Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
81 registered members (aquariuscsm, alarmguy, avi1777, Back40, Astro_Guy, arowbat, 9 invisible), 935 guests, and 50 spiders.
Topics286,106
Posts4,902,697
Members67,563
Most Online2,967
Mar 10th, 2019
18 yo roof,roof vent and repair #4676570
02/24/18 03:17 PM
02/24/18 03:17 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
i was helping my cousin do some stuff . we went into the attic and we noticed the osb where the dryer roof vent is rotten. don't know how long its been like that.
So his house is 18 yo and the original composite roof. he is thinking of just fixing that area and i suggested just getting a reroof as the roof is probably at the end of its life. Also, we would like to figure out why that area rotted. his house is 2 stories and the vent is way of top because his W/D is on the second floor .
So how long do composite roof usually last. better to just replace whole roof than a repair ?
Re: 18 yo roof,roof vent and repair [Re: WhyMe] #4676591
02/24/18 03:34 PM
02/24/18 03:34 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Without pictures I would guess the humidity coming from the vent caused the wood to rot. And maybe use composite wood to replace the rotted wood is a good idea. Replace the whole roof....that's a decision your cousin will have to make.
Re: 18 yo roof,roof vent and repair [Re: WhyMe] #4676593
02/24/18 03:36 PM
02/24/18 03:36 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Depends on the quality and weight of the roofing material they can run anywhere from 15 to 30 plus years.
But my guess is he will replace that roof this summer if he's smart.
2004 Corolla 129932
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 18 yo roof,roof vent and repair [Re: WhyMe] #4676668
02/24/18 04:31 PM
02/24/18 04:31 PM
PimTac Offline
PimTac  Offline
I would reroute that dryer vent out the side instead of out the roof. I’ll bet the duct is plugged full of lint too. As for the roof, get on top and check the shingles. He may have a few years left which would give him a chance to save up.
Cannot see signatures any longer so it doesn’t matter.
Re: 18 yo roof,roof vent and repair [Re: WhyMe] #4676674
02/24/18 04:38 PM
02/24/18 04:38 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Was the osb black with mold or actually crumbling away? Maybe the vent was improperly installed, or the vent is leaking humid air into that vent. You'll have to inspect the roof.
Depending on how bad the roof is you may be able to repair the area, or maybe you can just replace that section of shingles on that roof.
Usually southern roof exposures will deteriorate fastest.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 18 yo roof,roof vent and repair [Re: WhyMe] #4676676
02/24/18 04:41 PM
02/24/18 04:41 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
You sure it isn't the bathroom vent ?
Re: 18 yo roof,roof vent and repair [Re: JC1] #4676724
02/24/18 05:21 PM
02/24/18 05:21 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
both. there is black mold and its soft and crumbly. its not a small area, 2x2 feet . its the dryer vent for sure. can't see the vent from the outside unless we hop into the neighbors yard due to the angle.
he has a guy coming next week to look at it. i bet he is going to tell him to replace the roof.
Re: 18 yo roof,roof vent and repair [Re: WhyMe] #4676764
02/24/18 06:13 PM
02/24/18 06:13 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
At 18 yrs old, the roof is only 1/2 worn out. Is the roof pitched low enough to move around on safely? As roofs go, 2'x2' is a small area. Also it may be larger because you want to cut the OSB in the middle of a rafter. Splurge on a full sheet or have a big box store cut you the exact size you need. If they will sell you some tar paper and/or ice and water shield by the foot that would be awesome. Use a hammer and a catspaw to remove nails etc.A wall paper scraper makes a great tool to separate the tar dots. How are the shingles attached? Nails or staples? Try to remove the shingles intact. Push comes to shove, you may have to buy a bundle. Slide the paper underneath at the top and sides on top at the bottom Figure out what is up with the drier vent. If they are restricted, they create condensation in addition to wasted energy etc. Even expensive metal duct is lousy for dealing with lint. The ducts need at least yearly cleaning.
Thick oil is better grin2
Re: 18 yo roof,roof vent and repair [Re: WhyMe] #4679679
02/27/18 01:58 PM
02/27/18 01:58 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Use Ice & Water shield on all areas that needs flashing and valleys.
This type of material is not available 18 years ago.
If he decides to replace the roof, ask to use the Ice&Water shield also in addition to metal flashing and metal parts for anything coming out through the roof.
In theory roof should last 20-30 years for 30 years roof.
But if there is water seeping, something has failed so the age of the roof is determined by what failed first not just the roof materials.
  • 2017 Toyota Sienna
Re: 18 yo roof,roof vent and repair [Re: WhyMe] #4679686
02/27/18 02:08 PM
02/27/18 02:08 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
I would also expect a roof in that part of the country to last a lot longer than 18 years, unless there is install issues, or really cheap materials (absolutely possible on any house built new).
Re: 18 yo roof,roof vent and repair [Re: WhyMe] #4679735
02/27/18 03:07 PM
02/27/18 03:07 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
got a roofing company coming on friday. will update you guys on what he says .
Re: 18 yo roof,roof vent and repair [Re: WhyMe] #4685536
03/05/18 08:18 PM
03/05/18 08:18 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
update :
2 roofers came ams took a look at the roof. the one side where the vent is is pretty worn and they suggest replacement. one is a GLA rep and the other pabco and certainteed.
the work looks pretty close as is the warranty. the difference is the price. they is 5-7k difference depending on what grade of shingle is chosen.
thats quite a bit of difference. So are pabco stuff any good?
