WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
27 registered members (CB900F2, BlakeB, 53' Stude, Ablebody, earlyre, 3 invisible), 767 guests, and 40 spiders.
Topics290,746
Posts4,849,466
Members66,033
Most Online3,590
Jan 24th, 2017
What could cause this paint chips #4676774
02/24/18 06:30 PM
02/24/18 06:30 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
I noticed all these chips when rotating my tires today for the vibration concern I posted earlier. I hate to be "that guy"
But this was the side I had the rocker panel fixed and they sectioned it from right above this area to Midway under the car (between the doors)
The other side doesn't have these types of chips. This job was done 7 months ago. The car doesn't see any gravel roads only thing it really see is as Highway and it's Missouri so we do have the salt and Cinders on the road this time of year but still I wouldn't think it would look this bad and it's all the way down to the primer on every chip you see how would you guys handle this what would cause this what do you think?
2014 dodge dart GT
1995 Dodge ram 1500
Re: What could cause this paint chips [Re: ram_man] #4676786
02/24/18 06:46 PM
02/24/18 06:46 PM
WI
HoosierJeeper Offline
WI
If it's the passenger side, that side always seems to get blasted more due to stuff running down the crown of the road.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: What could cause this paint chips [Re: ram_man] #4676790
02/24/18 06:50 PM
02/24/18 06:50 PM
Northern Ontario, Canada
Danno Offline
Danno  Offline
Leading edges always take more abuse from road debris, pretty common imo. Looks like the door is too far inset to protect that leading edge, therefore paint chips .
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: What could cause this paint chips [Re: ram_man] #4676793
02/24/18 06:51 PM
02/24/18 06:51 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
That's probably true. But my wife has the same car with more miles than my entire car much less the paint job and it doesn't look like that.
2014 dodge dart GT
1995 Dodge ram 1500
Re: What could cause this paint chips [Re: Danno] #4676796
02/24/18 06:53 PM
02/24/18 06:53 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
Picture angle kind of makes it look like that but in person it's flush. I took the picture kind of cockeyed because it was raining really hard and I did want to kneel on the ground
2014 dodge dart GT
1995 Dodge ram 1500
Re: What could cause this paint chips [Re: ram_man] #4676816
02/24/18 07:16 PM
02/24/18 07:16 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Could be, but if this is replacement paint on a section that couldn't be hot baked on, it may be softer.
My understanding, could be wrong, is that if a replacement panel (hood, trunk, hatch, door) gets painted, it's done then baked at high heat. Maybe not factory hot, but hot all the same.
If the body structure gets painted, to prevent damage to plastics, rubbers, seals, etc., its baked much lower.
Re: What could cause this paint chips [Re: ram_man] #4676825
02/24/18 07:27 PM
02/24/18 07:27 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
If I took it to them what should I reasonably expect them to do? I dont want to be out of line but I also want the paint to be right as well.
2014 dodge dart GT
1995 Dodge ram 1500
Re: What could cause this paint chips [Re: JHZR2] #4676843
02/24/18 07:42 PM
02/24/18 07:42 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Also depends on the shop. Some don't have a bake booth at all. That paint chips REALLY easily, I know from experience. The difference between a properly baked paint job that's designed to mirror OEM hardness and one that isn't is significant.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: What could cause this paint chips [Re: OVERKILL] #4676854
02/24/18 07:55 PM
02/24/18 07:55 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
Would you expect this though so bad so soon? Would you say anything ?
2014 dodge dart GT
1995 Dodge ram 1500
Re: What could cause this paint chips [Re: ram_man] #4676868
02/24/18 08:17 PM
02/24/18 08:17 PM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
The shop should have a warranty, top tier shops have life time warranties.
And the whole repair/repaint vs. OEM paint, repaint will Never be as durable as OEM, due to the bake process. 180 degree's OEM, vs. 140 degree's if a repair facility even bakes it at all. Rocker panel= No bake!
Also, the problem could easily be a bad prep, paint process. I can't tell from here. Take it back to the shop, and try to be professional about it, hopefully they will be also.
08 Tribeca 82k PUP 5w30 wix
06 Accord Hybrid 131k PUP 5w20 wix
02 Chevy k3500 97k Delvac 1 esp 5w40 wix
00 F350 133k Delvac 1300 15w40 wix
Re: What could cause this paint chips [Re: ram_man] #4676941
02/24/18 09:19 PM
02/24/18 09:19 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
I would expect it on soft paint if you are regularly seeing small road debris like tiny stones getting kicked up that wouldn't necessarily chip OEM paint.
Maybe talk to the shop, ask them if they use a bake booth? And ask them about the chips?
Re: What could cause this paint chips [Re: ram_man] #4676943
02/24/18 09:27 PM
02/24/18 09:27 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
Plastic panels painted without a "plastic bonding" primer perhaps. Or paint without a flexible additive.
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: What could cause this paint chips [Re: ram_man] #4677014
02/24/18 10:29 PM
02/24/18 10:29 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I had a car with paint chips that had been repaired by a large shop. They wouldn’t cover it, their warranty only covers peeling paint, not rock chips.
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: What could cause this paint chips [Re: Nick1994] #4677138
02/25/18 12:41 AM
02/25/18 12:41 AM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
This is kind of what I'm afraid of and I understand that rock chips happen but that seems like an awful lot in a short amount of time especially when the other side doesn't exhibit the same look at all my concern isn't really the chips but it's how bad will it get in years not months
2014 dodge dart GT
1995 Dodge ram 1500
Re: What could cause this paint chips [Re: ram_man] #4677188
02/25/18 03:22 AM
02/25/18 03:22 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
To the OP... Go to the dealer and ask him if he can order those for your car...
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
