Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
24 registered members (bmod305, Black_Thunder, AnthemBassMan, bfleeman, Brad_C, 555, 2 invisible), 489 guests, and 68 spiders.
Topics286,263
Posts4,905,495
Members67,589
Most Online2,967
Mar 10th, 2019
Amp wiring question #4675066
02/23/18 06:50 AM
02/23/18 06:50 AM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Well past my big speaker phase of youth but I did score a deal on a very moderate sub and amp combination for my summer cruiser. Reading the factory manual for the amp Iím a little confused. Itís listed as a 2/3/4 channel amp and bridgable. How would one wire this to one single voice coil sub? Also the manual shows two 30A fuses wired in parallel on the battery power line. This seems odd to me, can I replace it with a single larger fuse and or why size?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Amp wiring question [Re: buck91] #4675068
02/23/18 06:57 AM
02/23/18 06:57 AM
MN
14Accent Offline
14Accent  Offline
MN
If you're using a SVC sub, bridge two of the channels together by connecting to the A channel negative and B channel positive, either left or right. Connect your RCA input to either L or R channel.
Yes, a single 60a fuse on the B+ wire is fine.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Amp wiring question [Re: buck91] #4675070
02/23/18 07:00 AM
02/23/18 07:00 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
I donít think it will run as a mono amp. Note the line between the upper L+ and lower L- as well as the upper R- and lower R+ Those look like the bridges to me.
Robert
  • 2007 Toyota Prius Touring (It is For Sale)
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9‚ÄĚ 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Amp wiring question [Re: buck91] #4675077
02/23/18 07:15 AM
02/23/18 07:15 AM
MN
14Accent Offline
14Accent  Offline
MN
It'll run mono just fine. The lines are indicating your speaker connections. Just use one or the other.
Re: Amp wiring question [Re: 14Accent] #4675079
02/23/18 07:18 AM
02/23/18 07:18 AM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
It will run 2 channel bridged but how will it run mono?
Robert
Re: Amp wiring question [Re: buck91] #4675082
02/23/18 07:22 AM
02/23/18 07:22 AM
socal
barkingspider Offline
socal
Yeah, that amp is not for mono use. It states 2/3/4 channel.
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Amp wiring question [Re: buck91] #4675093
02/23/18 07:48 AM
02/23/18 07:48 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Some amps can be bridged, some cannot. It depends on the topography (basically, the type of circuit used) or the configuration (some amps are already bridged internally to get higher power output ... they cannot be bridged a second time).
Are you positive the two fuses are wired in parallel? That sounds strange and doesn't fit any known purpose. Have you confirmed it with a DMM? Are you sure they are not individual fuses each bank of power amplifiers, or are they two fuses wired in series?
The difference will determine whether you need to maintain two 30A fuses or can substitute one 60A fuse. If you can substitute one 60A fuse you will still need to jump the empty fuse socket. In the end I would just forget about the whole fuse thing and carry on as configured. Getting it wrong carries a slight risk of fire or a definite risk of blowing fuses, if the amp would even work at all. I don't see the point.
There is a 3-channel configuration. That would probably be achieved by taking the bridged 2-channel L or R and cutting the bridged configuration, leaving two individual L and two individual R channels. Now they can bridge two of those four into a third channel.
All of the above taken together seems to indicate you cannot bridge the amp to one channel, due to reason 2 (it's already bridged in 2 channel mode).
EDIT: Upon further examination of the speaker output wiring notes silkscreened on the unit it definitely contains four amplifiers (L + L and R +R), with two L and two R, which are bridged in 2 ch mode (L + L and R + R) and although I don't see any silkscreen about 3 channel mode, I'm sure in the manual it would be L + (L+R, bridged) +R configuration. So, no, your mono dreams are over with this amp.
You could simply not use one channel, and configure it in mono mode that way. In fact it's your only option. Most Solid State amps are fine with one channel unused. In that case you would only use the RCA input on the channel you intended to connect to a sub (or whatever) and leave the unused channel RCA unconnected.
Sub frequency signals are usually present equally in both L and R channels of the source, so there is no real penalty in only using one channel as long as the frequencies are truly sub or very low bass ... about 120 Hz or less; above 120 Hz they do become directional.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Amp wiring question [Re: buck91] #4675110
02/23/18 08:11 AM
02/23/18 08:11 AM
Johnny2Bad Offline
Johnny2Bad  Offline
If you're confused about the wiring diagram silkscreen, it goes like this:
L+ top row to L- bottom row, bridged 2 ch mode (Channel 1)
R- top row to R+ bottom row, bridged 2 ch mode (Channel 2)
Note the little bars connecting the above configuration, including one little bar connecting the words "bridged" to the above wiring.
So, if you intend to use this amp, connect it as above, but only with one channel (you choose, 1 or 2, but not both). Leave the unused channel speaker outputs and the RCA input of that channel unconnected. Doing so will give you the highest power from each channel (the used and unused ones). Without a manual you can't be positive of the 3-ch mode, as it's not indicated on the silkscreen. Regardless, it would offer the same power in the "middle" channel as the above configuration, so there is no need to go there.
Re: Amp wiring question [Re: buck91] #4675163
02/23/18 09:11 AM
02/23/18 09:11 AM
USA
mk378 Offline
mk378  Offline
USA
Fuses are wired in parallel because a 60 amp fuse is not made in that physical form factor. The "mega fuse" is more expensive than two small ones.
Like the others said you would use only half of the amplifier to drive a single speaker. This is likely OK if you don't want it really loud.
Re: Amp wiring question [Re: buck91] #4676291
02/24/18 10:50 AM
02/24/18 10:50 AM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Thanks all! I feel like a gommer asking but its just been so long. Anyways, the amp is an older Pioneer GM-4000F which will be connected to a JVC Arsenal KD-AHD59 which does have sub output (unfortunately they are stereo outs). Basically what I'm hearing is that if I bridge channel A to B using either left or right speaker outputs it should work just fine with my SVC sub (its a Insignia of unknown model/specs as I haven't pulled it from enclosure to check yet). I by no means need a huge thumper just want a little more balanced sound in my cruiser.
Oh, and the manual clearly shows parallel 30A fuses at the battery connection. Very weird.
Edit: Here is the three channel mode. I wonder if I can just run the mono output from channel B....
2011 F150 4x4 5.0L
