Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
102 registered members (Aichiguy, 2015_PSD, 69Torino, Ag76, 2012AccentSE, addyguy, 13 invisible), 1,777 guests, and 51 spiders.
Topics286,112
Posts4,902,865
Members67,565
Most Online2,967
Mar 10th, 2019
Mazda 2.3 spark plugs w/ 2 cycle oil 68k miles #4676458
02/24/18 01:22 PM
02/24/18 01:22 PM
FL
CharlieJ Offline OP
CharlieJ  Offline OP
FL
These are the OEM spark plugs from my 2007 Mazda 3 with 2.3l engine. The plugs have 68k miles with the last 45k miles using 2 cycle oil in the gas at approximately 1oz per 5 gallons, usually a little more. Look pretty good to me, gap was exact across all 4 at .050. I hope this debunks the internet myth that 2 cycle oil in a 4 cycle engine causes fouling or excessive carbon buildup. 2 cycle oil used is Pennzoil Marine XLF synthetic blend. Replaced with NGK IX 4344, LTR5IX-11, gapped to .040.
'07 Mazda3 2.3 Mobil 1 HM 5w-30
'84 Mazda Rx-7 Valvoline Maxlife 10w-30
Re: Mazda 2.3 spark plugs w/ 2 cycle oil 68k miles [Re: CharlieJ] #4676481
02/24/18 01:46 PM
02/24/18 01:46 PM
USA
oldhp Offline
oldhp  Offline
USA
They look good to me.......I might have run'em 30K longer.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Mazda 2.3 spark plugs w/ 2 cycle oil 68k miles [Re: oldhp] #4676487
02/24/18 01:48 PM
02/24/18 01:48 PM
wv
krismoriah72 Offline
wv
There was a guy on here that showed his piston tops on his 4 wheeler running the same formula as you and it looked like new.
If u could do a boroscope with the same results..i dont think anyone has done it yet in an auto...
Re: Mazda 2.3 spark plugs w/ 2 cycle oil 68k miles [Re: CharlieJ] #4676500
02/24/18 01:58 PM
02/24/18 01:58 PM
Florida
Artem Offline
Artem  Offline
Florida
And the benefit of the two stroke oil in the fuel is...?
I pre-mix the fuel for my Rotary RX-8 but the engine is designed to burn oil. A regular piston engine doesn't need it.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: Mazda 2.3 spark plugs w/ 2 cycle oil 68k miles [Re: CharlieJ] #4676501
02/24/18 02:00 PM
02/24/18 02:00 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: CharlieJ
using 2 cycle oil in the gas at approximately 1oz per 5 gallons... I hope this debunks the internet myth that 2 cycle oil in a 4 cycle engine causes fouling or excessive carbon buildup
That is such a low rate, you would NEVER EVER foul plugs at that rate
Same here - clean the thread and put them back in again
Re: Mazda 2.3 spark plugs w/ 2 cycle oil 68k miles [Re: oldhp] #4676517
02/24/18 02:23 PM
02/24/18 02:23 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
Yep re-gap, a little anti-seeze, and keep running; nothing wrong with those plugs.
yup
Re: Mazda 2.3 spark plugs w/ 2 cycle oil 68k miles [Re: CharlieJ] #4676901
02/24/18 08:47 PM
02/24/18 08:47 PM
FL
CharlieJ Offline OP
CharlieJ  Offline OP
FL
I know I could have run them longer, but I already bought new plugs; wasnít going to do the job and not replace them. Is running 2 cycle oil necessary? No, it isnít, but the engine does run smoother with it.
I first heard of the idea of doing this from this forum years ago and started premixing oil in the gas and these are the results. Many people have said it would create carbon build up and fouling of plugs even with this small dosage. Hereís my proof that it does not. Take it for what itís worth.
