Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
93 registered members (2009Edge, 2015_PSD, bdcardinal, bbhero, ArrestMeRedZ, 13 invisible), 2,128 guests, and 32 spiders.
Topics287,749
Posts4,933,806
Members67,850
Most Online2,967
Mar 10th, 2019
Small Engine Additive Packages TDS please #4676405
02/24/18 12:32 PM
02/24/18 12:32 PM
United Kingdom
OilMonkey Offline OP
United Kingdom
Hi guys/girls,
Does anyone have a link to any TDS's for 4 Stroke additive packages at all?
I believe Infinium/Lubrizol & Afton make motorcycle oil additives but can't see a link to view/download the product data sheets?
These are probably for registered users/customers to view I know, but im just curious about treat rates etc.
If anyone has a copy of one that would be much appreciated!!
Regards
OilMonkey
Re: Small Engine Additive Packages TDS please [Re: OilMonkey] #4676495
02/24/18 01:53 PM
02/24/18 01:53 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Small engine oil lives a very easy life.
If blended specifically for small engines, there will be less additives than a good auto oil.
Re: Small Engine Additive Packages TDS please [Re: OilMonkey] #4676554
02/24/18 02:58 PM
02/24/18 02:58 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
I always tought that 4t OPE oils are just rebranded HDEO diesel oils
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Small Engine Additive Packages TDS please [Re: OilMonkey] #4678504
02/26/18 10:03 AM
02/26/18 10:03 AM
NJ, USA
MotoTribologist Offline
NJ, USA
I don't know of any publicly available sheets out there. The treat rates are generally between 5% - 10% and vary based on a few different criteria:
- Additive company
- Specs it meets (API SG through SN and JASO MB through MA2)
- Additional specs, if any
Less additives than auto oils? Not in my experience. They usually meet the same specs as the auto oils and then some, unless you are referring to friction modifiers; in that case, yes they have less of those.
Same as HDEOs? Some probably are, but there are a lot of specific 4T small engine ones. HDEO DI packages usually have more antioxidant and TBN boosters than 4T engine DI packages at the very least.
Re: Small Engine Additive Packages TDS please [Re: OilMonkey] #4678693
02/26/18 01:40 PM
02/26/18 01:40 PM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
OPE oil is mostly the same auto oil packaged differently.
Thus the price is higher and the profit
margin larger.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Small Engine Additive Packages TDS please [Re: OilMonkey] #4678749
02/26/18 02:48 PM
02/26/18 02:48 PM
NJ, USA
NJ, USA
If they develop the auto oil version and then run the clutch test to verify compatibility with wet clutches, it would make sense to not reinvent the wheel.
However, these companies usually have a lot of auto DI packages to choose from and maybe 1 to 3 4T small engine DI packages. So I think it is safe to assume that if they are rebadging an auto DI package for this use, the ones they pick to do so with are chosen because they are the ones best suited for the application.
Re: Small Engine Additive Packages TDS please [Re: OilMonkey] #4692651
03/12/18 04:56 PM
03/12/18 04:56 PM
United Kingdom
United Kingdom
Thank you for your input guys, I have spoken to Infinium and they have sent me a TDS for one of their 4T Additive Packages suitable for what i'm trying to achieve.
Really appreciate your time. wink
