List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
Never waxed ???
by SilverGt. 09/23/18 10:55 AM
Plumbing drain question
by wormwood1978. 09/23/18 10:38 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
94 registered members (Al, BigCahuna, 55hambone, alchargo, Bman90, 53' Stude, 11 invisible), 1,783 guests, and 38 spiders.
Topics290,898
Posts4,852,112
Members66,047
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
High Mileage Transmission Change #4674196
02/22/18 11:13 AM
02/22/18 11:13 AM
Michigan
toreytlow Offline OP
Michigan
I have a 2006 Chevy Impala with 140k miles. It has never had the transmission fluid flushed or changed. I am not having any apparent issues with my transmission, however the fluid on the dipstick is a light to medium brown; similar to a new motor oil color.
My question is, Should I drain and fill the pan, and replace the filter? Or will this possibly cause an accelerated wearing of what is left of my transmission? I called over 10 transmission shops in the area, and I received a wide array of answers which included:
A. DO NOT GET A FLUSH NO MATTER WHAT (this was advice from most every shop.)
B. Get your pan drained and filled (those who said this, said that the idea that a change accelerates the wearing process only applies to older vehicles. This just doesnt seem right to me.)
C. At least 5 different people advised that at 140k miles, I should just leave it alone if it is working fine now. They said that emptying any of the fluid that has clutch material suspended in it and replacing it with clean fluid could cause slipping, because the clutch pads no longer have the friction material on them OR in the fluid surrounding them.
PLEASE HELP!!!!
Re: High Mileage Transmission Change [Re: toreytlow] #4674201
02/22/18 11:19 AM
02/22/18 11:19 AM
Illinois, U.S.A
RamFan Offline
RamFan  Offline
Illinois, U.S.A
I'd drop the pan and change the fluid/filter. Or get a Mityvac and do a simple fluid exchange. I dropped the pan in our Monte at around 130k miles on it and the pan was almost spotless. I think changing a trans filter is kind of a thing of the past, they just are soooo much cleaner than they once were.
This is all my opinion though, no science to back it up.
18 Giulia Ti Sport
+2.0l turbo - Factory fill & filter
16.5 CX-5 Touring
+2.5l - 48k - SynPower w/ Maxlife 0w20 - PureOne - 8k/1yr
Re: High Mileage Transmission Change [Re: toreytlow] #4674204
02/22/18 11:19 AM
02/22/18 11:19 AM
California
Billbert Offline
Billbert  Offline
California
You should drop the pan and change the filter before problems start. transmissions do not like to be starved of fluid by a clogged filter.
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
Re: High Mileage Transmission Change [Re: toreytlow] #4674217
02/22/18 11:36 AM
02/22/18 11:36 AM
USA
oldhp Offline
oldhp  Offline
USA
+1 on pan drop, change filter, refill. Maybe go 2500 miles suck the fluid out and refill again.
Re: High Mileage Transmission Change [Re: toreytlow] #4674225
02/22/18 11:45 AM
02/22/18 11:45 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Here are my two cents.
Drain and fill first and see what the results are. If all is ok, then wait a bit maybe 3000 miles or whatever time you feel comfortable with. Then drop the pan and clean the pan and change the filter and refill.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: High Mileage Transmission Change [Re: toreytlow] #4674240
02/22/18 11:59 AM
02/22/18 11:59 AM
Vermont
littleant Offline
littleant  Offline
Vermont
I would do a fluid and filter change. Agree on not doing a flush.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: High Mileage Transmission Change [Re: toreytlow] #4674241
02/22/18 12:00 PM
02/22/18 12:00 PM
US
JLTD Online shocked
JLTD  Online Shocked
US
Definitely NO flush. At 140k I like the mityvac method, remove a 1/2 quart every couple of weeks and replace. Eventually it will be all new fluid. Drive that way awhile, then do a pan drop, filter change and refill. Then repeat the pan drop/filter routine every 30-50k.
I'm a thickie; but a 20 has its place.
I use AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 41k, OE 5w20/Wix
Re: High Mileage Transmission Change [Re: JC1] #4674243
02/22/18 12:01 PM
02/22/18 12:01 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
+1
If there is eventual eventual slippage from worn clutches there are probably safe Lubeguard additives to give you some "grip" back. Ensure you put the correct fluid back into the vehicle.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: High Mileage Transmission Change [Re: toreytlow] #4674252
02/22/18 12:05 PM
02/22/18 12:05 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Pretty much what everyone else said. The transmission shops don't like to do it because they're afraid if there are problems later you are going to blame them.
Re: High Mileage Transmission Change [Re: toreytlow] #4674270
02/22/18 12:18 PM
02/22/18 12:18 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Transmissions like clean , pink / red fluid of the correct specification .
Our little red Chevy Sonic has no dip stick and no DIY serviceable transmission filter . Thank you , GM , twice ! :-(
It does have a little drain plug on the bottom . I have done a drain and fill twice . May do another one , when the weather warms up .
With no user serviceable filter , I DO NOT want the internal filter to stop up !
Wyr
God bless
Re: High Mileage Transmission Change [Re: toreytlow] #4674299
02/22/18 12:32 PM
02/22/18 12:32 PM
Georgia
Charlie2015 Online content
Charlie2015  Online Content
Georgia
Drop the pan, change the filter, and add back new fluid - but only if you have enough money in your bank account for a replacement transmission. Right now, your transmission is working fine. As soon as you start messing with it, you have no idea if it is going to run better or worse.
1998 Honda Accord EX 2.3L Auto
2009 Scion TC Manual
Re: High Mileage Transmission Change [Re: Charlie2015] #4674309
02/22/18 12:38 PM
02/22/18 12:38 PM
Michigan
Michigan
First off, thanks to everyone for the advice. To add onto this Charlie, the kbb value of my car in the area and condition is right around $3-3.5k. With this mileage, am I better off rebuilding the trans if it goes, or using that money towards a different used car? Sorry, this is my very first and only vehicle!!!
Re: High Mileage Transmission Change [Re: toreytlow] #4674322
02/22/18 12:45 PM
02/22/18 12:45 PM
Florida
Artem Offline
Artem  Offline
Florida
Do a simple drain and fill with proper spec fluid (preferably OEM, since it was good for 140k miles.
If the transmission is in good health, it will only benefit from fresh fluid providing the proper spec of slip and protection.
If the tranny is about to expire anyway, well... you've got bigger problems. LOL
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: High Mileage Transmission Change [Re: toreytlow] #4674334
02/22/18 12:51 PM
02/22/18 12:51 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
Put me in the leave it alone camp.
2018 Challenger SRT
Re: High Mileage Transmission Change [Re: dishdude] #4674340
02/22/18 12:57 PM
02/22/18 12:57 PM
Michigan
Michigan
Could you please explain why you would choose to leave it alone?? Thanks!
Torey
Page 1 of 3 1 2 3
