Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
53 registered members (bullwinkle, chance, alarmguy, 4WD, Char Baby, 69Torino, 7 invisible), 947 guests, and 41 spiders.
Topics295,047
Posts4,926,801
Members66,672
Most Online2,553
Oct 27th, 2018
Spark Plug Interpretation #4674752
02/22/18 07:08 PM
02/22/18 07:08 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Just took these out of my 1994 Honda Lawn Tractor. Been in for 2 years. What would make one plug run black? Now, I just cranked it up and let it run to get oil warm to change and then removed the plugs after it cooled down.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: Spark Plug Interpretation [Re: Gebo] #4674764
02/22/18 07:24 PM
02/22/18 07:24 PM
Canada
boraticus Offline
boraticus  Offline
Canada
That little bit of soot built up on the insulator is nothing. It's likely residue from running the machine with the choke on for start up. Had you run the machine under load for a while, chances are it would likely burn off.
What's interesting though is that only one plug has soot on it as though only one cylinder was receiving more fuel?
The sooty plug's electrode appears to be whitish. Which isn't unusual in today's lean running engines.
You have nothing to worry about. The plugs look fine.
The best time to read a spark plug is after running the engine under load for a good period of time. Normally the color should be a tan. But, as I said, today's very lean engines often show very light deposits.
I have a 2005 Craftsman riding mower powered by a Honda GX engine. In the thirteen years that I've owned it, I've yet to pull the spark plugs. Engine starts quickly and runs strong. I've never felt the need to take a look at the plugs. Maybe this year.
Re: Spark Plug Interpretation [Re: Gebo] #4674770
02/22/18 07:29 PM
02/22/18 07:29 PM
ME
eljefino Offline
eljefino  Offline
ME
When I had a v-twin bike one side was jetted differently from the other on account of cooling.
Re: Spark Plug Interpretation [Re: eljefino] #4674772
02/22/18 07:33 PM
02/22/18 07:33 PM
Canada
boraticus Offline
boraticus  Offline
Canada
That would make sense with one cylinder behind the other in a vertical installation. Especially in an air cooled engine. But in a horizontal, fan cooled V-twin, I doubt there would be a significant temperature differential between cylinders requiring different jetting and if the engine only has one carb, I'd say we can safely rule that out.
Re: Spark Plug Interpretation [Re: Gebo] #4674806
02/22/18 08:22 PM
02/22/18 08:22 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
You should run the tractor at full rpm and mow. Then shut off the gas to kill the engine and pull and check the plugs.
CX5 Touring 2.5L :-)
Re: Spark Plug Interpretation [Re: Gebo] #4674816
02/22/18 08:27 PM
02/22/18 08:27 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Will do in a few weeks.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Spark Plug Interpretation [Re: Gebo] #4675038
02/23/18 03:50 AM
02/23/18 03:50 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
You have some oil control issue, compression or weak ignition associated with that one cylinder. That left plug is not acceptable and should look like the other. I have an old craftsman twin that did that, but not as bad, it was a bad magneto coil.
The "thinking" man's friend.
Re: Spark Plug Interpretation [Re: Lubener] #4675406
02/23/18 11:28 AM
02/23/18 11:28 AM
Canada
boraticus Offline
boraticus  Offline
Canada
A little soot doesn't confirm that he has an oil consumption issue. He should just run the machine under load for a while then take a look at the plugs. If the engine isn't smoking blue under load, not likely to be an oil consumption problem.
Re: Spark Plug Interpretation [Re: boraticus] #4676094
02/24/18 04:52 AM
02/24/18 04:52 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I suggest some oil because of the accumulated craters present. Minor oil consumption may not be bad enough to produce blue smoke.I use the common sense approach, if the plug condition is due to the way it was run,the other cylinder should look poorly as well.I would bet that compression results between the two cylinders are not similiar.
Re: Spark Plug Interpretation [Re: Lubener] #4676118
02/24/18 06:30 AM
02/24/18 06:30 AM
Canada
boraticus Offline
boraticus  Offline
Canada
Possibly could be some compression difference but once heated, would it be of any significance? Maybe the OP could tell us if the engine is consuming oil? If not, I wouldn't be too concerned about it.
Re: Spark Plug Interpretation [Re: Gebo] #4676131
02/24/18 06:56 AM
02/24/18 06:56 AM
VA
Gebo Offline OP
Gebo  Offline OP
VA
No oil consumption. Years ago I had a lot of misfiring problems. After talking with local dealer, changing plugs, etc., I ended up replacing both coils thinking it was low voltage. Come to find out I had a much simpler fix that I only figured out on accident. For years I had been washing and replacing the foam filter which covered the expensive paper element filter. The paper looked fine so I kept on using it and just washing and re-oiling the foam filter.
Well, guess what? All my problems were fixed when I replaced the paper filter with a new one. It had gotten clogged with dirt that could not be seen with the naked eye. The clogged paper filter had been restricting air flow causing misfiring. Now I change both air filters every two years along with my gas filter and spark plugs. And only with Honda OEM.
By the way, this is the GXV 620, V Twin, 20 HP Honda engine.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Spark Plug Interpretation [Re: Gebo] #4676429
02/24/18 12:04 PM
02/24/18 12:04 PM
Canada
boraticus Offline
boraticus  Offline
Canada
I could be wrong but I don't think you're supposed to oil the foam filter if it's over a paper filter. Doing so would cause the paper filter to become saturated and too restricted if oil gets on it in sufficient quantity.
I've been using the original paper filter on my Honda GXV-530 for going on 13 years. I use compressed air to blow both the foam and paper elements out every so often. It's not very dusty where I cut so, the filter doesn't pull in much dust.
Does your GXV-620 have overead cams? My 530 does, which I thought was unusual. Most GX engines are push rod.
Re: Spark Plug Interpretation [Re: Gebo] #4676461
02/24/18 12:23 PM
02/24/18 12:23 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
boraticus,
You make an excellent point about oiling the foam filter. I know when it is still in the plastic bag there is a little oil in there with the filter. Maybe I was over oiling it. I'll start a new thread on the "oiling the foam."
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 60K
Re: Spark Plug Interpretation [Re: Gebo] #4681237
03/01/18 06:23 AM
03/01/18 06:23 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
boraticus,
If that were the case, the other plug would be blackened too. Look elsewhere.
