Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
38 registered (alarmguy, billt460, bradepb, BoiseBound, bullwinkle, crazy_raccoon, 6 invisible), 957 Guests and 36 Spiders online.
65282 Members
67 Forums
285683 Topics
Page 1 of 2 1 2 >
#4676557 - 02/24/18 02:00 PM what would you do / expect
ram_man Offline
Loc: southern mo
ok so as many of you know I have had a fair amount of issues with tire vibrations.
1 few months back I bought a set of sumitomo htr p02 225/40r18. I had zero vibrations drove all the way to Colorado without an issue. I rotated them for the first time the other day front to back and back to front. and had a vibration at highway speeds 70-75mph I didn't go any faster than that. I had them re balanced today by NTB which is where I bought them. they feel better but still do vibrate enough to move the steering wheel. Without giving me a bad attitude what would you do? when I came home I swapped wheels with the other dart and with her tires and wheels i had no vibration. So its in the wheel tire combo like it has been every time in the past. is it possible this car is very particular with tire run out? is there any manufacturer with stricter run out variation than others.
How would you go about solving this issue once and for all?
2014 dodge dart GT "mine"
2013 Dodge Dart limited "hers"
1995 Dodge ram 1500
#4676559 - 02/24/18 02:04 PM Re: what would you do / expect [Re: ram_man]
SatinSilver Offline
Loc: OH
Go back to NTB and tell them the issue that you just described. Hopefully they'll put one or two new tires on it. Let them take care of it. Talk to the store manager from the beginning since they have the most authorization for new tires. A service advisor will first try to give you the run around to get rid of you.
#4676573 - 02/24/18 02:19 PM Re: what would you do / expect [Re: ram_man]
DuckRyder Offline
Loc: Atlanta
Well, it seems from what you have said that it is more than likely one of the front tires. I would have NTB road force the two front tires and see what they were and if they could be reduced. If anyone said the words “in spec” I’d ask to talk to someone with a clue preferably a supervisor with a clue, but that can be a rare combination.
It could be worse:
IME Yokohama is usually quite uniform and recently had very good luck with BFG and Mich Premier.
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
#4676611 - 02/24/18 02:49 PM Re: what would you do / expect [Re: ram_man]
Nick1994 Offline
Loc: Phoenix, AZ
Are these OEM wheels?
Rotate the left side. Any vibrations? If not, rotate the right side. Any vibrations? If so then there's your problem wheel.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4676618 - 02/24/18 02:53 PM Re: what would you do / expect [Re: ram_man]
Warstud Offline
Loc: MIchigan
Was this car in an accident?
#4676622 - 02/24/18 02:56 PM Re: what would you do / expect [Re: ram_man]
edwardh1 Offline
Loc: Coastal South Carolina
many shops that have road force machines dont use that feature.
Edited by edwardh1 (02/24/18 02:56 PM)
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
#4676625 - 02/24/18 02:59 PM Re: what would you do / expect [Re: ram_man]
ram_man Offline
Loc: southern mo
Oem wheels yes. And car has never been in an accident. The rocker panel had to be fixed it was hit with a curb but that's not relevant to this I don't think.
Edited by ram_man (02/24/18 03:08 PM)
1995 Dodge ram 1500
#4676685 - 02/24/18 03:50 PM Re: what would you do / expect [Re: ram_man]
skyactiv Offline
Loc: The Midwest
Maybe you have bent wheel(s)?
Me: 13' VW GTI 3 door 6 speed manual
#4676701 - 02/24/18 04:04 PM Re: what would you do / expect [Re: ram_man]
JHZR2 Offline
Loc: New Jersey
If the rocker hit a curb I'd guess that a wheel could have too. Bent wheel would result.
Swap the two sides independently and determine the guilty wheel. Do more diagnostics from there.
#4676766 - 02/24/18 05:21 PM Re: what would you do / expect [Re: JHZR2]
ram_man Offline
Loc: southern mo
wheel never touched the curb it was a freak deal turned to sharp out of a parking spot forgetting the curb was there and caught it. As soon as I heard it scrape I stopped. Was doing 1mph.
I swapped left side and had no change and the. Swapped right and vibration is gone steering wheel is smooth. That's also the wheel with the most weight on it.
1995 Dodge ram 1500
#4676818 - 02/24/18 06:18 PM Re: what would you do / expect [Re: ram_man]
JHZR2 Offline
Loc: New Jersey
Well you know what it is, how much is a refinished one on eBay or elsewhere?
Ive generally found new OE to be around $400; refinished about half that.
#4676824 - 02/24/18 06:24 PM Re: what would you do / expect [Re: ram_man]
ram_man Offline
Loc: southern mo
It's around $600 new. I really doubt it's the wheel I've had this issue so much with various tires. I'm almost certain it's a tire issue like usual.
I wonder what happens if they dont have the tire in stock....I didn't see it on their website.
1995 Dodge ram 1500
#4676856 - 02/24/18 06:56 PM Re: what would you do / expect [Re: ram_man]
dan_erickson Offline
Loc: Crown Point, IN
You have a bent wheel. When the wheel is on the back on the car you will not feel the vibration in the steering wheel.
15 Accord Coupe EX-L V6 Navi
Castrol Magnatec 0w20
#4676862 - 02/24/18 07:04 PM Re: what would you do / expect [Re: ram_man]
ram_man Offline
Loc: southern mo
But this issue has happened before. the exact issue and it's always been tires. Needless to say I'm skeptical of a bent wheel.. because of all the tire issues I've had. a tire out balance on the rear wouldn't be as noticable or at all either.
1995 Dodge ram 1500
#4676875 - 02/24/18 07:24 PM Re: what would you do / expect [Re: ram_man]
tomcat27 Offline
Loc: Chicago, IL
start with a re-balance. make sure they use the road force balancer if they have one. My local DT has one but does not use it unless they "have to"
2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Page 1 of 2 1 2 >
