2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
86 registered members (alphadog, Aichiguy, agpatel, AdditiveOCD, 77GrandPrix, 11 invisible), 1,422 guests, and 62 spiders.
Topics286,436
Posts4,908,161
Members67,622
Most Online2,967
Mar 10th, 2019
Fluke 77: Strange DC Voltage Offset #4674759
02/22/18 08:15 PM
02/22/18 08:15 PM
Central Texas
sleddriver Offline OP
Central Texas
Got curious about the cause of this recently. It's a first generation 77. Bought it new in 1983. Worked fine up until last year. Perhaps some techs here have seen/heard of this? A 'net search didn't really turn up anything.
Powers on normally. Passes self-test. On Vdc, display reads -2.246 V then slowly begins to fall. With leads shorted, it reads 0.00Vdc. Unshorted, it reads -2.165 for a bit then slowly falls. I don't leave it shorted for long, just to see what happens
On 300mV, display reads "- OL"
On Ohm setting, reads -2.884M Ohm. I short the leads it reads -0.1 Ohms. Unshort back to earlier reading.
On diode check, display reads OL.
On Aac reads 0.02 amps with last digit ticking slowly. Looks normal for Aac.
On Adc, reads 0.00 amps. Looks normal.
Given the above, something's FUBAR on Vdc, 300mV dc/ac, Ohms and diode test settings. Ampere settings are unaffected.
This negative DC offset sounds like something is shorted. Capacitors block DC, but not a shorted one. Thus DC would get in somewhere it's not supposed to. On 300mV, this -2.3V is clearly over-range, so the display reads OL. On the Ohms settings, the -2.xx MOhms reading indicates a voltage being fed into the ckt, which isn't right.
May also be a shorted transistor. I opened the case. Inside is primarily film caps, a few tant. and one or maybe two AEC's under the display. The AEC's are suspect. Film caps don't usually go bad on their own. Tant. though....not sure if these go wobbly after decades like AEC's.
BJT's can go wobbly though. I'll have to dig up a service manual + schematic.
You bench guys ever seen this before? Dang odd. Just suddenly happened one day.
Another reason to heat up the iron.......
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Fluke 77: Strange DC Voltage Offset [Re: sleddriver] #4674761
02/22/18 08:21 PM
02/22/18 08:21 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Ooen it up and look for anything “gooey” or dirty. Clean with flux cleaner.
Also look for cracked solder joints. A dead component is unlikely. A rusty selector knob is also possible.
Re: Fluke 77: Strange DC Voltage Offset [Re: danez_yoda] #4674833
02/22/18 09:46 PM
02/22/18 09:46 PM
Canada
i_hate_autofraud Offline
Canada
Yeah, 30 year old flux residue can leak current across a PCB and throw things off! I scooped a
super expensive instrument that was sold off cheap, I found it drifted lots during bench test. Knowing the input
impedance would be well over 100 Meg ohms, flux cleaner did the job!
On cracked solder joints, you'll need a really good magnifier and light to see any kinda crack, sometimes
a crack looks like a cold joint but in a thin line either thru the solder fillet that's easily missed
or just around the component lead. Surprisingly, gold plated leads don't always take solder that well!
I've got 2 primo, expensive to replace Fluke 8842A bench meters that track the calibrator bang on! If they go south
I'll be in trouble! LOL
Re: Fluke 77: Strange DC Voltage Offset [Re: sleddriver] #4674852
02/22/18 10:14 PM
02/22/18 10:14 PM
Central Texas
Central Texas
Fluke left no residual flux on the board. Very clean. Did a board hover with a mag. hood. No cracks or broken traces I can find.
Meas. ESR of caps I could easily get to. Nothing strikes me as the culprit...yet.
I did locate a very old service manual! Verified component locations, labels and values on schematic. Found a BJT with coll & base tied together, forming a diode. If this shorted, it may be the problem.
M1 10W-30 HM
Re: Fluke 77: Strange DC Voltage Offset [Re: sleddriver] #4675348
02/23/18 11:32 AM
02/23/18 11:32 AM
Leamington, ON, Canada ..... r...
Papa Bear Offline
Papa Bear  Offline
A capacitor doesn't have to be shorted .. just leaky. (I mean resistive leaky, not juicy leaky)
I'd clean the PCB with alcohol and let it dry.
Probably time for a new DVM - I recently got one with a large display for my old eyes. cool
The meter I used for decades was a Beckman TECH 310, I loved it
2016 Dodge GC Deep Cherry 5W-30 Dino
2013 SYM Wolf Classic 150 T4 15W-40
2009 V-Star 250 Black Cherry 20W-50 Dino
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: Fluke 77: Strange DC Voltage Offset [Re: sleddriver] #4675477
02/23/18 01:43 PM
02/23/18 01:43 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I vote for dirty contacts on the mode selection switch. Doubt it's caps. In 30+ years in the industry, I have seen very few caps short, they go open with age much more frequently.
The "thinking" man's friend.
Re: Fluke 77: Strange DC Voltage Offset [Re: sleddriver] #4683811
03/04/18 08:08 AM
03/04/18 08:08 AM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
replace the tants and lytics.
Re: Fluke 77: Strange DC Voltage Offset [Re: sleddriver] #4743983
04/30/18 10:17 PM
04/30/18 10:17 PM
Central Texas
Central Texas
Time for an update: I followed the trouble-tree in the service manual. Vdc reads correctly despite the no-connection offset. Ditto for the Ohms function. Checked ESR of all tantulums & one AEC. OK. The U1 IC looked straight on the pads with only a few legs maybe solder-starved. Not enough to warrant heating it up. No cracked/ringed solder joints.
I gave the board a good wash, a close examination and swept out any remaining debris with a stiff natural bristle brush. I'd read that Fluke had some issues on the earliest of models with solder-starved joints on the 60-pin U1 IC. One or two looked 'dry' but I left them. Fortunately pin/pad alignment was dead on.
I thoroughly cleaned out the banana barrels with ethanol, and around the posts. My 'board hover' showed a bit of green corrosion on the inside button of the NEG batt. terminal, which is riveted to the stand-up mount. I removed as much as possible (to no improvement), so I unsoldered it, took a wire wheel in a MotoTool to it, then soaked it in vinegar to eat the alkaline paste residue. Afterwards, I gave it a shot of DeOxit D5 spray and let it sit overnight.
I used a dental pick to rake out the joints between the + & - 9V batt. terminals and anywhere else that caught my eye. Over time, who-knows-what can build up on top cause tiny little conductive paths that weren't there when new. I also closely checked the probe connections and between the posts. Washed again, then blew dry with air, then had another look for any areas I missed.
Next day I resoldered it back in place, installed the 9V batt. and powered her up. Vac settled at 0.01. I noticed a + 1.5V offset on Vdc for a few sec. then it settled down to 0.00! Clicked over to 300mV, same thing. Ohms setting right at OL.
Success!
Looks like she was hankering for a good bath & a scrub and it did her a world of good! Interesting how Fluke uses a 9V batt. It's not 9V and gnd but rather +Vdd and -Vss. Internal to U1 there is more going on. Fluke used a dual slope A/D which requires two inputs as shown in the SM. Everything is converted to a voltage, filtered, buffered, integrated and counted before being outputted to the LCD display driver.
Speaking of a bath & scrub, the outer protective vinyl/rubber/plastic case needs a good one then a treatment of protectant. I mixed some powder Tide + hot water in a small cooler, dropped in both protective sleeves, agitated a bit, then shut the lid for an overnight soak.
Next day, the water was black. They didn't need much scrubbing due to the long soak. Both came out looking clean and new. Wiped them off then let both dry in the Sun for a few hrs. I'll wipe with some Mequiar's VLR.
Glad the old F77 is back in service. I've used it several times since with no more issues. Glad to cross this repair off this list.
M1 10W-30 HM
Re: Fluke 77: Strange DC Voltage Offset [Re: sleddriver] #4744000
04/30/18 10:33 PM
04/30/18 10:33 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Thorough af recondition! Nice job
There's no replacement...'scosity for natural viscosity
Re: Fluke 77: Strange DC Voltage Offset [Re: PeterPolyol] #4748928
05/06/18 01:51 AM
05/06/18 01:51 AM
Central Texas
Central Texas
cheers
M1 10W-30 HM
Re: Fluke 77: Strange DC Voltage Offset [Re: sleddriver] #4755158
05/12/18 03:32 PM
05/12/18 03:32 PM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
great!
you wont likely find a better dvm unless you buy another fluke.
and i run lithium primaries in mine.
they dont leak corrosive stuff.
its worth $8 for an energizer lithium to protect a high end meter.
Re: Fluke 77: Strange DC Voltage Offset [Re: kc8adu] #4755185
05/12/18 04:24 PM
05/12/18 04:24 PM
Central Texas
Central Texas
Thanks. Bought that meter in 1983 same year I graduated EE program. We've tested a lot over the decades too. I don't store batteries in any electronic equip due to leakage. But the DVMs get used so often it's a hassle to remove/install.
M1 10W-30 HM
Re: Fluke 77: Strange DC Voltage Offset [Re: sleddriver] #4827961
07/31/18 07:32 PM
07/31/18 07:32 PM
michigan
dirtymudder Offline
dirtymudder  Offline
michigan
I still have my B&K from 1981. I wouldn't give it up for love nor money. It's the best diode and transistor tester I have ever used in a VOM
