How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
95 registered members (aquariuscsm, 1978elcamino, 69Torino, 4WD, 94astro, 9 invisible), 2,288 guests, and 59 spiders.
Topics286,018
Posts4,900,861
Members67,548
Most Online2,967
Mar 10th, 2019
Intake manifold bolts torque 11ft lb #4674233
02/22/18 11:55 AM
02/22/18 11:55 AM
IL
Ndx Offline OP
Ndx  Offline OP
IL
Hey,
I have torque down intake manifold bolts to 11 ft lb
My torque wrench starts at 10 ft lb ...
https://www.cpooutlets.com/platinum-tools-c2fr50f-3-8-in--drive-10---50-lbs-ft--split-beam-click-wrenches/prenc2fr50f,default,pd.html#xsell=prenc2fr50f--2
I guess I should look for a different one for this job ? I know that they are not very accurate at low scale.
Thank you
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674237
02/22/18 11:57 AM
02/22/18 11:57 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Maybe an inch - pound torque wrench & do the math conversion ?
Best of luck , :-)
Wyr
God bless
Re: Intake manifold bolts torque 11ft lb [Re: WyrTwister] #4674256
02/22/18 12:09 PM
02/22/18 12:09 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
Best of luck , :-)
If you can multiply by 12!
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674265
02/22/18 12:14 PM
02/22/18 12:14 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
If you are + 20% should be fine.
Manifold What on?
Story: I recall snapping the cam box bolts on my GF Suzuki 500 doing a valve lash adjustment. Torque to yield.
I had a short ratchet and I was even choked on it up near the head - just running the bolts down PRIOR to torqueing them. Never ran into this situation before with American made engines.
At least I could get (what was left of)them out of the casting with my bare fingers since the threads in the casting werent distorted.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674403
02/22/18 01:48 PM
02/22/18 01:48 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
132 inch pounds should be pretty close...
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674404
02/22/18 01:48 PM
02/22/18 01:48 PM
CA
The Critic Offline
The Critic  Offline
CA
Torque wrenches are generally accurate from 20%-100% of the specified range.
You need to buy a new torque wrench, probably an inch lbs one.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674406
02/22/18 01:51 PM
02/22/18 01:51 PM
IL
Ndx Offline OP
Ndx  Offline OP
IL
Its plastic intake manifold going to alu block ...
Do you guys think that those cheap princess auto torques are suitable for this ?
https://www.princessauto.com/en/detail/1-4-in-dr-digital-torque-wrench/A-p8381477e
or this ?
https://www.princessauto.com/en/detail/1-4-in-dr-click-type-torque-wrench/A-p8653990e
should I compensate for 1/4 to 3/8 adapter ?
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674412
02/22/18 01:54 PM
02/22/18 01:54 PM
California
nthach Online content
nthach  Online Content
California
I think you should be OK, especially if the bolts are to be coated with a anaerobic sealant. Get a different torque wrench in in-lbs for those smaller bolts. I use a bike torque key set at 5Nm for smaller screws that the OEM calls for low torque on.
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674439
02/22/18 02:15 PM
02/22/18 02:15 PM
IL
Ndx Offline OP
Ndx  Offline OP
IL
bolts are going dry ...
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674443
02/22/18 02:16 PM
02/22/18 02:16 PM
San Antonio, TX
das_peikko Online content
das_peikko  Online Content
San Antonio, TX
You need an inch pound torque wrench with a range of about 30-200 inch pounds for that job.
http://www.torqwrench.com/tools/item.php?StockCode=M1R200HX
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674450
02/22/18 02:19 PM
02/22/18 02:19 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Get an in-lb torque wrench. prob 1/4 drive
preferably not a princess auto power fister.
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674451
02/22/18 02:19 PM
02/22/18 02:19 PM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
Just do them up by hand...
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674489
02/22/18 02:41 PM
02/22/18 02:41 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Use an inch pound wrench, set it at 132inlb.
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674490
02/22/18 02:42 PM
02/22/18 02:42 PM
California
California
I've been happy with this, but eventually I do want to upgrade to nicer.
https://www.harborfreight.com/14-in-drive-click-type-torque-wrench-61277.html
Re: Intake manifold bolts torque 11ft lb [Re: Ndx] #4674499
02/22/18 02:50 PM
02/22/18 02:50 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
or this ?
PA's Pro Point brand is probably the highest quality available in a big box store around here in Toronto. All of the stuff I have seen is Taiwan made, nicely finished and beefy. I understand why some people argue USA made = Taiwan made > China made when I handle their tools.
I would use it without hesitation.
EDIT: Would a adapter not distort the torque readings?
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
