Any real advantage of Iridium plugs in motorcycle?
Michigan
Iridium plugs can make sense in a car with hard to reach plugs and rack up lots of miles. But do they really make sense in a motorcycle that gets a few thousand miles a year and aren't hard to change?
Iridium and platinum require less voltage to fire, at high RPM this may make a difference in reducing the possibility of a misfire.
Some bikes fire the plugs on every stroke (wasted spark) plugs wear out twice as fast. Iridiums in the Wife's Nija 250
Are holding up well.
Sure they do. Iridium are usually fine wire plugs. With small electrode area at the tip they concentrate the ionization charge and make it easier to fire. So you can usually open them up at least 0.005 over standard plugs w/o adding any load to the coils. Bigger spark gap is better ignition when it goes off
Iridium plugs will last a lot longer in cycles just like
in cars and trucks.
Honda originally called for plug changes at 8000 miles=
ridiculous.
No
My 2013 Honda pickup came from the factory with double-iridium plugs, and they specify them for replacement _just_ after the emissions performance requirement ends.
My 2012 Honda motorcycle came from the factory with double-iridium plugs, and they specify them for replacement _just_ after the emissions performance requirement ends.
Perhaps this is _only_ coincidence?
