Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
Super Tech Conventional 15w40 HDEO. CK-4/SN
by Snagglefoot
06/23/18 09:38 AM
1 gallon jug of Sta-bil for $7 at Rural King
by classic70
06/23/18 09:34 AM
Anger on BITOG
by Gebo
06/23/18 08:55 AM
2010 Acura MDX w/ 3.7 lire oil consumption issue
by Varbill
06/23/18 08:45 AM
Surprising oil filter service interval.
by jakewells
06/23/18 08:12 AM
World Population
by CourierDriver
06/23/18 08:11 AM
SBC Finned Aluminum Dress Up Kit $32
by hatt
06/23/18 07:35 AM
Meguiars
by dslofti
06/23/18 07:20 AM
Roller Bearing Setup For Dillon Shellplate
by billt460
06/23/18 05:59 AM
Omnia - the band
by Shannow
06/23/18 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
06/23/18 12:54 AM
Battery stuck in flashlight.
by Chris142
06/22/18 11:53 PM
Must read for everyone watching their diet
by JLTD
06/22/18 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
06/22/18 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
06/22/18 10:47 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
90 registered (4WD, 2002 Maxima SE, aquariuscsm, advocate, andyd, 330indy, 10 invisible), 1643 Guests and 32 Spiders online.
65299 Members
67 Forums
285845 Topics
#4676800 - 02/24/18 05:57 PM Cold Cranking ?
Ndx Offline
Loc: IL
Hi Guys,
How to decode which number is the CCA ?
580A or 920A.
My guess is 580A but what is the 920A number
Thank you
Edited by Ndx (02/24/18 06:00 PM)
#4676806 - 02/24/18 06:06 PM Re: Cold Cranking ? [Re: Ndx]
Kibitoshin Offline
Loc: Kaiōshinkai
Info in this link: https://www.yuasa.co.uk/info/technical/understanding-the-specifications/
DIN and EN/SAE/GS are different ways the battery is tested for CCA. The most common measurement is SAE.
Edited by Kibitoshin (02/24/18 06:08 PM)
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L - 170k mi
02 Chevy Silverado C1500 V8 5.3L 154k mi
#4676817 - 02/24/18 06:17 PM Re: Cold Cranking ? [Re: Ndx]
sxg6 Offline
Loc: ME
Looks like it has 580CCA. 920 is probably the number of standard cranking amps.
https://parts.audiusa.com/p/Audi__/Battery-Vehicle-Battery/47983532/000-915-105-CF.html
#4677220 - 02/25/18 04:57 AM Re: Cold Cranking ? [Re: Ndx]
Char Baby Online   content
Loc: ROCHESTER, NY
Cranking Amps(CA) is at 32 degrees F
Cold Cranking Amps(CCA) is at 0 degrees F
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4677393 - 02/25/18 09:12 AM Re: Cold Cranking ? [Re: Ndx]
mk378 Online   content
Loc: USA
580 amps by DIN method, 950 by SAE method.
Both tests are conducted at -18 C (0 F). The DIN test requires the battery voltage to stay above 9.0 volts for the first 30 seconds of draw of the rated current, and above 6.0 volts for 150 seconds.
The SAE test is only the first 30 seconds, and also allows the battery voltage to drop to 7.2 volts during the 30 seconds. Thus when doing both tests on the same battery, the SAE rating will be a higher number. Current technology means that most batteries will reach a SAE rating about 1.5 times the DIN.
Edited by mk378 (02/25/18 09:21 AM)
