Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
98 registered members (555, 3311, A1O, 2015_PSD, addyguy, 12 invisible), 2,096 guests, and 63 spiders.
Topics286,156
Posts4,903,166
Members67,565
Most Online2,967
Mar 10th, 2019
1996 Honda Accord - no crank #4675925
02/23/18 10:09 PM
02/23/18 10:09 PM
Holland, MI USA
DutchBrad Offline OP
Holland, MI USA
Hello all:
I have a 1996 Honda Accord LX 2.2 four cylinder, the car will not crank. The battery is fine, the starter I just replaced, it acts like it has a short when you turn the key to crank it. The idiot lights go dim, it makes a small click before the lights dim out. It "recovers" (stops acting like it has a short) after a few minutes, so you try to crank again, and it does the same thing. Once when I had the headlights on it cranked over and started. Any ideas??
I replaced the starter thinking the solenoid was causing the electrical short. Did not fix the issue.
Help!
DutchBrad
12 Mitsubishi i-MiEV 20k-electric
03 Toyota Sienna 149k PP 5w20 P1
96 Honda Accord LX 237k VNG 5w30, Pronto
96 Honda Accord EX ??K, VNG, Pronto
Re: 1996 Honda Accord - no crank [Re: DutchBrad] #4675930
02/23/18 10:13 PM
02/23/18 10:13 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Checked both battery cables and connections/grounds?
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: 1996 Honda Accord - no crank [Re: DutchBrad] #4675931
02/23/18 10:13 PM
02/23/18 10:13 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Its not a short. It's an open.It has a bad connection or cable.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 1996 Honda Accord - no crank [Re: Chris142] #4675938
02/23/18 10:20 PM
02/23/18 10:20 PM
Holland, MI USA
Holland, MI USA
This is a new one for me. An open will drain the battery? I just had the battery out and cleaned the connectors when it was out to do the starter last night. Same condition. I will check the grounds. I pulled the battery connection off again to avoid a dead battery.
Re: 1996 Honda Accord - no crank [Re: DutchBrad] #4675940
02/23/18 10:21 PM
02/23/18 10:21 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I don't believe you mentioned the battery drain in your initial post...
Re: 1996 Honda Accord - no crank [Re: Alex_V] #4675952
02/23/18 10:30 PM
02/23/18 10:30 PM
Holland, MI USA
Holland, MI USA
The car does not have a battery drain after the short/open whatever is causing the dim idiot lights recovers. When you go to crank the car, the idiot lights go dim, but after a couple of minutes the short/open condition stops. I thought it was the solenoid shorting out. Sorry for the confusion. I was pretty surprised when the same condition happened with the new starter in place and wired up. I unhooked the battery last night because I had to get inside and did not know how long the condition would take to recover. It is like a fuse resets or something, but when I go to crank it again, the dim lights happen again with no starter movement, only a small click. Could not tell where the click came from.
Re: 1996 Honda Accord - no crank [Re: DutchBrad] #4675955
02/23/18 10:33 PM
02/23/18 10:33 PM
IL
qjohn Offline
qjohn  Offline
IL
Check the ignition switch. I had a 95 Odyssey and I needed to swap out the switch. I recall it was common on mid 90s Hondas.
Re: 1996 Honda Accord - no crank [Re: DutchBrad] #4675995
02/23/18 11:26 PM
02/23/18 11:26 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Do you have a volt meter?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 1996 Honda Accord - no crank [Re: DutchBrad] #4676018
02/24/18 12:01 AM
02/24/18 12:01 AM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
Did you check the battery cables only at the battery? Did you check the ground connection at the other end of the cable from the battery? One is on the radiator support, should be another on the engine block. Clean them with baking soda mixed with water, and your old tooth brush, report back.
And get a volt meter, check voltage please.
08 Tribeca 86k PUP 5w30 wix
06 Accord Hybrid 134k PPHM 0w20 wix
02 Chevy k3500 99k Delvac 1 esp 5w40 wix
00 F350 136k Delvac 1300 15w40 wix
Re: 1996 Honda Accord - no crank [Re: DutchBrad] #4676180
02/24/18 08:54 AM
02/24/18 08:54 AM
Leamington, ON, Canada ..... r...
Papa Bear Offline
Papa Bear  Offline
How did you come to this conclusion?
2016 Dodge GC Deep Cherry 5W-30 Dino
2013 SYM Wolf Classic 150 T4 15W-40
2009 V-Star 250 Black Cherry 20W-50 Dino
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: 1996 Honda Accord - no crank [Re: DutchBrad] #4676194
02/24/18 09:05 AM
02/24/18 09:05 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Sounds like a flat/dead battery, if its charged then as someone posted look at the ignition switch.
Re: 1996 Honda Accord - no crank [Re: DutchBrad] #4676254
02/24/18 10:12 AM
02/24/18 10:12 AM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
+2 on the ignition switch to be checked out.
16 Civic-QSUD 0W-20, XG7317
14 Civic-Idemitsu Zepro 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline ProDS 10W-30, TG7317
Re: 1996 Honda Accord - no crank [Re: DutchBrad] #4676961
02/24/18 09:48 PM
02/24/18 09:48 PM
Holland, MI USA
Holland, MI USA
Just took a look at the car again today, the car started in neutral. So it is the neutral safety switch. Not a fan of all that safety [censored]. Might try a way to bypass it? If not, I will replace the switch. Thanks for all the comments, much appreciated.
Re: 1996 Honda Accord - no crank [Re: Papa Bear] #4676962
02/24/18 09:49 PM
02/24/18 09:49 PM
Holland, MI USA
Holland, MI USA
I had the battery out and ran it in my other Accord. It also showed 12.6 volts when I checked it.
Re: 1996 Honda Accord - no crank [Re: DutchBrad] #4677178
02/25/18 02:30 AM
02/25/18 02:30 AM
USA
mk378 Offline
mk378  Offline
USA
Neutral safety switch will not cause all the lights to go out. You have a bad connection in one of the major power or ground wires. Use your voltmeter to find out where the voltage is being lost.
