Transfer case, differential plugs
Ndx
IL
Service manual say replace ...
Can I instead apply some of this ?
https://www.permatex.com/products/thread...raulic-sealant/
Thx
I was thinking about it ... But I'm afraid of cracked transfer case those plugs are tappered already I don't want to add thickness ... I know it's minimal but liquid seems a little bit safer
I got 80632 but it has Teflon worried about contamination a little ..
I think it’s fairly important to clean off the buildup of Teflon tape and/or thread sealant, particularily on aluminum transfer cases and then re-apply a fresh coating. Make sure the drain plug on the transfer case has the integral magnet.
SF
Considering I have one that is stuck in place, and now stripped, I'm more of the mind to use nothing.
