Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
Never waxed ???
by SilverGt. 09/23/18 10:55 AM
Plumbing drain question
by wormwood1978. 09/23/18 10:38 AM
Post your euro cars high mileage
by Serge. 09/23/18 09:08 AM
Post your cars high mileage
by Serge. 09/23/18 09:01 AM
Post your latest mileage achievement
by Snagglefoot. 09/23/18 08:23 AM
Field repair by the Mississippi!
by Number_35. 09/23/18 08:18 AM
F150 5.0 Lost power
by hatt. 09/23/18 08:15 AM
Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
70 registered members (barryh, BAJA_05, bdcardinal, advocate, Berny, Al, 8 invisible), 1,816 guests, and 41 spiders.
Topics290,892
Posts4,852,041
Members66,047
Most Online3,590
Jan 24th, 2017
brand x oil is thinner than brand y oil question #4674685
02/22/18 06:40 PM
02/22/18 06:40 PM
WA
OilUzer Offline OP
OilUzer  Offline OP
WA
some background info:
just for kicks i did a test with conventional (dino) oil 5W-30 and 10W-30
put some of each in 2 clear plastic cups and tested both at room/garage temperature (60F) and the refrigerator (38F) and the freezer -2F
the 5W-30 looked thinner in all cases. obviously, the difference was more subtle at room temp vs. the freezer.
i also got my wife involved and she confirmed the results smile
another background info:
In "7.5Wx30 Oil" thread i asked about 50/50 mix of 5W-30 and 10W-30 producing 7.5W ...
kschachn, OVERKILL and others commented and correct me if i am wrong but the conclusion was that:
1-
There is no spec/designation for 6,7,7.5,8W etc. only 0W, 5W, 10W ... at least for auto oil.
sounds like there is 7.5W (another thread) for motorcycles but for thatís beside the point here.
2-
For all practical purposes, it is not practical/feasible/useful to have any classification in between 0,5,10W ...
as a result, 50/50 Mix will no longer meet the 5W spec and most likely be considered a 10W ...
Not wanting to split hair ... i can totally understand the above logic.
another thing leading to my question:
Based on the above logic, let's say that:
company A has an oil that barely misses the 0W spec and gets the Winter classification of 5W
company B (or even company A) has an oil that narrowly makes the 5W spec and is classified as 5W
correct me if i am wrong here but Oil A and B can practically (mathematically?) be 5W (4.9W) apart and both be classified as 5W
now my main question:
when people say brand x 5W-30 is "thinner" than brand y 5W-30 ... is it because of the reason above (oil A vs. B)
or am i over-simplifying things?
Re: brand x oil is thinner than brand y oil question [Re: OilUzer] #4674695
02/22/18 06:50 PM
02/22/18 06:50 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
hide
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: brand x oil is thinner than brand y oil question [Re: OilUzer] #4674707
02/22/18 07:04 PM
02/22/18 07:04 PM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
There are definite ASTM tests that determine which XW-XX viscosity an oil meets. Of course there is a range of numbers at the testing temperatures at each viscosity that would allow one oil to be "thicker or thinner" than other oils at low temps, high temps, and anywhere in between. A graph could be plotted showing a complete viscosity curve if measurements were made for all temperatures in between.
For example, generally a full synthetic high mileage oil can be more viscous at all temps than their non-HM counterparts, yet still have the same viscosity label, such as 5W-30. I believe they are formulated this way to maximize fuel economy for the newer cars (meeting all the current oil specs when a car is new for warranty, etc) but later as the engine begins to consume oil, the HM formulations bump up the viscosity some as one way to slow the consumption and leaks, yet still remain within the 5W-30 specs.
Re: brand x oil is thinner than brand y oil question [Re: OilUzer] #4674789
02/22/18 08:57 PM
02/22/18 08:57 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
Usually in discussion on this site, people like to refer to the HTHSV when distinguishing one oil of the same grade as 'thicker' or 'thinner' than the other oil of the same grade. I don't recall a discussion in reference to the CCS and MRV when discussing 5W and higher varieties; usually those discussing cold viscosity just leave it at "0W grade", and then get into CCS and MRV values of various 0W graded oils to compare cold viscosity.
WRT to splitting W grades, I'm sure it's already been mentioned numerous times that we're talking about a 5 degree Celsius temperature difference in qualification between them, so what insights do you feel can be more readily conveyed in doing so?
Re: brand x oil is thinner than brand y oil question [Re: OilUzer] #4674836
02/22/18 09:52 PM
02/22/18 09:52 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
When I say that one oil is thinner than another, I am referring to the op temp viscosity. I don't really care about what it's like sitting in the driveway (that's what happens when you live in Cali). So I have heavy 30's and light 40's and such in mind. That's where the wear curves are and fuel consumption, etc. At op temp ...
Re: brand x oil is thinner than brand y oil question [Re: OilUzer] #4674915
02/22/18 11:23 PM
02/22/18 11:23 PM
WA
OilUzer Offline OP
OilUzer  Offline OP
WA
if we are talk about "relatively" a thin or thick oil, does it really matter what temp we are sampling it at?
Re: brand x oil is thinner than brand y oil question [Re: OilUzer] #4674921
02/22/18 11:32 PM
02/22/18 11:32 PM
South Carolina
eyeofthetiger Offline
South Carolina
Actually, brand y oil is thinner than brand x oil.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: brand x oil is thinner than brand y oil question [Re: OilUzer] #4675036
02/23/18 04:45 AM
02/23/18 04:45 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
As has been explained ad nauseum in the various recent threads, they are grades, which are band, and performing "mathematical" equations on them is not possible.
e.g
What mathematical process would you use to describe the things that are in the fringe region of Xrays and UV light, or visible light and Infra Red ?
ysult.5 ??
bleinf.5 ??
Re: brand x oil is thinner than brand y oil question [Re: Shannow] #4675058
02/23/18 06:16 AM
02/23/18 06:16 AM
WA
OilUzer Offline OP
OilUzer  Offline OP
WA
e.g
ysult.5 ??
bleinf.5 ??
Thanks for the example, however let's make a simpler analogy. as someone explained in another thread with the grading system:
- student 1 scores 100 on a test and gets an A
- student 2 scores 90 on the same test and gets an A
- student 3 scores 89 on the same test and gets a B
one can argue that:
student #2 soft/thin A is not far from student #3 strong B and for all practical purposes they are almost the same!
To further clarify my question, is it possible that:
- oil A has a true 2.51W which is closer to 5W than 0W so it gets a classification 5W.
- oil B has a true 7.49W which is closer to 5W than 10W and get the same classification of 5W.
oil A and B are 4.98W apart but they are both classified as 5W.
based on that, can you conclude that oil A is a "thinner" 5W than oil B?
I also know that xW classifications jump from 0W to 5W and 10W, etc. and are not infinite and I understand why (it is not practical) but in real world, how can you force the oil/molecules to follow the 0, 5, 10W standard? hence 2.51W or 7.49W in my example.
This was basically my question. Not sure if it works this way and as I mentioned, maybe I am over simplifying or misunderstanding things.
again, I was not trying to reach a conclusion in my original post, it was a question which I thought may? explain the "thinner" oil theory!
Thank you!
Re: brand x oil is thinner than brand y oil question [Re: OilUzer] #4675076
02/23/18 07:13 AM
02/23/18 07:13 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Best double troll act in the history of BITOG...congratulations.
Re: brand x oil is thinner than brand y oil question [Re: Shannow] #4675096
02/23/18 07:54 AM
02/23/18 07:54 AM
WA
OilUzer Offline OP
OilUzer  Offline OP
WA
not sure where this is coming from!!!!
if you feel or think that you are being "trolled", please ignore this discussion.
you don't have to participate!
btw, if it matters to you, it is much easier for me to make an example with the grade system than the visible light spectrum.
someone else just used the grade system in another one of my threads and it was fresh in my mind ...
didn't mean to offend you or criticize your example!
Re: brand x oil is thinner than brand y oil question [Re: OilUzer] #4675113
02/23/18 08:19 AM
02/23/18 08:19 AM
WA
OilUzer Offline OP
OilUzer  Offline OP
WA
and one more thing, I had to lookup "double troll" ... lol
first time I have ever been accused of any trolling let alone "double trolling" smile
I am not an internet guy. I am on VERY few websites (sports & car & recently this oil site) and hardly ever post anything! it goes thru cycles you know ... I am sure my "oil" related interest will die off sooner or later.
since i bought a car that requires 0W-20 i joined this site and got interested in oil ... every time i did a search for 0W20 it took me to BITOG!!!
also this site has tons of other information and I like it! it has become my "go to" web site for anything car related and more.
Re: brand x oil is thinner than brand y oil question [Re: OilUzer] #4675840
02/23/18 08:41 PM
02/23/18 08:41 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
The real answer, or best answer, at least, is that the viscometric properties of a given oil will fall somewhere on SAE J300. Where they fall dictates how the oil is labelled. Certain things are also likely to go hand in hand. A 10w-30 ILSAC, for instance, will exceed the 10w-XX limits fairly handily (but will not meet the 5w-XX limits) and will have a lower HTHS, just above the minimums for the grade. A 10w-30 HDEO will exceed the 10-XX limits much more closely and have an HTHS of 3.5 or higher. So, the 10w-30 ILSAC would already be what you consider a 7.5w-30. Except, however, it's not, because if it's a 10-XX but not a 5w-XX, it has to be labelled as a 10w-XX, and if it's meeting 5w-XX requirements, it has to be labelled as 5w-XX.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: brand x oil is thinner than brand y oil question [Re: OilUzer] #4675848
02/23/18 08:49 PM
02/23/18 08:49 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
one can argue that:
Thank you!
If you want to make those types of distinctions, you can't use the W rating system, period. It's neither designed to, or capable of, conveying anything further about the oil than it's SAE J300 Winter classification.
You can compare oils in the way you want to, but you'll have to use the appropriate data like CCS/MRV/Temperature and possibly VI.
Re: brand x oil is thinner than brand y oil question [Re: PeterPolyol] #4676028
02/24/18 12:24 AM
02/24/18 12:24 AM
WA
OilUzer Offline OP
OilUzer  Offline OP
WA
thank you guys!
it makes sense and kind of reaffirms my original intuition ...
btw, i had to lookup a lot abbreviations you guys throw at me! lol
it makes sense not to use xW rating in my logic!
i was trying to figure out why one 5W oil is different than other 5W (i used the word "thinner") and shouldn't have used the existing standards for my example. it was easier using the xW system to convey my point but i can see that it is not a good analogy (discrete vs. continuous) and xW system is not a continuous system!
i assume we can conclude that:
basically if 2 oils are pigeonholed into a given grade/classification, it doesn't make them equal!
