Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
84 registered members (Aero540T, 02z, ABomb369, AandPDan, 928, -SyN-, 3 invisible), 1,390 guests, and 33 spiders.
Topics290,812
Posts4,850,855
Members66,040
Most Online3,590
Jan 24th, 2017
Any 2015 Corolla owners here - coolant change Q #4674366
02/22/18 01:20 PM
02/22/18 01:20 PM
co
NissanMaxima Offline OP
co
Hi all:
I have a 2015 Corolla bought new. I believe it is 11th generation (2013+). At some point, I want to do a drain and refill with the genuine Toyota pink fluid. However, does anyone know if there are engine bleeder bolts to mess with and if there is any sequence you need to perform with the heat/ac control system to open valves etc? I'm hoping it is a simple matter of opening the petcock to drain, slowly refilling to avoid air bubbles, and then running with radiator cap off till fully warmed to burp any air. I don't have the service manual for this car (can you even buy these anymore?) and the owner's manual has no information on this DIY item. (Why don't they just give you some instructions how to do these simple things anymore? My 1995 Maxima manual has detailed info on coolant and oil changes!)
Re: Any 2015 Corolla owners here - coolant change Q [Re: NissanMaxima] #4674379
02/22/18 01:27 PM
02/22/18 01:27 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
I don't mess with bleeder bolts or worry about valves. Just drain the radiator and refill. Let it run and top off. That's what I plan to do on my 2015 Camry.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
Re: Any 2015 Corolla owners here - coolant change Q [Re: NissanMaxima] #4674388
02/22/18 01:36 PM
02/22/18 01:36 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
How many miles are on it? Coolant should be good till the 100k service.
If its clean and no build up then drain radiator, jack front end up a little, add new coolant, then put cap back on and go for a short test drive. After it cools off after the drive then top off as needed.
yup
Re: Any 2015 Corolla owners here - coolant change Q [Re: NissanMaxima] #4674409
02/22/18 01:52 PM
02/22/18 01:52 PM
CA
The Critic Offline
The Critic  Offline
CA
There is an inline bleeder valve on the Prius version of the 2zr-fe. On the Prius, the valve is located near the master cyl area.
I usually vacuum fill these systems.
2011 Toyota Prius - 173k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 131K - Mobil 1 EP HM 5W-30
Re: Any 2015 Corolla owners here - coolant change Q [Re: NissanMaxima] #4674419
02/22/18 02:02 PM
02/22/18 02:02 PM
co
co
Thanks all:
Just over 40k on it now and was planning on doing around 50k or 60k. My Maxima has bleeder bolts but based on experiences on one of the Nissan forums, I never tried to open them and always had good luck with just drain and refill (super slow trickle with my big funnel) and then letting warm up with radiator cap off till fans come on and slightly rev engine a few times. However, my Maxima owner's manual did have a procedure where you hold down buttons on the heater/ac control till a certain code turns on presumably to open some valves so that was my main "concern".
Re: Any 2015 Corolla owners here - coolant change Q [Re: NissanMaxima] #4674431
02/22/18 02:09 PM
02/22/18 02:09 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Those Corollas can take hours to bleed. Run it till its warm,turn it off and walk away for a couple of hrs. Repeat.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Any 2015 Corolla owners here - coolant change Q [Re: Chris142] #4674438
02/22/18 02:15 PM
02/22/18 02:15 PM
CA
The Critic Offline
The Critic  Offline
CA
Try a vacuum filler. I can get those systems filled in 2 min and bled in 20 min every time.
Re: Any 2015 Corolla owners here - coolant change Q [Re: NissanMaxima] #4674453
02/22/18 02:22 PM
02/22/18 02:22 PM
co
co
Hi Critic: Do you have a recommendation? I did see a recommendation for a vacuum filler on the Coolant forum but it required shop air which I don't have.
Re: Any 2015 Corolla owners here - coolant change Q [Re: NissanMaxima] #4674456
02/22/18 02:25 PM
02/22/18 02:25 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Originally Posted By: NissanMaxima
Thanks all:
Why so early? There's no need for that.
Re: Any 2015 Corolla owners here - coolant change Q [Re: Leo99] #4674476
02/22/18 02:38 PM
02/22/18 02:38 PM
co
co
Thanks all:
I know the previous red Toyota coolant was long life, but I wasn't sure about the pink version. 100k seems really long to me regardless.
Re: Any 2015 Corolla owners here - coolant change Q [Re: NissanMaxima] #4674517
02/22/18 03:04 PM
02/22/18 03:04 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
Thanks all:
100k is perfectly fine for that car and coolant. No reason to do it IMO.
yup
Re: Any 2015 Corolla owners here - coolant change Q [Re: NissanMaxima] #4675699
02/23/18 06:09 PM
02/23/18 06:09 PM
CA
The Critic Offline
The Critic  Offline
CA
I would just follow the instructions in the repair manual. It may take some time, but filling this car conventionally should still work.
