Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Easter Sunday
by gman2304. 04/21/19 10:17 AM
Old Buick Century Question
by GrtArtiste. 04/21/19 10:03 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
98 registered members (andyd, alphadog, 53' Stude, 2015_PSD, 240_Ed, AdditiveOCD, 12 invisible), 1,877 guests, and 25 spiders.
Topics287,853
Posts4,935,596
Members67,865
Most Online2,967
Mar 10th, 2019
4l60e broken bolts #4676555
02/24/18 03:00 PM
02/24/18 03:00 PM
out there
spasm3 Offline OP
spasm3  Offline OP
out there
Took off the trans pan and broke 4 bolts! What is the easiest way to get them out?
I don't really want to have to mig a nut on upside down and near the aluminum pan rail. I did not realize the bolts that broke may have been exposed on the backside and had corrosion.
Hoping clinebarger reads this!
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: 4l60e broken bolts [Re: spasm3] #4676571
02/24/18 03:18 PM
02/24/18 03:18 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Drill the centers and use a bolt extractor kit. Spray them with your favorite liquid wrench or equivant fluid and let them soak overnght first.
If you want the job done right......do it yourself.
Re: 4l60e broken bolts [Re: spasm3] #4676647
02/24/18 04:13 PM
02/24/18 04:13 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
A broken bolt is a broken bolt, it doesn't matter if its on a transmission or a lawnmower. Center punch the broken bolt and drill a small diameter hole through the center of it (center punch it first and drill straight) then work up the sizes until its almost gone then use an easy out (not the coarse spiral kind fine thread is ok).
LH drill bits would be the best option but even without its not a big deal as they are straight through not a blind hole, I do this almost daily. These are not hardened bolts and drill out easy.
Do not use these.
These are okay.
Don't use the ones you have to hammer in the pan flange is a little fragile. You can use them but it takes a bit of experience to know how hard you can hit it.
Re: 4l60e broken bolts [Re: spasm3] #4676699
02/24/18 05:01 PM
02/24/18 05:01 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
Use a wire brush to de-rust the bolt tips. Then hit them with penetrating oil. If the threads are exposed on the sheared side, give them a tap with a hammer. Then if you can get a bite with vise grips, tighten the bolt just a spec. If you have the purchase to tighten, the bolt, it should back out.
My plan B is tried and true, but slow. Go buy some 1/8 bits. Easiest way to make sure you're working with a sharp bit. If you can center punch do so. Center punching the exact ctr ,isn't easy. I have found that it doesn't need to be perfect. The object is to remove the center of the bolt and not the threads. Chances are, the next pass with a 3/16 bit will do the trick. OK I'm guessing a 6 or 8 mm ( 1/4 -5/16) If the bolt is a 1/4, try a 7/32. For a 5/16, run in a 1/4" bit. If you see threads, quit, if not, go to 9/32 Next use a small screwdriver to dig what little metal is left away from the threads. By the 4th bolt you should be good at this.
Well intentioned people will urge you to use an EZ out. I urge you to be patient and deft. grin2
Thick oil is better grin2
Re: 4l60e broken bolts [Re: andyd] #4676747
02/24/18 05:47 PM
02/24/18 05:47 PM
Trav Offline
Trav  Offline
Well intentioned person here and also a pro. You need to be pretty good with a hand drill to drill a hole on your back under the car accurately enough to pick the threads out, drill press not a problem.
An easy out is fine if there is very little left and you don't use a lot of force. I agree if there is enough left to get vise grips on then sure give it a go but I assume the OP is smart enough to know that if he is changing transmission filters.
Re: 4l60e broken bolts [Re: spasm3] #4676808
02/24/18 07:11 PM
02/24/18 07:11 PM
Marshfield , MA
Marshfield , MA
Thank you sir. My eyesight is bad. I'm too cheep to use the proper EZ out. My record is 1 for 3 with the cheap ones. 2 major fails. Enough for a reptilian brain triggered flight response. When a bolt breaks it really rips and leaves a high spot. Try holding a punch on that, Blindo. To start a pilot hole, I just need a spot where I can get drill to stay put without snapping it. As the drill goes in, I gradually work it plumb and straight. as it hogs out material. 25 yrs ago, I replaced the wye pipe on a Jeep V-8. I sheared 3 outta 4 exhaust studs. I drilled them out and re-tapped in place with a hand held 3/8 drill. Once there is a 1/4" hole in the center It doesn't take much to move the remaining bolt toward the center. I learned that drilling out broken '66 Bug ball joints ages ago. I just got better from there grin2
Re: 4l60e broken bolts [Re: spasm3] #4676821
02/24/18 07:21 PM
02/24/18 07:21 PM
San Antonio, TX
das_peikko Online content
das_peikko  Online Content
San Antonio, TX
The PROTO kind are the best. They will work beautifully if you take the time to do the research.
Those pan bolts are M6 x 1.00
Re: 4l60e broken bolts [Re: das_peikko] #4676827
02/24/18 07:29 PM
02/24/18 07:29 PM
Trav Offline
Trav  Offline
They are good, the spline type is also good the only drawback is they need to be hammered in. If you have experience it not a real issue but the aluminum flange on the transmission is easily broken in you start beating on it hard enough. Break or crack that and you have a big problem.
2cents
Re: 4l60e broken bolts [Re: spasm3] #4676832
02/24/18 07:32 PM
02/24/18 07:32 PM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
If you decide to break out the drill, look into getting some left hand drill bits. If you're going to be drilling it, may as well drill it the right direction. smile
Sometimes the bits will bite hard enough to start turning the bolt, especially as you start stepping up in size. My experience, FWIW.
Re: 4l60e broken bolts [Re: spasm3] #4676858
02/24/18 07:58 PM
02/24/18 07:58 PM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
you can cut a slot with a dremel and remove with screwdriver.
Re: 4l60e broken bolts [Re: spasm3] #4676931
02/24/18 09:05 PM
02/24/18 09:05 PM
out there
spasm3 Offline OP
spasm3  Offline OP
out there
Thanks guys, guess i will break out the drill.
Thanks Trav. I have larger fluted extractors, i've used them before, but i was worried about whapping on the aluminum pan rail.
I saw a norseman extractor set but its not fine thread like you suggested.
https://www.amazon.com/Norseman-Screw-Re...seman+extractor
Re: 4l60e broken bolts [Re: spasm3] #4676966
02/24/18 09:52 PM
02/24/18 09:52 PM
Trav Offline
Trav  Offline
If you get most of it drilled out they should work okay, use a tap wrench on it. The fine threaded ones have more meat because of the shallower flutes so they are a bit stronger and they get more flutes in the broken bolt.
Like all of them except spline type they have a tendency to jam the broken part tighter in the hole as they act like a wedge if you really go to town tightening them.
Easy outs are generally better suited to removing broken bolts that broke installing not ones that broke removing due to corrosion.
If the broken bolt is slightly proud of the flange but not enough to get grips on and not flat grind it flat with a dremel or similar or a file making it easier to center punch.
Re: 4l60e broken bolts [Re: spasm3] #4677050
02/24/18 10:55 PM
02/24/18 10:55 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Like Trav said.....A broken bolt is a broken bolt! Though I have great luck welding a nut to the stud & extracting it.
Just a word of caution about the two front bolt holes directly under the pump......DO NOT bottom a ease out/extractor OR a Tap into the pump sealing flange!!!! It is very thin & easy to distort.
This also applies to using to long of a replacement bolt!
2001 Chevy Camaro L92/4L80E
Re: 4l60e broken bolts [Re: spasm3] #4677056
02/24/18 10:59 PM
02/24/18 10:59 PM
out there
spasm3 Offline OP
spasm3  Offline OP
out there
WOW thanks for that ! I don't remember off hand which bolts are broken, but i think they were on the corners.
Re: 4l60e broken bolts [Re: spasm3] #4677202
02/25/18 04:50 AM
02/25/18 04:50 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
I love threads where Trav and clinebarger share their experience.
