It's AMSOILŪ, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
71 registered (2009Edge, 2015_PSD, 63Marauder, badtlc, 10 invisible), 1189 Guests and 36 Spiders online.
65319 Members
67 Forums
285956 Topics
#4677105 - 02/24/18 11:04 PM 2011 BMW 328i - coolant leak
Ndx Offline
Loc: IL
Hi Guys,
I'm trying to find coolant leak... Has anyone used the UV dyes ?
Do I just add it too coolant ?, Do I have to flush system after ?
Are those dyes universal or coolant specific ? If specific any recommendations for Bmw coolant.
Thank you
#4677190 - 02/25/18 02:35 AM Re: 2011 BMW 328i - coolant leak [Re: Ndx]
rooflessVW Online   content
Loc: North Carolina
You simply add the due to the coolant, however;
An external coolant leak should be fairly obvious even without a dye.
How much are you losing? If you can't see crusty coolant trails it may be the heater core or internal.
"Zed's dead baby, Zed's dead."
#4677288 - 02/25/18 07:30 AM Re: 2011 BMW 328i - coolant leak [Re: Ndx]
Audios Offline
Loc: Lyndhurst NJ
Pressure test the system to find leaks, the coolant is already blue. Ive been having a run on radiators and expansion tanks on the E9x's lately. Get it up in the air take the panel off and look from the bottom.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2005 BMW M3 BMW Twin Power 10/60
1998 BMW M3/4/5 Fuchs 5/40
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
#4677325 - 02/25/18 08:07 AM Re: 2011 BMW 328i - coolant leak [Re: Ndx]
Ndx Offline
Loc: IL
It's leaking on outside but I think only while driving or super hot.
I see drips on driveway but even that does not help pin point....
I had oring on filter cap fail and spray everything around so that does not help lol it's mess there ... I don't want to wash engine in winter ...
Thx guys
#4677426 - 02/25/18 09:53 AM Re: 2011 BMW 328i - coolant leak [Re: Ndx]
andyd Offline
Loc: Marshfield , MA
Later model BMWs plastic cooling parts have a rising failure rate as the car approaches 100K miles. The old, last 30 yrs plus stuff, wasn't recyclable enough.
Thick oil is better grin2
#4677430 - 02/25/18 09:57 AM Re: 2011 BMW 328i - coolant leak [Re: Ndx]
Lolvoguy Offline
Loc: Canada
Doing a cooling system "overhaul" once every 80k miles, seems to be very common on these cars as complete kits are readily available:
https://www.fcpeuro.com/products/bmw-cooling-system-overhaul-kit-e46-oem-e46coolkit
06 Lexus IS350- Wife
88 BMW 325is- Mistress
03 Suzuki SV650S- One night stand
#4678515 - 02/26/18 09:15 AM Re: 2011 BMW 328i - coolant leak [Re: Lolvoguy]
jeepman3071 Offline
Loc: Storrs, Connecticut
That's for the E46, the OP is talking about an E90 generation car.
OP: How many miles on the car? Check the plastic coolant hose connectors for white residue or drips. The o-rings on the connectors like to leak and the plastic hoses crack. My GF's E90 cracked the coolant hose with the sensor on the passenger side. The hose cracked right where the sensor mounts onto the connector.
Also have you replaced the oil filter housing gasket yet? The gasket gets brittle over time and can cause coolant and oil to mix. Like stated above also check the expansion tank and cap for white residue. The tanks crack and the caps fail, causing them to lose pressure and leak.
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (32k) - Castrol Edge Euro 0w40, MANN HU816X
#4678608 - 02/26/18 10:55 AM Re: 2011 BMW 328i - coolant leak [Re: Ndx]
Alfred_B Offline
Loc: America
Probably a hairline crack on the coolant expansion tank if it only happens when super hot. E46 has that issue, I thought they had fixed it for E90.
#4678868 - 02/26/18 03:30 PM Re: 2011 BMW 328i - coolant leak [Re: Ndx]
Trav Offline
Loc: MA, Mittelfranken.de
The dye works well with a UV light, get one for coolant (dexcool has a different one) run it and pressurize it then start looking.
I would bet its from some plastic part that is cracked on these.
#4679275 - 02/26/18 09:48 PM Re: 2011 BMW 328i - coolant leak [Re: Ndx]
antonmnster Offline
Loc: Minneapolis
My radiator developed a slow leak in a corner around 120k. be THANKFUL you don't have a 335. That job brought me to tears - it's like the assembled the unibody around the radiator.
Pay attention to where the puddle is when you park it. Is it right at the front? Driver side? Passenger? Those can be big clues. Otherwise don't be afraid to get under it and pop the splash shield off. Take a good look around the water pump, the big electric pump hanging off the passenger front corner of the block. Odds are highest that it's the pump. Just a heads up, it ain't cheap, and it ain't easy to get to.
#4679526 - 02/27/18 09:43 AM Re: 2011 BMW 328i - coolant leak [Re: Ndx]
mightymousetech Offline
Loc: Ontario, Canada
On an E90, first thing to check is the expansion tank and the water pump.
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
