'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
25 registered members (ChrisD46, dlundblad, aba4430, Bailes1992, earlyre, 3 invisible), 298 guests, and 46 spiders.
Topics286,049
Posts4,901,477
Members67,551
Most Online2,967
Mar 10th, 2019
Best Ring and Pinion and Why? #4676529
02/24/18 02:39 PM
02/24/18 02:39 PM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
I have a 2000 F150 4x2,ext cab,4.6 V8, Auto Trans, 3.55 locker (factory gear) 8.8 axle.
Tire size - 245/70r16 106t
The only performance related thing I've done to my truck.
1) True dual exhaust with Borla mufflers. I still have all 4 cats on my truck.
__________________________________________________ ____________
The general consensus with a lot of people on here say the DiabloSport Predator 2 Performance Tuner 7102 is a "waste" of money!
Ok....so which ring and pinion would you say is the best choice,and WHY?
3.73 ring and pinion ?
3.90 ring and pinion ?
4.10 ring and pinion ?
Most of my driving is in town driving,and I get on the interstate about 1 time every month and travel 3 hrs round trip.
I do tow a 1,800 lb utility trailer 3-4 times per week in town.
Re: Best Ring and Pinion and Why? [Re: lawnguy] #4676531
02/24/18 02:43 PM
02/24/18 02:43 PM
Cincinnati
donnyj08 Offline
donnyj08  Offline
Cincinnati
Keep the 3:55. You're not towing any real weight and that truck will never be truly fast.
2008 Silverado Z71 LT 90k Maxlife FS 5w30
2010 Ford Escape 172k QSUD 5w20
2016 Yamaha XSR900 12k, Rotella 15w40 Yamaha Filter.
Re: Best Ring and Pinion and Why? [Re: lawnguy] #4676535
02/24/18 02:47 PM
02/24/18 02:47 PM
New England
gathermewool Offline
New England
I agree - stick with what you got.
Not to suck the jelly out of your donut, but that Borla exhaust likely isn't giving you any more performance, if it's just a cat-back.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Best Ring and Pinion and Why? [Re: lawnguy] #4676545
02/24/18 02:51 PM
02/24/18 02:51 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Making your slow truck loud is dumb.
That truck will be slow no matter what you do. If you want a fast old truck and aren't a "Ford guy", it's hard to beat a Chevy/GMC with a 6.0.
Me: 13' VW GTI 3 door 6 speed manual
Re: Best Ring and Pinion and Why? [Re: skyactiv] #4676549
02/24/18 02:54 PM
02/24/18 02:54 PM
South Carolina
eyeofthetiger Offline
South Carolina
Slow things are allowed to sound good, too. The 4.6 V8 sounds [censored] good.
I'd put 4.10 gears in it since you don't do much highway. I'd also like doing the work myself.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Best Ring and Pinion and Why? [Re: lawnguy] #4676568
02/24/18 03:14 PM
02/24/18 03:14 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
I would be helpful if you put some meaningful info in the thread title, please.
Thanks.
2004 Prius; 110K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Best Ring and Pinion and Why? [Re: eyeofthetiger] #4676602
02/24/18 03:43 PM
02/24/18 03:43 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I'll echo this.....
Though I will say, It's pretty hard to get the pinion depth Just Right (shimmed) without a special tool.
It can be done - it's just a little time consuming doing it by "trial-and error".
The shims go between the pinion gear and rear pinion bearing, which is pressed on.
Pulling the bearing off with a bearing puller usually destroys it.
Re: Best Ring and Pinion and Why? [Re: lawnguy] #4676613
02/24/18 03:50 PM
02/24/18 03:50 PM
NH
supton Offline
supton  Offline
NH
Didn't this get hashed out already?
I'd think the performance change from 3.55 to 3.73 would be negligible, and not worth the cost. not unless if it was swapping the whole axle for pennies.
4.10 might be annoying for highway, but sure would put some snap into it for around town, off the line.
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 146k, ours
1999 Toyota Camry LE, 2.2L/4AT, 202k, his
Re: Best Ring and Pinion and Why? [Re: lawnguy] #4676706
02/24/18 05:07 PM
02/24/18 05:07 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
If you are [censored] bent on spending the money, get the 4.10's.
2016 Grand Cherokee SRT - Castrol Edge 0w-40, FRAM Ultra
Re: Best Ring and Pinion and Why? [Re: skyactiv] #4676707
02/24/18 05:08 PM
02/24/18 05:08 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Or a Lightning, or a Harley, both of which I've already suggested to him.
Re: Best Ring and Pinion and Why? [Re: OVERKILL] #4676738
02/24/18 05:36 PM
02/24/18 05:36 PM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
Why 4.10 ?
Re: Best Ring and Pinion and Why? [Re: lawnguy] #4676743
02/24/18 05:42 PM
02/24/18 05:42 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Why 4.10 ?
Because it will make the biggest difference, and since this isn't going to be cheap, you might as well get the most out of your dollar.
Re: Best Ring and Pinion and Why? [Re: OVERKILL] #4676775
02/24/18 06:31 PM
02/24/18 06:31 PM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
So it will make a bigger difference than a 20hp performance programmer for $350?
Why 4.10 ?
Re: Best Ring and Pinion and Why? [Re: lawnguy] #4676778
02/24/18 06:33 PM
02/24/18 06:33 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Why 4.10 ?
Do you honestly think a non-PI 4.6L is going to gain 20HP from a tuner? If Ford could have, they would have gone that route rather than spending significantly more money on developing the PI heads and cams.
Re: Best Ring and Pinion and Why? [Re: lawnguy] #4676807
02/24/18 07:09 PM
02/24/18 07:09 PM
New England
New England
Tuning can sometimes garner gains like that. Tuners aren't concerned with emissions standards, so they can play more with fueling and timing, without that constraint.
