I just evicted some snowflakes from my class c/d rental. The carpet was brand new when they moved in 6 months ago. Apparently, the snowflakes were angry at being evicted for not paying rent so they trashed the carpet. Due to this stupid act, they lost the entire two month security deposit. I am trying to think of a cheap, indestructible flooring that can be easily and cheaply renewed every turnover. The existing plywood subfloor is rough, wavy, and has a lot of gaps, so the usual trick of painting the subfloor will probably not work. I thought of screwing down sheets of thin OSB with the smoothest side up and painting them satin brown. Smooth, cheap to install, and easy to refresh if scratched or gouged by rolling on a new coat of cheap paint.
what do you folks think?
Thanks in advance for any advice
