Re-using building materials esp nails
by andyd
06/18/18 08:57 AM
Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
BITOG using excessive CPU power?
by Kibitoshin
06/18/18 05:10 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
99 registered (Artem, Backwoods41695, billt460, badtlc, AndyB, 4WD, 8 invisible), 1556 Guests and 36 Spiders online.
65262 Members
67 Forums
285515 Topics
#4676423 - 02/24/18 11:53 AM Found Marvel Mystery Oil Gallon For $12.53 @RK
69Torino Offline
Loc: Indy
Awesome. Less than WM. Since I dose 4 cars, a tractor and a bunch of power equipment with MMO in the gas. Lots of stuff on clearance still at my Rural King, including Berryman B12 for $2.03. Your results may vary at your local Rural King. Don't know if the Rural King clearance items are store by store or corporate driven.
Apparently I own too many cars and toys to fit in a signature.
#4676451 - 02/24/18 12:16 PM Re: Found Marvel Mystery Oil Gallon For $12.53 @RK [Re: 69Torino]
tig1 Offline
Loc: Illinois
Thanks, I'll check it out on the MMO. I use that in gas only, at the recommended amount(4 oz per 10 gal of gas).. I can't prove it helps, but I sure can't prove it doesn't. In the 25 years I have used it I haven't had a single fuel related problem.
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4676476 - 02/24/18 12:43 PM Re: Found Marvel Mystery Oil Gallon For $12.53 @RK [Re: 69Torino]
69Torino Offline
Loc: Indy
I personally think top cylinder lube is a good thing, for compression, and I would imagine it should help a fuel pump (in tank) last longer.
#4676498 - 02/24/18 12:55 PM Re: Found Marvel Mystery Oil Gallon For $12.53 @RK [Re: 69Torino]
Linctex Offline
Loc: Waco, TX
I just hope they haven't changed the formula over the last few years.
I thought I read recently that there's no longer any TCP in MMO
If the TCP is gone, there's no reason to buy it anymore.
#4676540 - 02/24/18 01:49 PM Re: Found Marvel Mystery Oil Gallon For $12.53 @RK [Re: 69Torino]
Rick505 Offline
Loc: New Mexico
This is what the SDS directly from their website shows:
3. Information on Ingredients:
3.1 Substance not applicable
3.2 Mixture
Component CAS Number Concentration (wt%)
Petroleum Distillates (Hydrotreated Heavy 64742-52-5 60-100%
Naphthenic)
Petroleum Distillates (Stoddard Solvent) 8052-41-3 10-30%
Tricresyl Phosphate 1330-78-5 0.1-1.0%
Ortho Dichlorobenzene 95-50-1 0.1-1.0%
Para Dichlorobenzene 106-46-7 <0.1%
#4676619 - 02/24/18 02:55 PM Re: Found Marvel Mystery Oil Gallon For $12.53 @RK [Re: tig1]
Rolla07 Offline
Loc: MTL, CANADA
I expect better from you Tig1!! MMO has no purpose in port injected cars. Unless you have a car thats carbureated, why bother? Not being able to prove it doesnt work, isnt a good theory smile We could use premium gas when regular is recommended, use oil additives and in theory you cant prove they have no benefit! I still wont use anything but the once per OCI dose of techron or a product containing PEA.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4677047 - 02/24/18 09:54 PM Re: Found Marvel Mystery Oil Gallon For $12.53 @RK [Re: Rolla07]
tig1 Offline
Loc: Illinois
Like I said" can't prove it works but can't prove it doesn't". No fuel problems is something positive. Right?
M1 0-20 EP
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4677126 - 02/24/18 11:25 PM Re: Found Marvel Mystery Oil Gallon For $12.53 @RK [Re: Rolla07]
Linctex Offline
Loc: Waco, TX
MMO has no purpose in port injected cars. Unless you have a car that's carbureted, why bother?
Not true....
It helps keep intake valves clean when no Top Tier gas is available
It helps keep varnish out of the piston ring grooves and off the skirts.
It's a GREAT upper cylinder lube (I don't use it in summer much, but always in the winter)
#4679087 - 02/26/18 07:06 PM Re: Found Marvel Mystery Oil Gallon For $12.53 @RK [Re: Linctex]
tig1 Offline
Loc: Illinois
Not true....
Also what about PFI? I started driving cars with PFI in 1990 and have never had to touch one using MMO. shrug
M1 0-20 EP
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
