Mouse Visiting Car
by Ifixyawata
06/20/18 10:07 AM
Hit a shopping cart at 30mph
by LeakySeals
06/20/18 10:00 AM
Let's Talk Bed Pillows
by LoneRanger
06/20/18 09:21 AM
Changed Speedo Gear on 700r4 Tailshaft
by Pike51
06/20/18 09:20 AM
Which do you prefer: ZL-1 Camaro or GS Corvette ?
by Mr Nice
06/20/18 08:41 AM
CVT Discussion
by Sierra048
06/20/18 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Need mini grease gun
by Duffyjr
06/20/18 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
06/20/18 06:57 AM
Brake Bleeder
by supton
06/20/18 06:56 AM
As close to blowing out as you can get
by wwillson
06/20/18 06:04 AM
changing tranny filter
by Dennisistheman
06/20/18 06:04 AM
From small things...
by Silk
06/20/18 05:57 AM
Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Pennzoil Platinum at Walmart
by TheLawnRanger
06/19/18 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
06/19/18 10:45 PM
Whatís the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
92 registered (Aero540T, 853okg, 28oz, 9050lx, 2015_PSD, 2009Edge, 7 invisible), 1483 Guests and 27 Spiders online.
65276 Members
67 Forums
285642 Topics
Page 1 of 2 1 2 >
#4673900 - 02/21/18 09:42 PM STIHL Hp ultra fail??? Or my fault???
Matt2stroke Offline
Loc: Australia
Bought a brand new 2 stroke mower never been used. (Victa 2 stroke power torque) it says to use 25:1 or 50:1 using there victa formula semi synthetic oil (Valvoline made). I couldnít find any on shelf so I bought the STIHL go ultra and mixed it at 50:1. Iíve used the mower for 20hr and I thought Iíd have a look see on the exhaust port side of the cyclinder. Well I donít know if itís already scoring or if it was because I didnít run it in and itís just from the initial startup lubing from new. ( I got told I didnít have to run it in with fully synthetic at 25:1 just to stick to 50:1). It looks like 2-6 scratches on the cyclinder... I was wondering if itís because not enough or if I should just run STIHL ho ultra at 25:1 or even 32:1.. any input would help cheers Iíll link HD photos below..
#4673901 - 02/21/18 09:43 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Matt2stroke]
Matt2stroke Offline
Loc: Australia
Edited by Matt2stroke (02/21/18 09:44 PM)
#4673904 - 02/21/18 09:46 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Matt2stroke]
Crispysea Offline
Loc: TN USA
I wouldnít worry too much about it. You could run it at 40:1 or 32:1 if youíre really worried about wear. I think 25:1 is overkill.
#4673910 - 02/21/18 10:03 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Matt2stroke]
jhellwig Offline
Loc: Ottumwa, Iowa
That isn't scored. The scratches are from carbon in that goofy shaped port. What do the rings look like?
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2008 Chevy Suburban 5.3
1983 Chevy K5 350
#4673915 - 02/21/18 10:09 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Matt2stroke]
Buzzsaw Offline
Loc: Ga
Stihl Ultra is only JASO FB. I'd run a FD rated oil at 32:1 to 25:1 if it were me. Your mower should be okay.
#4673922 - 02/21/18 10:21 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Matt2stroke]
BrocLuno Offline
Loc: Kalifornia Kollective
I run all my 2-stroke power equipment at 40:1, or slightly richer. I use a 50:50 mixture of Motul 710 and Pennzoil TWC3. Have been doing this for close to 20 years. Most of my piston skirts will show an odd scratch here or there, but the engines run up to 10 years before re-ring.
I just tore down a Red-Max blower to re-ring. It was 20 years old run weekly for at least 2 hours w/o previous internal service. Looked fine with slight carbon cap. Cleaned right up.
Only motor I have lost in the last 30 years was one Homelite 46cc saw engine. A modern one with a CAT in the exhaust. I blame the CAT for too much heat retention. Have never seized a hot saw or a race saw on my mix. Others running much more expensive lubes have...
I have ancient outboards and Weedeaters, inexpensive Ryobi's, and expensive built Husqvarna's. They all get the same mixture. Set the timing right and the mixture, and keep a good air filter on it smile
2-strokes never die from too much oil. They will die from too little. But way more important is the mixture control. Slightly rich will live 100 years. Slightly lean will die in an hour ...
#4673928 - 02/21/18 10:29 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Matt2stroke]
eyeofthetiger Offline
Loc: South Carolina
I don't see the problem in the picture. It's good to run a bit more oil when breaking in a new engine, but I still run my old chainsaw and weed wacker around 25:1.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
#4673942 - 02/21/18 10:43 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Matt2stroke]
KneeGrinder Offline
Loc: North of you Idaho
"It looks like 2-6 scratches on the cyclinder..."
We are looking at the piston are we? I sure hope that's not your cylinder!
50:1 is proper ratio for Stihl Ultra. I use a lot of it. It is a good mix for a chain saw that pulls 14k rpm's, I doubt your mower pulls that kind of rpm, so your exhaust port looks very oil fouled for 20 hours run time. Your picture is shifted 90 degree's? And your exhaust port looks different on the right side which I believe is the floor of the port, just part of the design I guess.
The Scuff could very well be debris sucked in thru the air filter side, but it sure looks like you have enough lubrication in your fuel. Another possibility is not letting the engine warm completely before using, that can cause scuffing on 2 strokes.
08 Tribeca 82k PUP 5w30 wix
06 Accord Hybrid 131k PUP 5w20 wix
02 Chevy k3500 97k Delvac 1 esp 5w40 wix
00 F350 133k Delvac 1300 15w40 wix
#4673946 - 02/21/18 10:50 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Matt2stroke]
Linctex Offline
Loc: Waco, TX
Light scratches.... definitely NOT scored.
Properly machined modern 2-strokes can all handle 50:1 without any issues.
#4673961 - 02/21/18 11:09 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Buzzsaw]
Matt2stroke Offline
Loc: Australia
Yeah I asked the guy at STIHL and he said STIHL didnít pay for the FD rating like they did with the STIHL Hp super because for how many people pay premium for the ultra wasnít worth it. There super is FD rated. ( not %100 sold on the truth of the matter) but it would make sense ultra would be better than super.
#4673962 - 02/21/18 11:12 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Matt2stroke]
Matt2stroke Offline
Loc: Australia
Photos of rings and upper cyclinder below
#4673967 - 02/21/18 11:14 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Matt2stroke]
Matt2stroke Offline
Loc: Australia
#4673968 - 02/21/18 11:15 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: KneeGrinder]
Matt2stroke Offline
Loc: Australia
Oh yeah sorry the piston
#4673976 - 02/21/18 11:31 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Matt2stroke]
Panzerman Offline
Loc: Port Orange, Florida
New cylinders come with scratches. You even scratch them when you rebuild.
Nothing to worry about.
But richer is better than less oil. My last weed whacker, A Sears Craftsman was 25 years old. It didn't die just got hard to start. My wife bought me a new Echo but I ran 32:1 in it it's whole life and I run 32:1 in the echo too even though it says 50:1. Runs fine.
Edited by Panzerman (02/21/18 11:31 PM)
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
#4673987 - 02/21/18 11:54 PM Re: STIHL Hp ultra fail??? Or my fault??? [Re: Panzerman]
Matt2stroke Offline
Loc: Australia
Yeah I might do what others say and go 40:1,32:1 just to be safe. I know STIHL ultra is good itís in my STIHL whippersnipper/weed whacker
Page 1 of 2 1 2 >
