Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
93 registered members (aquariuscsm, Bear, atikovi, A310, beanoil, 9 invisible), 1,783 guests, and 41 spiders.
Topics295,012
Posts4,926,005
Members66,664
Most Online2,553
Oct 27th, 2018
UOA: 2011 Equinox 2.4l - fuel in oil #4675480
02/23/18 12:47 PM
02/23/18 12:47 PM
Iowa
Iowegian Offline OP
Iowegian  Offline OP
Iowa
back ground info:
I purchased my 2011 Equinox with the 2.4l, AWD, and 58k miles in Nov of 2016.
Since purchase.....
Replace high pressure fuel pump (GM recall)
Manual shifter cable replaced (done by selling dealer for free)
Replaced spark plugs, front o2 sensor, map sensor, and differential and transfer case fluid (nasty black) myself.
Had transmission fluid completely changed by pushing old fluid out with new fluid. (Again black and nasty)
Cleaned a very dirty throttle body. (Much better idle)
New pistons, rings, and timing chain (GM warranty)
Replaced thermostat when they had my engine torn apart. (My cost for part only. Opening too soon...but no check engine light lol)
Replaced catalytic converter (GM warranty)
Replaced cracked exhaust manifold (purchased warranty)
Replaced AC condenser (purchased warranty)
I did do a leak down test a few weeks ago.
Numbers were about 95, 96, 89, 98. I chalk the #3 cylinder to my not getting top dead center.
I did have some high fuel trim numbers. LTFT was around +6% to +9%. Changed out the MAF sensor right after the leak down test which cured that.
I am waiting for the transmission to fail soon. GM may or may not cough up for their mistake on that as well.
However, I have the purchased warranty that last 4 years or 48k which will pay for that monstrous bill if it does.
I have an appointment next week with the dealer that rebuilt the engine.
I am fairly confident that it is the High Pressure Fuel Pump that is the problem.
I think the next part that I will replace will be the entire car.... crush
Edit- just a note, when I changed my oil, I ended up with about a half quart to a quart more than I had put in it...
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: Iowegian] #4675509
02/23/18 01:10 PM
02/23/18 01:10 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Sorry to hear. The link below kind of echoes what you mention.
https://www.carcomplaints.com/Chevrolet/Equinox/
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: Iowegian] #4675510
02/23/18 01:11 PM
02/23/18 01:11 PM
Indiana
classic70 Offline
classic70  Offline
Indiana
I would send it down the road while it still runs...
I had a 2012 Nox that was trouble free... sounds like yours is a lemon. I know a lot of the 11's had issues.
2003 GMC Yukon 5.3 228k
1997 k1500 5.7 225k
1970 GMC C15 5.3 100k
2012 Honda Odyssey 118K
Big Stash
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: Iowegian] #4675519
02/23/18 01:16 PM
02/23/18 01:16 PM
PimTac Offline
PimTac  Offline
That list is not indicative of any quality in my book. It sounds like you have been super patient with this vehicle. It may be time to let it go.
On the bright side, you got your money’s worth out of the warranty.
Cannot see signatures any longer so it doesn’t matter.
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: Iowegian] #4675520
02/23/18 01:16 PM
02/23/18 01:16 PM
Iowa
Iowegian Offline OP
Iowegian  Offline OP
Iowa
2010's and 2011's are worse.
2012's are having problems too.
The PCV system freezing up and blowing out the rear main seal is one of the other problems. GM ectended warranty on that as well.
Note to anyone, it is the 2.4l's that are having the problems. The V6s are not. Especially the 3.6l V6. Very good engine in the Equinox.
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: PimTac] #4675527
02/23/18 01:21 PM
02/23/18 01:21 PM
Iowa
Iowegian Offline OP
Iowegian  Offline OP
Iowa
I will definitely get rid of it before the purchased warranty is up.
Holding on to it for now till my family knows for sure what will happen in the next year or two. May move which may require purchasing a crew cab...
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: Iowegian] #4675653
02/23/18 04:07 PM
02/23/18 04:07 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Why was the engine rebuilt?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: Leo99] #4675685
02/23/18 04:47 PM
02/23/18 04:47 PM
WV, USA
JCasto Offline
JCasto  Offline
WV, USA
Obviously not the OP here, but I'll hazard a guess since my 2011 had a lot of the same issues. I assume it was rebuilt due to oil consumption issues. That would also probably explain the catalytic converter replacement too. We ran an oil consumption test starting at 98k, rebuild was done at 104k then within 2-3k the catalytic converter started throwing a code. Luckily everything was done under recall so no out of pocket costs.
2017 Ford Explorer XLT : Pennzoil Platinum 5W-20, WIX/NAPA Gold 57502/7502
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: JCasto] #4675696
02/23/18 05:04 PM
02/23/18 05:04 PM
Iowa
Iowegian Offline OP
Iowegian  Offline OP
Iowa
Good assumption....
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: JCasto] #4676297
02/24/18 09:57 AM
02/24/18 09:57 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
I'm assuming that the rebuild doesn't fix the design flaws so won't the oil consumption issues return eventually?
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: Iowegian] #4676621
02/24/18 02:56 PM
02/24/18 02:56 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Wow massive fuel in oil and a very low flashpoint.
2004 Corolla 126649
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: JohnnyJohnson] #4676633
02/24/18 03:03 PM
02/24/18 03:03 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
There's probably a lot more fuel in the oil than what's being reported. Since Blackstone's testing method for fuel is an estimate at best. Much better labs out there to test for fuel in the oil.
Re: UOA: 2011 Equinox 2.4l - fuel in oil [Re: Leo99] #4679593
02/27/18 10:58 AM
02/27/18 10:58 AM
Iowa
Iowegian Offline OP
Iowegian  Offline OP
Iowa
Different ring design is now being used.
So not necessarily going to return but it has on other cars.
I think the biggest problem is the cascade effect of oil burning. Other parts are damaged and those can in turn come back to create oil burning again.
However using the old 2.4l and putting GDI into it was definitely a design flaw.
2011 Equinox, 2.4l
2009 Sienna, 3.5l
