Patman
Staff member
Here are the latest results from my 2006 Civic, analysis done by Wearcheck Canada:
6,200 miles on oil
April 22, 2017 to Feb 17, 2018 (10 months)
143,600 miles on engine
Mobil 1 0w20 AFE
Fram Ultra oil filter
4.0L oil capacity
750 ml make up oil
Iron 7.5
Lead 0
Aluminum 2.8
Copper 0.6
Chromium 0.5
Nickel 0.2
Tin 0
Silver 0
Vanadium 0.2
Silicon 16
Potassium 1.4
Sodium 5.3
Sulfur 1527
Moly 67
Boron 36
Titanium 0
Calcium 982
Magnesium 649
Manganese 0.2
Antimony 0.8
Barium 0
Lithium 0.2
Beryllium 0
Cadmium 0
Phosphorus 542
Zinc 612
Oxidation 60%
Nitration 66%
Sulfation 68%
Soot 0
Glycol 0
Water 0
Fuel 8%
Viscosity at 100c 6.4
Viscosity at 40c 47.9
Viscosity Index 74
I was really hoping to see no fuel in the sample this time (last time was 5%) but it went the other way!
I put in more 0w20 AFE and did not change the filter, but my original plan was to switch to either 0w20 EP or AP on the next interval after this one. Now I'm wondering if I'm better off to just stick with shorter intervals and cheaper conventional oil. I really don't want to spend a lot of money looking into the cause of this excess fuel, as the car really isn't worth much at all and just needs to last me 4 more years (and then I will be retired so we can get away with just the BMW and Corvette) The car still runs great, there is no hard starting problem (like there was a few years ago when I had a lot of fuel in the oil) so if it weren't for this UOA I would never even know there was any issue at all. Considering the high fuel and low viscosity, wear numbers are excellent!
I had done back to back doses of Gumout Regane over two full tankfulls at the start of this interval to try to lower the fuel (which has worked for me before) and I will try it again this time.
6,200 miles on oil
Mobil 1 0w20 AFE
4.0L oil capacity
750 ml make up oil
Iron 7.5
Lead 0
Aluminum 2.8
Copper 0.6
Chromium 0.5
Nickel 0.2
Tin 0
Silver 0
Vanadium 0.2
Silicon 16
Potassium 1.4
Sodium 5.3
Sulfur 1527
Moly 67
Boron 36
Titanium 0
Calcium 982
Magnesium 649
Manganese 0.2
Antimony 0.8
Barium 0
Lithium 0.2
Beryllium 0
Cadmium 0
Phosphorus 542
Zinc 612
Oxidation 60%
Nitration 66%
Sulfation 68%
Soot 0
Glycol 0
Water 0
Fuel 8%
Viscosity Index 74
