Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
3 minutes 2 seconds ago
Ruger LCP .380
by PW01
Yesterday at 11:24 PM
Launching boat with stick shift
by troutfisher
Yesterday at 11:22 PM
Free oil
by Spitter
Yesterday at 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
Yesterday at 10:04 PM
RC cars
by red7404
Yesterday at 09:36 PM
Any Good 4K Movies ?
by Warstud
Yesterday at 09:06 PM
Gray on Oil Dipstick?
by chinee
Yesterday at 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
Yesterday at 08:15 PM
Parking wars show.
by Chris142
set for years
by 93cruiser
Yesterday at 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
Yesterday at 07:26 PM
Trying to fix chainsaw
by turtlevette
Yesterday at 06:48 PM
tire rotation
by marine65
Reese hitch $30 Walmart YMMV
by pda1122
Yesterday at 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
2016 Honda Pilot appears to be consuming oil
by pilot1226
Yesterday at 06:00 PM
New belt squeal cause damage to belt?
by pda1122
Yesterday at 05:33 PM
Food Safety - If You Have Children
by Zee09
Yesterday at 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
Yesterday at 05:02 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
60 registered (boulderdentist, 4WD, bdcardinal, AZjeff, Ag76, 3 invisible), 1056 Guests and 30 Spiders online.
65303 Members
67 Forums
285886 Topics
#4676464 - 02/24/18 12:27 PM To Oil or Not To Oil My Foam Prefilter???
Gebo Offline
Loc: VA
I have a Honda 20 hp 2 cylinder engine. It has a paper element and a black foam element that is the prefilter. Am I supposed to just wash off the black foam filter to get the junk off/out of it and then reinstall? Or am I to wash, dry and then apply a small amount of oil? IF I am supposed to oil it, does it matter about the oil?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
#4676477 - 02/24/18 12:44 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: Gebo]
oldhp Offline
Loc: USA
I had a JD lawn tractor that used a foam pre-filter. Every fall I would wash it with Dawn, then give it a small dime size dab of Marvel Mystery Oil. I worked the MMO in until it was all even in the foam. I cleaned it again one more time and then when I put it away for winter. Never had a problem.
#4676506 - 02/24/18 01:07 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: Gebo]
Linctex Offline
Loc: Waco, TX
A non-detergent 30W mineral oil is best for this, as it will not attack the foam.
Use the oil VERY sparingly - its supposed to be a light film on the pores - NONE of the pores should be filled with oil anywhere!
Massage it until all oil is spread very evenly.
#4676510 - 02/24/18 01:14 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: Gebo]
Gebo Offline
Loc: VA
The reason I asked this question was years ago my paper element looked clean but was actually clogged. We are assuming it was from my over oiling. It was suggested that I shouldn't apply oil to a foam prefilter as it may end up releasing some of the oil into the paper element thereby clogging it up. That is the point of my question. From what y'all are saying, it appears we are to apply oil but very, very sparingly. Is this correct?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
#4676514 - 02/24/18 01:20 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: Gebo]
JeepWJ19 Offline
Loc: PENNSYLVANIA
Call the filter manufacturer and ask if it's supposed to be oiled?
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
#4676528 - 02/24/18 01:38 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: Gebo]
gathermewool Offline
What does the manual say? My Cub Cadet manual says that the foam pre-filter should NOT be oiled.
#4676609 - 02/24/18 02:48 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: Gebo]
Warstud Offline
Loc: MIchigan
Usually a Pre-Filter is used to capture large particles.... so I would say it probably doesn't require oil.
#4676673 - 02/24/18 03:38 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: Gebo]
Happy Birthday toneydoc Offline
Loc: War Eagle
I think I would clean it of all debris, wash it in gentle soap and let dry and then reinstall without oil since you have another filter behind it
It is probably there to collect big grass particles, etc
1994 Jeep 158k Mobil 5000 5w30
2014 Camry 32k QS AD 5w30
2018 Jeep Cherokee 1k factory fill
2014 HD Ultra 35k Mobil1 15w50
2012 Rav4 35k PP 5w20
#4676710 - 02/24/18 04:10 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: Gebo]
boraticus Offline
Loc: Canada
With paper filters the foam element isn't supposed to be oiled. Blow both elements out with compressed air, put them back in and go to work.
#4676811 - 02/24/18 06:12 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: Gebo]
I've never gotten into blowing out filters with compressed air. Do you blow the dirty side or from the clean side through the filter? If the former, you'll get the large bits out, but likely push fine particulates further into the media. You could also damage the media.
I've always simply vacuumed out filters like this. You'll get most of the junk out a little more gently.
#4676902 - 02/24/18 07:47 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: gathermewool]
boraticus Offline
Loc: Canada
Blow from the clean side to blow the dirt collected on the opposite side off. Been doing it for years. Just don't use 200 lbs. of air pressure. Forty to fifty lbs. is enough to get the job done without damaging the element.
#4676981 - 02/24/18 09:05 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: boraticus]
Does a better job than vacuuming with a shop vac and slim accessory?
#4677018 - 02/24/18 09:30 PM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: Gebo]
AMC Offline
Loc: South Eastern, CT
If the pre-filter sits on a mesh frame of some sort, oil it. If the pre-filter sits directly on the paper, do not oil it. The oil can soften the paper and ruin it, which you do not want.
My Kawasaki engine has the same filter setup with a foam pre-filter, sitting in front of a paper main filter. I oil the foam then squeeze out all the excess and re-install. Works great, every time.
11 Chevy Silverado - PP 5w-30
10 Ford Focus - QSAD 5w-20
14 Yamaha Super Tenere - Delo 15w-40
#4677414 - 02/25/18 09:37 AM Re: To Oil or Not To Oil My Foam Prefilter??? [Re: gathermewool]
boraticus Offline
Loc: Canada
Beats me.
I've never used a shop vac to clean a paper air filter. Compressed air only. Been doing it for decades.
I doubt there would be much difference provided the shop vac has the power to pull air through the paper to dislodge finer particles.
