8 with a plastic drain plug - 1/3 of a turn and it's out, 1/3 of a turn and it clicks back in. The challenge is that it's about an inch in diameter and 10 quarts of hot oil comes out REALLY FAST.
Re: What type of material for oil drain plug & washer? [Re: Claud] #4677795
02/25/18 04:11 PM
02/25/18 04:11 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Ever use one? They're great!
"Zed's dead baby, Zed's dead."
Re: What type of material for oil drain plug & washer? [Re: Claud] #4677930
02/25/18 06:38 PM
02/25/18 06:38 PM
Trav Offline
Trav  Offline
Claud.
They are in composite pans AFAIK but I guess there is no reason they couldn't be used in steel or aluminum, all plastics are not weak or junk.
Re: What type of material for oil drain plug & washer? [Re: Trav] #4677963
02/25/18 07:09 PM
02/25/18 07:09 PM
Texas
4WD Offline
4WD  Offline
Texas
This 5.3L two piece does add another gasket but puts the plug in steel. Also like how the plug and the filter are right behind the belly shield so it stays in place for oil change. Does this access the screen or what?
Re: What type of material for oil drain plug & washer? [Re: rooflessVW] #4678599
02/26/18 11:45 AM
02/26/18 11:45 AM
Margate England
Claud Offline
Claud  Offline
Margate England
What is it that makes them great?.
I've yet to come across an oil drain plug that gave me cause to think it was even slightly above average, never mind great.
Claud.
Re: What type of material for oil drain plug & washer? [Re: twj348] #4679049
02/26/18 07:41 PM
02/26/18 07:41 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I can't say I've ever seen an aluminum washer with a steel pan.
You wouldn't want to use SS for a washer. Too hard and wouldn't crush.
Find an OE washer for your vehicle and use that style.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: What type of material for oil drain plug & washer? [Re: dlundblad] #4679368
02/27/18 05:04 AM
02/27/18 05:04 AM
Youngstown, NY
Subdued Offline
Subdued  Offline
Youngstown, NY
Everything can crush.
2015 Jeep Cherokee 18k
2008 Chrysler Town & Country Touring 149k
2007 Toyota Yaris S 170k
