DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Rollo, Drifted, Jcar516, gregjr7, daveed
67613 Registered Users
90 registered members (2010Civic, 2015_PSD, 4WD, ArrestMeRedZ, aleneros, ammolab, 10 invisible), 1,701 guests, and 60 spiders.
Topics286,361
Posts4,907,079
Members67,613
Most Online2,967
Mar 10th, 2019
Switching Oil viscosity giving Quicksilver a try #4674504
02/22/18 02:54 PM
02/22/18 02:54 PM
CA
ad244 Offline OP
ad244  Offline OP
CA
Hey BITOG riders. I recently picked up some quarts of Quicksilver 20w-50 Full synthetic on clearance from Wallys World for $5.00 a quart with the intent of running it in my bike. The bike in question is my trusty 2001 Honda XR650R, the water cooled thumper. Traditionally I have always run Rotella T5 (??) 15w-40 in the bike and it has really done fine thus far (may be the motto of this thread). I ride the bike in the deserts of southern California year round in the heat of the desert where 100+ degrees are not uncommon. It is not uncommon for the coolant overflow bottle to boil its contents during tight single track and long hill climbs as the bike does not have any radiator fans (Next project).
Honda Recommends: Oil change every 600 miles, 10W-40 or 20W-50 are specified however synthetic is not. I typically change it every 30 or so hours as the bike does not have an odometer.
I still have a good stash of the Rotella so more than likely I will hold off on trying the Quicksilver until summer hits however have any members on here given this oil a go in a big bike? My Honda has recently had the top end replaced by my mechanic so I couldnt get a good look of the internals however from what he said, there dont seem to be any issues with internal wear/ damage from the Rotella. I am ideally looking for just more protection and peace of mind running the thicker stuff in the old bike.
I appreciate any feedback and insight from members who have used the Quicksilver oils in the past.
Cheers, Dave!
Re: Switching Oil viscosity giving Quicksilver a try [Re: ad244] #4674518
02/22/18 03:04 PM
02/22/18 03:04 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Really good oil. Good on you smile
I run 25W-40 in stuff from time to time. Mostly boat engines. Works great in BBC's running V drives in flat bottoms laugh
Re: Switching Oil viscosity giving Quicksilver a try [Re: ad244] #4674534
02/22/18 03:21 PM
02/22/18 03:21 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
I'll be interested to hear if it works just as well. I've been looking to run a similar weight in my bikes.
Re: Switching Oil viscosity giving Quicksilver a try [Re: ad244] #4674678
02/22/18 06:34 PM
02/22/18 06:34 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
Does your bike have a wet clutch? If so, you might want to be concerned about the possibility that some oils can have additives that make them too slippery for a wet clutch.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Switching Oil viscosity giving Quicksilver a try [Re: BrocLuno] #4674704
02/22/18 07:03 PM
02/22/18 07:03 PM
CA
ad244 Offline OP
ad244  Offline OP
CA
Thank's for the good discussion guys
Oh very cool! Where do you purchase your 25W-40 from, I've never hear of an oil meeting that viscosity although Im pretty new to the oil enthusiast community. I would be interested to hear about boat engine oil temperatures since it is my understanding their cooling system is fed by the ambient water (usually below 80 degrees F) Id imagine they run a bit cooler?
I assume BBCs running V Drives are a pretty powerful set up, at least it sounds impressive!
I believe this is a rated Motorcycle oil, It is not an energy conserving oil just like the Rotella I have been using. Yes to answer your question though, the bike is indeed a wet clutch set up and I have always tried to be mindful of my oil chose in regards to the clutch set up. I had a Yamaha FZ1 years back and it would Sheer Rotella T6 in 800 Miles or so. May have something to do with the 110 horsepower and my happy wrist!
Re: Switching Oil viscosity giving Quicksilver a try [Re: ad244] #4674727
02/22/18 07:33 PM
02/22/18 07:33 PM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
Do you have the owners manual?
My 2002 CBR 600 F4i gives me a range. 10w40 being the preferred.
In my 3.5 quart sump I'm running 2qts of conventional Valvoline MC 20W50 and 1.5 quarts of Valvoline MC 10W40. My bike has been fine and has 27k miles on it
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: Switching Oil viscosity giving Quicksilver a try [Re: JeepWJ19] #4674946
02/23/18 12:09 AM
02/23/18 12:09 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Saw thiese at Wally World in Calgary. Theyve been sitting there since the summer.
If you want the job done right......do it yourself.
Re: Switching Oil viscosity giving Quicksilver a try [Re: ad244] #4675080
02/23/18 07:20 AM
02/23/18 07:20 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
There seems to be some confusion in this thread.
AD244 didnt post what kind of Quicksilver 20/50 oil he purchased but we can assume its Quicksilver Motorcycle oil. (they also make an atv oil I believe plus many, many, many specialized marine lubricants.
Some background.
Quicksilver is the lubrication division of Mercury Marine.
In the decades of boating experience, their Marine Lubricants are top notch in my book.
They make many specialized marine lubricant products and I have found them to always be superior to "after market" products.
These products consist of corrosion inhibitors, cable lubricants, gear oils, engine oils, everything under the sun and rock solid products.
A few years back they came out with other synthetic power sports lubricants at very reasonable prices, if they carried over the same quality as their marine lubricants isnt proven but I certainly would not hesitate to use the power sports lubricants.
Their Main conventional MARINE ENGINE OIL is 25/40 with a claimed no viscosity improver. I would not use this in a motorcycle, though I guess it could do no harm. This oil carries no automobile oil rating, just marine.
Then there is the "new" power sport market of which is Quicksilver 20w50 motorcycle oil among another ATV branded oil. Of course if you are using the motorcycle oil there is absolutely no concern about it being compatible with your wet clutch.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Switching Oil viscosity giving Quicksilver a try [Re: ad244] #4675124
02/23/18 08:31 AM
02/23/18 08:31 AM
Snagglefoot Offline
Snagglefoot  Offline
Ok. For clutch protection, try this.
Re: Switching Oil viscosity giving Quicksilver a try [Re: Snagglefoot] #4677006
02/24/18 10:24 PM
02/24/18 10:24 PM
Kentucky
cardsrok Offline
cardsrok  Offline
Kentucky
I use this in my 07 Honda Rincon. I can't find it in any local stores. only online.
Re: Switching Oil viscosity giving Quicksilver a try [Re: ad244] #4677320
02/25/18 09:04 AM
02/25/18 09:04 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
No idea on their MC lubes, but boat engines shear their marine "no VI" 25W-40 pretty easily.
Boats have the advantage of an unlimited supply of cool water, but the oil temps can get ridiculous due to the constant load and rpm. Some engines have very efficient, very large oil coolers. Some have oil coolers that are very small, and some have none at all.
Re: Switching Oil viscosity giving Quicksilver a try [Re: DoubleWasp] #4677331
02/25/18 09:11 AM
02/25/18 09:11 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
You have posted this a number of times so do you question it not having VM in the additives package?
25w40 would just seem like a mono oil. What is shearing?
Re: Switching Oil viscosity giving Quicksilver a try [Re: 4WD] #4677452
02/25/18 11:18 AM
02/25/18 11:18 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Shearing is when a 40 weight oil "shears" down to a 30 weight oil ect.
However its meaningless to judge an oil on shearing only, more so in a forum without any proof, a UOA and the engine make and model.
Just hearsay but no factual helpful information as far as your particular vehicle, your vehicle engine design and type of use is responsible how much your oil shears but some will look towards an oil to help make up for engine design and some oils will be better to handle it, in theory ...
So I question any post that states any particular oil shears easy, even more so when an oil states it is designed to be more shear stable..
07 Suzuki C50
Re: Switching Oil viscosity giving Quicksilver a try [Re: alarmguy] #4678271
02/26/18 12:03 AM
02/26/18 12:03 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
Not asking the definition read where Im saying there is no VM. So those molecules are not there to rupture and then never assist the return to spec viscosity range. Im asking what has sheared in 25w40 that some here accept to be VM free (mono) ... (shear stable) in other words the 25w is just coincidental in whats really a warm weather lubricant
If oil thins due to excessive temperatures and other and then returning to spec at STP has it really sheared?
Re: Switching Oil viscosity giving Quicksilver a try [Re: alarmguy] #4678697
02/26/18 01:43 PM
02/26/18 01:43 PM
CA
ad244 Offline OP
ad244  Offline OP
CA
Some background.
Wow! Hi Alarm Guy. Thank you very much for you extremely informative post above. Lots of great information there!
Indeed I have purchased the 20W-50 motorcycle oil which is indeed wet clucth compatable. I'm sorry for not clarifying this as I was simply unaware that Mercury Marine made so many different flavors of oil including powersports oil.
[img:left]https://i5.walmartimages.com/asr/d8bb4f5...mp;odnBg=FFFFFF[/img]
I am glad to hear that this oil is very well regarded and I will be interested to see if it makes the engine run smoother for the kind of riding that I enjoy doing. Its a clackity 4 Valve thumper so maybe it will quiet it up a little bit? Even if it doesn't it will provide a little more piece of mind.
Thank you again!
