CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
55 registered members (87sammy, Anthony, 2015_PSD, A1O, Bailes1992, 6 invisible), 715 guests, and 26 spiders.
Topics287,674
Posts4,932,035
Members67,838
Most Online2,967
Mar 10th, 2019
Front coil springs - 2000 F150 4x2 ? #4675818
02/23/18 08:14 PM
02/23/18 08:14 PM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
I have a 2000 F150,4x2 ,ext cab. I just recently had all 4 shocks replaced with Monroe gas magnum shocks.
I also got installed maxtrac 2 inch rear lowering shackles,and max trac rear hangers. I did this to make the rear of my truck level to the front. Now after having this doing it has a slight "bulldog" look,where the rear is now a little bit lower than the front.
Can I have installed these front coil springs and still keep my monroe shocks on,or do i have to get shorter front shocks?
I ask this because this guy with maxtrac suspension told me that if I where to install the rear shackles,and hangers I would have to use shorter shocks. Well when my mechanic did the install the shackles,and hangers when on just fine with the monroe shocks.
I think if I buy these and have them installed it will even everything more level. Please advise. Thanks!
Re: Front coil springs - 2000 F150 4x2 ? [Re: lawnguy] #4675868
02/23/18 09:06 PM
02/23/18 09:06 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Donít you tow with this truck?
2015 Hyundai Sonata 2.4L 93k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Front coil springs - 2000 F150 4x2 ? [Re: lawnguy] #4675877
02/23/18 09:17 PM
02/23/18 09:17 PM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
yes. 1800 lbs max
Re: Front coil springs - 2000 F150 4x2 ? [Re: lawnguy] #4675966
02/23/18 10:46 PM
02/23/18 10:46 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: lawnguy
yes. 1800 lbs max
I wouldn't lower the rear if you tow much. I know 1800 lbs gross isn't a lot,
but even 100 lbs of tongue weight probably put you "level" before.
