Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
9 minutes 32 seconds ago
revive Nicd battery
by Donald
22 minutes 31 seconds ago
Need help finding an apartment for friend
by RazorsEdge
43 minutes 4 seconds ago
ceratec with redline 5w30?
by 08z06
56 minutes 21 seconds ago
does your COMCAST modem have weak wifi??
by edwardh1
Today at 09:50 PM
I hate stuck thermostats
by jakewells
Today at 09:49 PM
Mag1 75w90
by SavagePatch
Today at 09:32 PM
Old batteries at HD
by bbhero
Today at 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
Today at 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
Today at 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
Today at 08:13 PM
Shure stylus replacement
by aquariuscsm
Today at 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
Today at 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
Today at 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
Today at 06:27 PM
Why buy low mileage tires?
by HowAboutThis
Today at 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
Today at 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
Today at 05:18 PM
Car Sales Scammers on Letgo
by ZZman
Today at 04:18 PM
Air shocks or Timbren for trailer towing ?
by Oldtom
Today at 04:10 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
70 registered (AnonOIl, bbhero, AVB, alphadog, 10 invisible), 1289 Guests and 35 Spiders online.
65258 Members
67 Forums
285500 Topics
#4675886 - 02/23/18 08:26 PM Opinions on buying this 07 escape
gabriel9766 Offline
Loc: Missouri
Car got towed into work for a busted lf brake hose.... so they got all 4 done and i went to bleed the system and all 4 bleeders were frozen solid. So tried to sell em new wheel cyls and calipers. They traded it in in our used car department. So it came back to me to get a pedal to get it to auction..... i asked what they wanted for it. They said 3k. It's on 07 ford escape xlt 3.0L FWD. with 109k on it. Got some under body rust but not to bad and a paint spot peelingx behind the sun roof. No leaks but could use sawy bar links. Pulled the oil cap and it dont look the best down there but not to bad. So im trying to figure out if i should buy it and get rid of my Leakey a$$ taurus.
#4675895 - 02/23/18 08:31 PM Re: Opinions on buying this 07 escape [Re: gabriel9766]
Nick1994 Offline
Loc: Phoenix, AZ
$3k sounds like the price a dealer should ask for it. Auction price? No way.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4675897 - 02/23/18 08:33 PM Re: Opinions on buying this 07 escape [Re: gabriel9766]
BAJA_05 Offline
Loc: Berks County/Pa.
Did you take it for a test drive? Is it automatic and what does the tranny fluid look like if it is? Also -- is it 4WD? Mileage is not bad at all for that price.
Dale
2017 VW Jetta SE TSI 1.4L Turbo
PP Euro 0W40 & FU
2008 Acura TL 3.2L QSHM 5W20 & FU
2005 Subaru Baja AWD 2.5L N/A 5spd.
Rotella T6 5W30 & ST
#4675899 - 02/23/18 08:35 PM Re: Opinions on buying this 07 escape [Re: gabriel9766]
copcarguy Offline
Loc: PA
This generation Escape LOVE to rust away near the rear shock towers. Carefully inspect this area before doing anything.
#4675908 - 02/23/18 08:46 PM Re: Opinions on buying this 07 escape [Re: BAJA_05]
gabriel9766 Offline
Loc: Missouri
Dale
going to put calipers and whhels cyls on it tommrow and test drive it then decide. FWD 3.0 v6
2015 Chevy Malibu 1LT DI 2.5L I4- PPPP 0w20 and a napa gold 7060 39,829K
2007 Ford Escape XLT FWD 3.0 V6 motorcraft 5w30 bulk and a motorcraft FL500s 109,944K
#4675948 - 02/23/18 09:28 PM Re: Opinions on buying this 07 escape [Re: gabriel9766]
tomcat27 Offline
Loc: Chicago, IL
according to NADA, that's a good price - as long as you are ok with 2wd. ditto on the rust by the rear fender wells. when those rust you lose your shock mounts. there are repair kits available. I just fixed one last year.
2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
#4676122 - 02/24/18 06:35 AM Re: Opinions on buying this 07 escape [Re: tomcat27]
gabriel9766 Offline
Loc: Missouri
What about the engine? Wouldn't say its slugged but not clean.
Edited by gabriel9766 (02/24/18 06:35 AM)
#4676124 - 02/24/18 06:38 AM Re: Opinions on buying this 07 escape [Re: gabriel9766]
NHGUY Offline
Loc: USA
The front engine cradle/suspension crossmember is just 2 pieces of sheet steel spot welded together,the control arms bolt to this,these rust badly and can cause the wheels to tilt out at the bottom when the control arms break away.This is what happens when a Mazda 6 gets transformed into an SUV/Crossover.Should have stayed being a car.
#4676134 - 02/24/18 06:59 AM Re: Opinions on buying this 07 escape [Re: gabriel9766]
SubieRubyRoo Offline
Loc: Winchester, Indiana
I'd say pass. too many rust issues, 3.0 can have many problems as well. I'd say 1k max esp. considering the amount of work it needs.
#4676166 - 02/24/18 07:35 AM Re: Opinions on buying this 07 escape [Re: gabriel9766]
JHZR2 Offline
Loc: New Jersey
If it has that much corroded at 109k, I'd avoid it. Or take the risk at like $1500.
#4676192 - 02/24/18 08:05 AM Re: Opinions on buying this 07 escape [Re: gabriel9766]
spasm3 Offline
Loc: North Carolina
The cd4e transmission in that escape is a weak point as well. The factory had transmission coolers on a lot of them to get them to last. When i had an 01 escape i changed the trans fluid every other oil change. There was no filter to access. The valve body went bad in mine at 175k so i traded it.
With the rust and unknown maintenance and so forth i'd pass or get it cheap say $1000.
13 elantra 68k 5w30 QSUD
03 chevy avalanche76k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 3900 miles m1 0w20/0w40 mix
#4676723 - 02/24/18 04:21 PM Re: Opinions on buying this 07 escape [Re: gabriel9766]
Eric Smith Offline
Loc: Kansas, USA
Prices on that age would be 4-5k depending on age and miles. The rear wheel wells is major rust point (a body shop can fix this but don't know how much). CD4e is a good transmission if the fluid is changed, if the fluid isn't red run! Brake components are fairly cheap, going to do mine this spring. Too late now but if you could of soaked those bleeders in MMO and ATF for a couple drive cycles they would came loose. Sway bar links are cheap.
I'd say even with the bad brakes and if eventually have to change the trans your still ahead at 3k.. but I'd try to get less.
My well taken care of Escape at 155k runs and drives like new.
05 Chevy 3500 (Class C RV) 55k (PU 5w30)
04 Escape 150k (PHM 5w20)
02 Focus 132k (PP 5w20)
91 Festiva 255k .. Rust bucket
#4676725 - 02/24/18 04:23 PM Re: Opinions on buying this 07 escape [Re: NHGUY]
Eric Smith Offline
Loc: Kansas, USA
There's a recall on this. I never had ours looked at though. The front timing cover leaks and pretty much cures any chance of rust up front!
#4676837 - 02/24/18 06:36 PM Re: Opinions on buying this 07 escape [Re: JHZR2]
gabriel9766 Offline
Loc: Missouri
I kind of oversated the rust. It's got some surface rust underneath the vehicle and some spots are just a little worse.
#4676850 - 02/24/18 06:49 PM Re: Opinions on buying this 07 escape [Re: gabriel9766]
gabriel9766 Offline
Loc: Missouri
Well probably gonna buy it next week. Got the rear wheel cylinders put on and One front caliper, got the other bleeder to break loose Barely. Power bled the system with the machine at work and test drove it and the transmission and engine run and drive smooth. Atf is brown but not burnt.
