71141 / Lifeguard 5
by chefwong. 12/18/18 07:52 PM
Tested Positive for Flu
by john_pifer. 12/18/18 07:37 PM
Cooper RTX?
by 01rangerxl. 12/18/18 07:25 PM
IPhone SE or flip phone?
by 53' Stude. 12/18/18 05:49 PM
1993 K1500 hard cold start
by BrianF. 12/18/18 05:43 PM
Put my wife's dog down yesterday
by Stelth. 12/18/18 05:04 PM
ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
O2 sensor B1S1 no voltage??
by David1. 12/18/18 03:43 PM
Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
Sportbiker, trollhattan, MuhThugga, wxo, dbierman
66718 Registered Users
117 registered members (aba4430, -SyN-, 2009Edge, AandPDan, 69Torino, 01rangerxl, 15 invisible), 1,951 guests, and 35 spiders.
Topics295,236
Posts4,930,678
Members66,718
Most Online2,553
Oct 27th, 2018
2015 Yaris oil recommendation #4674461
02/22/18 01:29 PM
02/22/18 01:29 PM
MNE
BIMMA Offline OP
BIMMA  Offline OP
MNE
I just got a 2015 Yaris 1.33 1NZ-FE engine with 5000 miles.
What would be the best oil/grade for this engine?
I already have 4 qts of M1 0W20 EP.
I have a couple more options, like Castrol Edge 0W30, Castrol Edge 5W30, M1 ESP 5W30.
So what you think?
I appreciate your help.
2007 Lexus ES350 2GR-FE Mobil 1 5W30 EP w/OEM filter;
2015 Toyota Yaris 1NZ-FE Mobil 1 0W20 EP w/OEM filter;
Re: 2015 Yaris oil recommendation [Re: BIMMA] #4674470
02/22/18 01:33 PM
02/22/18 01:33 PM
orlando fl
tojo1968 Offline
tojo1968  Offline
orlando fl
Good cars. A co worker also does courier work and has gotten over 300k out of his first 2.
What does the manual say about what to use. I would think in Michigan any brand name 0/20w, 5/20w or 0/30w would work well.
2016 Frontier SL Crew Cab
Re: 2015 Yaris oil recommendation [Re: BIMMA] #4674472
02/22/18 01:35 PM
02/22/18 01:35 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
I've been using mostly Mobil 1 0W-20 for nearly all the miles on mine. No issues and no excess consumption.
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: 2015 Yaris oil recommendation [Re: BIMMA] #4674482
02/22/18 01:39 PM
02/22/18 01:39 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
What does you manual recommend? start from there
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2015 Yaris oil recommendation [Re: BIMMA] #4674495
02/22/18 01:45 PM
02/22/18 01:45 PM
PimTac Offline
PimTac  Offline
There is no best oil. Pick any major brand that meets the specs in your owners manual and run with it.
Cannot see signatures any longer so it doesn’t matter.
Re: 2015 Yaris oil recommendation [Re: BIMMA] #4674523
02/22/18 02:12 PM
02/22/18 02:12 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
ive been using pennzoil 5w30
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: 2015 Yaris oil recommendation [Re: BIMMA] #4674674
02/22/18 05:31 PM
02/22/18 05:31 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
Yes, good engine.
Is the factory warranty still in effect; if so, using the recommended 5w-30 might be the way to go
I will be using Amsoil ASL (5w-30) with 1 year intervals when I dump the dealer installed Subaru oil.
Not many miles for 3-4 year old car.
2004 Prius; 102K; ASL
2007 Yaris 78K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: 2015 Yaris oil recommendation [Re: kschachn] #4674682
02/22/18 05:38 PM
02/22/18 05:38 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Just noticed that you really have a lot of miles on your rides. Way to go!! thumbsup
2007 Ford Fusion 235,000 miles
M1 0-20 EP
2017 Ford Fusion 61K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 2015 Yaris oil recommendation [Re: simple_gifts] #4674705
02/22/18 06:04 PM
02/22/18 06:04 PM
MNE
BIMMA Offline OP
BIMMA  Offline OP
MNE
Originally Posted By: simple_gifts
Yes, good engine.
It was locked in a garage and not driven, maybe 1000-1500 miles a year and never been serviced and that means no warranty so I’m free.
So I got the OEM filter and tomorrow is day D.
Re: 2015 Yaris oil recommendation [Re: BIMMA] #4676287
02/24/18 09:42 AM
02/24/18 09:42 AM
NH
supton Offline
supton  Offline
NH
Has Toyota ever made an engine that was picky about what oil it needed to use?
2011 Toyota Camry, base, 2.5L/6MT, 170k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 144k, ours
1999 Toyota Camry LE, 2.2L/4AT, 195k, his
Re: 2015 Yaris oil recommendation [Re: BIMMA] #4677197
02/25/18 02:58 AM
02/25/18 02:58 AM
MNE
BIMMA Offline OP
BIMMA  Offline OP
MNE
After this oil change (M1 EP 0W20/OEM filter) I can hear a lotta ticking noise on idle. The low pressure light goes off immediately. Is this something I should worry about it?
P.S. this was her first oil change (8200 km).
Re: 2015 Yaris oil recommendation [Re: BIMMA] #4677363
02/25/18 08:40 AM
02/25/18 08:40 AM
ne atlantic coast & sw desert
jstert Offline
jstert  Offline
isnt 0w20 a bit thin? my sw desert snowbird yaris 1.5 requires 5w or 10w30 (im away at the moment and can’t check owner’s manual). im doing 18 month/3k mile oil changes on mine, will do the best change that i can find at a shop for $25. my last change was kendall semi syn 10w30.
2013 vw passat s
2014 toyota yaris l
Re: 2015 Yaris oil recommendation [Re: BIMMA] #4677713
02/25/18 01:56 PM
02/25/18 01:56 PM
Canada
addyguy Offline
addyguy  Offline
Canada
The Yaris 1.5L engine is a lot harder on oils than other Toyota engines. It revs harder, and earlier versions of the engine often 'burn out the rings' and start consuming oil.
Tercels were the worst; Echo's were a bit better; Yaris better still. I'd use 5W-30 oil; and keep the changes short.
2010 Kia Soul 2U - 2.0L I-4, auto; 137k miles.
M1 EP 10W-30; OEM Kia filter.
Re: 2015 Yaris oil recommendation [Re: addyguy] #4677718
02/25/18 01:59 PM
02/25/18 01:59 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
If you say so but I've found it to be quite benign, obviously much more so than my 1MZ-FE. Mine has been running fine on 0W-20 for well over 150,000 miles now and hardly any more consumption than when it was new. And trust me, I rev it out a lot considering it's usually necessary to do so.
1994 BMW 530i, 238K
Re: 2015 Yaris oil recommendation [Re: BIMMA] #4678400
02/26/18 06:15 AM
02/26/18 06:15 AM
MNE
BIMMA Offline OP
BIMMA  Offline OP
MNE
Mine is 1.33 euro version.
