oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Poles19, HinaMach, Horsehaulin, JLew, bmrk1100
66666 Registered Users
107 registered members (4WD, aquariuscsm, bdcardinal, anndel, aba4430, Best F100, 14 invisible), 1,786 guests, and 40 spiders.
Topics295,018
Posts4,926,070
Members66,666
Most Online2,553
Oct 27th, 2018
How much life left on these tires? #4675898
02/23/18 08:34 PM
02/23/18 08:34 PM
IL
Ndx Offline OP
Ndx  Offline OP
IL
https://m.ebay.com/itm/Set-of-4-265-50-1...0V/173169984227
Please help interpreting life left in those.
My current tires are wore down and itS affecting AWD system rear ones have more tread.... ( Transfer case )
I know sellers says 80% but lol they all do always ... Looks like no camber wear so that's good.
Re: How much life left on these tires? [Re: Ndx] #4675910
02/23/18 08:52 PM
02/23/18 08:52 PM
Basehor, KS
JayhawkRoy Online content
JayhawkRoy  Online Content
Basehor, KS
Here's my interpretation: "7-7.75" depth suggests one tire is at 7/32 depth remaining and at least one other is at 7.75/32ds remaining. The other two are unknown tread depth. Original Michelin tread depth appears to be about 10/32ds, so 3/32ds is used up. Tires become unsafe at about 2/32ds so there may be 5/32ds left. "80%" life remaining is a stretch.
Re: How much life left on these tires? [Re: Ndx] #4675913
02/23/18 08:58 PM
02/23/18 08:58 PM
NJ
irad Offline
irad  Offline
NJ
The seller measured at the center rib. See if he will measure at the edge ribs. An under inflated tire wears at the outside. Over inflated wear in the middle. This will give you a better idea of remaining tire life.
Re: How much life left on these tires? [Re: Ndx] #4675922
02/23/18 09:07 PM
02/23/18 09:07 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
technically, even assuming 7.75 remaining tread depth, there is 72% remaining, if you run your tires down to 2/32. I don't.
also, clearly those tires have seen some wheel spin. (ok, I might do that occasionally on one of my cars) there is also a small amount of weird damage visible on one tire. what else cant we see? and were the tires run flat? beyond "holding air", are they safe?
Apparently these tires new are over $300 each. so I suppose that $329 is a bargain for the set.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: How much life left on these tires? [Re: Ndx] #4675943
02/23/18 09:24 PM
02/23/18 09:24 PM
IL
Ndx Offline OP
Ndx  Offline OP
IL
Bargain ... But dunno might have to think about it twice.
Thx guys
Re: How much life left on these tires? [Re: Ndx] #4675945
02/23/18 09:24 PM
02/23/18 09:24 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
You can safely wear them down to the wear indicators molded into the tire. How much wear to that point. shrug
2007 Ford Fusion 235,000 miles
M1 0-20 EP
2017 Ford Fusion 60K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: How much life left on these tires? [Re: Ndx] #4675953
02/23/18 09:31 PM
02/23/18 09:31 PM
Michigan
NO2 Offline
NO2  Offline
Michigan
It depends where you live. 2/32 is not safe for any area with significant snow or rain. Assuming that the tires start with 10/32, and currently are at 7/32, only 62% of usable life remains for dry conditions. For areas with rain, 3/32 is the recommended minimum so the tires have 57% of usable life. In areas with a snow, 4/32 is the recommended minimum with most tires, so the tires are 50% worn.
Re: How much life left on these tires? [Re: Ndx] #4675957
02/23/18 09:34 PM
02/23/18 09:34 PM
CA
raytseng Offline
raytseng  Offline
CA
I give the poster some benefit of the doubt.
Even though a proration chart does do it linearly in terms of refund $,
Tires wear slower as the treadblocks wear down. The first 32nds always go away a lot faster than the final 32nds. They often are the best 32nds.
Often by the time you are on the last 32nds those last treadbits last forever, but its also been a few years and you would rather have new rubber anyway.
so it depends on your standards of tire "life". if you have high standards of performance the best life of the tire is already gone.
if you want a tire just to get from pointa to point b, then yes perhaps you have 80% of that minimal standard of ability left.
Re: How much life left on these tires? [Re: tomcat27] #4675988
02/23/18 10:14 PM
02/23/18 10:14 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
So, I suppose that $329 is a bargain for the set.
That's the way I look at it.
Re: How much life left on these tires? [Re: Ndx] #4676039
02/23/18 11:51 PM
02/23/18 11:51 PM
USA
slacktide_bitog Offline
USA
None
You have no ides how they were driven, under what conditions, etc. And the tire shop selling them doesn't know, either.
The only time I'd buy a used tire would be in an emergency, or for a full-size spare.
I don't usually like Chinese tires, but since DTD's big sale is over, at least you can get brands new tires for $100 each
Re: How much life left on these tires? [Re: Ndx] #4676080
02/24/18 02:52 AM
02/24/18 02:52 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Yeah, I wouldn't buy tires online just from a pictures and the guy says that they're OK!!!...But, if you must then, here is a bit of info from TheTireRack.
Info from Tire Rack, these tires when new start out at 10/32nds and are $325/ea. The Tire Rack specifies NO PORSCHE. Although, Tire Rack used a Porsche to test the tires, I think they mean in your size.
IDK if any of this helps but, you should be able to run'em for a while.
https://www.tirerack.com/tires/tires.jsp...0&tab=Specs
265/50R19
110V
Load Index 110 = 2,337lbs (1060kg) per tire
Speed Rating “V” = 149mph (240kph)
XL
N0(Porsche)
Eco:
Green X
440 A A 2,124 lbs. 50 psi 10/32" 34 lbs. 7.5-9.5" 8.5" 10.9" 10" 29.5" 705 HU,FR
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: How much life left on these tires? [Re: Ndx] #4676096
02/24/18 04:56 AM
02/24/18 04:56 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I'd pass, unless I was trying to get the vehicle in shape to sell and wanted to keep costs down.
God Bless Our Troops
Re: How much life left on these tires? [Re: Ndx] #4676110
02/24/18 06:07 AM
02/24/18 06:07 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
N0 is Porsche specification. N0 (N-Zero) is the first assigned version.
It is not “NO Porsche”.
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
Re: How much life left on these tires? [Re: Ndx] #4676159
02/24/18 07:25 AM
02/24/18 07:25 AM
VA
Gebo Offline
Gebo  Offline
VA
Not trying to be cute but did you see "Or best offer"? That's what I'm talking about... Offer them a price you feel great about and see what they say. $250 would be awfully nice price...
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: How much life left on these tires? [Re: DuckRyder] #4676603
02/24/18 02:44 PM
02/24/18 02:44 PM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Thank you my friend. This is good to know when giving info to others.
"Retired"
'15 Honda Civic LX
