Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
PARTS PLUS PH 2876 CUT OPEN
by 53' Stude. 04/17/19 06:18 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
40 registered members (Bailes1992, billt460, A1O, Billbert, bbhero, 6 invisible), 643 guests, and 25 spiders.
Topics287,672
Posts4,932,028
Members67,838
Most Online2,967
Mar 10th, 2019
Amsoil and light weight oil #4674135
02/22/18 09:38 AM
02/22/18 09:38 AM
California
Bullwinkle007 Offline OP
California
https://youtu.be/ynRkA0-Q8lk
By 0/20. I'll follow Honda uk oil weights for the same engine. Which states I can use a 0/40
Re: Amsoil and light weight oil [Re: Bullwinkle007] #4674195
02/22/18 11:11 AM
02/22/18 11:11 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
2013 video, but use what you like.
18 KIA Sportage 2.4 AWD
M1HM 10W-30, OE
13 Hyundai Santa Fe Sport 2.0T
PP EuroL 5W-30, OE
Re: Amsoil and light weight oil [Re: Bullwinkle007] #4674208
02/22/18 11:26 AM
02/22/18 11:26 AM
California
California
Yes from 2013,I did a test at home, I took a hot frying pan, put some RP 0/20 in, it caught fire after about 1.5 min. Then I took some dino Napa 10/30, it just smoked like a blown racing engine. I need to redue this experiment and record actual temps,
My particular Honda with a 5sp manual, the engine turns 3000 rpm cruising 80mph, 3500rpm at 90. Now that produces more heat say the 5sp auto model at that same speed cruising under 2500rpm. In the summer where I live, not uncommon for 100 plus outside.
European cars run heavyweight oils for a reason. BMW m cars use 10/60, others are 5/40, 0/40, why? Because they know it offers more protection than a light oil. There's only 1 reason for light oil, gas mileage. I could care less if I lose one or two miles per gallon if I know I will gain far more and protection of the engine
How can Ford Chevy Toyota say use a 0 20 oil in a V8 then go pull heavy loads and that pickup truck and expect that engine to last three four hundred thousand miles running a thin light weight oil.
If you take a car on the race track say the Corvette they recommend 530 for daily use but on the track use 15/50. Because they know the 5/30. Will be stretched Beyond its limits oil temp gets hot and you putting extreme stress on it so if you run a 15/50 1 South oil gets hot it will probably send down somewhere near 30 weight. Why do you think Chevy says go back to a 530 on a non track day? Because they want to continue to achieve their fuel mileage numbers and Cafe.
Re: Amsoil and light weight oil [Re: Bullwinkle007] #4674215
02/22/18 11:35 AM
02/22/18 11:35 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Ah yes, the ever popular frying pan test. You observed the auto-ignition temperature of the oil, can you explain how that relates to blowing engines or anything else? Is the auto-ignition temperature related to CAFE?
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 410K
2000 Toyota ECHO, 280K
Re: Amsoil and light weight oil [Re: Bullwinkle007] #4674234
02/22/18 11:55 AM
02/22/18 11:55 AM
Indiana
farrarfan1 Offline
farrarfan1  Offline
Indiana
This same thick vs thin rhetoric gets repeated over and over by new members all of the time. Just fill your Honda with 10W60 or 15W50 and be happy that your engine will outlast all of the ones maintained by ignorant, misguided owners who are using the recommended weight.
If laughter is the best medicine, then why do sick people go to doctors instead of comedians?
Re: Amsoil and light weight oil [Re: farrarfan1] #4674287
02/22/18 12:26 PM
02/22/18 12:26 PM
California
California
1. Oil recommendation is just that. It relates to Cafe bc they need to meet government standards. They could care less how long you keep it for. The mfg would prefer you buy another one.
I drove my 04 camry to 350k. I replaced it bc it was rear-ended. It burned some oil, I ran shell T6 in that. 5/40. No issues what so ever.tried 5/20. It went through that no problem. Recommendation for that year was 5/30. I feel ACEA rated oils are far superior to API. Just because I'm new here does not mean I do not have knowledge I don't understand theory and logic.
Re: Amsoil and light weight oil [Re: Bullwinkle007] #4674296
02/22/18 12:31 PM
02/22/18 12:31 PM
Minnesota
JoelB Offline
JoelB  Offline
Minnesota
What do you think you're gaining going to the thicker oil exactly? Longer engine life?
Mine: 2019 Chevy spark 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Wife's: 2018 Chevy spark 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Re: Amsoil and light weight oil [Re: Bullwinkle007] #4674308
02/22/18 12:37 PM
02/22/18 12:37 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
So how is auto-ignition temperature related to longevity or CAFE?
1994 BMW 530i, 241K
Re: Amsoil and light weight oil [Re: JoelB] #4674310
02/22/18 12:38 PM
02/22/18 12:38 PM
California
California
In theory you will gain longer life, 0/20 hths is 25%:less than a 0/40, vi is also hi. Around 180. Also found higher levels of zinc and prosperous, without having to pay for the higher cost of Redline and RP
Corvette recommends a 5/30. Track use 15/50. So theirs no issues using a 0/40 in my case when the mfg says it's fine in UK, and au, same engine. HP is different obviously bc of tuning and grades of gas. I could make more power running vp racing street 100, and only bc it's better than CA pump gas
Re: Amsoil and light weight oil [Re: Bullwinkle007] #4674316
02/22/18 12:41 PM
02/22/18 12:41 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
In theory you will gain longer life, 0/20 hths is 25%:less in a 0/40, vi is also hi. Around 180. Also found higher levels of zinc and prosperous, without having to pay for the higher cost of Redline and RP
I love high levels of prosperous. Go for as high as you can get.
1994 BMW 530i, 241K
Re: Amsoil and light weight oil [Re: Bullwinkle007] #4674327
02/22/18 12:46 PM
02/22/18 12:46 PM
Minnesota
JoelB Offline
JoelB  Offline
Minnesota
As long as you understand that this is all just speculation and your engine may or may not last longer on the thicker oil, then more power to you.
In reality modern engines that have been maintained last so long that none of this really matters so you might as well have fun. But I wouldn't condemn a thinner oil as being inadequate for your uses.
Mobil 1 0w20 AFE
ACDelco UPF64R
Mobil 1 0w20 AFE
ACDelco UPF64R
Re: Amsoil and light weight oil [Re: Bullwinkle007] #4674352
02/22/18 01:06 PM
02/22/18 01:06 PM
Indiana
farrarfan1 Offline
farrarfan1  Offline
Indiana
10W60 and a bottle or two of STP for the win.
Re: Amsoil and light weight oil [Re: Bullwinkle007] #4674358
02/22/18 01:15 PM
02/22/18 01:15 PM
Portland, Oregon
Joshua_Skinner Offline
Portland, Oregon
The thread title shows a lack of understanding of the issue.
2015 Nissan Frontier S King Cab, 2.5L, 5MT
Pennzoil Platinum 5W-30 in the crankcase. Red Line in the gearboxes.
Re: Amsoil and light weight oil [Re: farrarfan1] #4674360
02/22/18 01:16 PM
02/22/18 01:16 PM
New England
Virtus_Probi Offline
New England
Don't you mean Lucas instead of STP, being in Indiana and all????
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: Amsoil and light weight oil [Re: Virtus_Probi] #4674376
02/22/18 01:25 PM
02/22/18 01:25 PM
Indiana
farrarfan1 Offline
farrarfan1  Offline
Indiana
My bad.If Lucas is thicker than STP then it would be the better choice for an anti-CAFE blend.
