Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
33 registered members (das_peikko, carlprop, alcyon, clinebarger, csandste, Ag76), 717 guests, and 67 spiders.
Topics286,441
Posts4,908,218
Members67,622
Most Online2,967
Mar 10th, 2019
Abuse proof rental home flooring #4673811
02/21/18 09:17 PM
02/21/18 09:17 PM
Ceciltucky Maryland
Oldtom Offline OP
Oldtom  Offline OP
Ceciltucky Maryland
I just evicted some snowflakes from my class c/d rental. The carpet was brand new when they moved in 6 months ago. Apparently, the snowflakes were angry at being evicted for not paying rent so they trashed the carpet. Due to this stupid act, they lost the entire two month security deposit. I am trying to think of a cheap, indestructible flooring that can be easily and cheaply renewed every turnover. The existing plywood subfloor is rough, wavy, and has a lot of gaps, so the usual trick of painting the subfloor will probably not work. I thought of screwing down sheets of thin OSB with the smoothest side up and painting them satin brown. Smooth, cheap to install, and easy to refresh if scratched or gouged by rolling on a new coat of cheap paint.
what do you folks think?
Thanks in advance for any advice :-)
Re: Abuse proof rental home flooring [Re: Oldtom] #4673816
02/21/18 09:20 PM
02/21/18 09:20 PM
lllinois
salesrep Offline
salesrep  Offline
lllinois
I like your thoughts. ....cheap wood or vinyl is another thought
High quality Specialized Lubricants pay for themselves!
Re: Abuse proof rental home flooring [Re: Oldtom] #4673823
02/21/18 09:27 PM
02/21/18 09:27 PM
Central NY
rsylvstr Offline
rsylvstr  Offline
Central NY
I would get vinyl or vinyl or carpet 12x12 so you can replace the damaged parts.
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: Abuse proof rental home flooring [Re: Oldtom] #4673825
02/21/18 09:29 PM
02/21/18 09:29 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
A cheap laminate might be the way to go.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Abuse proof rental home flooring [Re: Oldtom] #4673835
02/21/18 09:34 PM
02/21/18 09:34 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
I would think that any decent tenant will see this painted osb floor and look elsewhere leaving you with only scumbags who don't plan on paying their rent anyway.
I understand that the low end rental business is tough but you can't cut every corner. How about cheap carpet in the rooms and some vinyl click plank flooring in the high traffic areas?
Re: Abuse proof rental home flooring [Re: Oldtom] #4673837
02/21/18 09:36 PM
02/21/18 09:36 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
That's why you have damage deposits. I also had a rider on my rentals insurance that covered me for renter vandalism and it also covered my loss of rent due to vandalism. I learned this early on from a friend who had rentals. They destroyed his carpet and flooring and they epoxied all the windows doors and cabinets closed.
Beyond that if you aren't doing a renter check that includes renter history, credit check and criminal wants and warrants you've been getting by on luck and borrowed time. It will catch up with you sooner or later.
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Abuse proof rental home flooring [Re: Oldtom] #4673851
02/21/18 09:50 PM
02/21/18 09:50 PM
workbench CZ-USA KS KC
Marco620 Offline
Marco620  Offline
Kevlar everything lol
15' Civic 1.8 i-vtec 222,222+ mi Redline oil/cvt fluid & Archoil9100
Just say no to drugs, union made cars and amsoil.
Son of a Navy Corpsman. Support vets!
Re: Abuse proof rental home flooring [Re: Oldtom] #4673858
02/21/18 09:55 PM
02/21/18 09:55 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Cheap vinyl laminate is pretty easy to come by...
I've seen it as low as $0.25 a square foot on clearance
Re: Abuse proof rental home flooring [Re: Oldtom] #4673861
02/21/18 09:57 PM
02/21/18 09:57 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
I've been putting down this Allure flooring lately. Started doing it a few years ago and it hasn't been trashed yet although I'm sure it's only a matter of time. A bit more durable that old stick on vinyl tile. I never put in carpet, either hardwood floor or this vinyl flooring.
https://www.homedepot.com/p/TrafficMASTE...110-0/202075782
Re: Abuse proof rental home flooring [Re: Wolf359] #4673865
02/21/18 10:04 PM
02/21/18 10:04 PM
Cincinnati
donnyj08 Offline
donnyj08  Offline
Cincinnati
This. My Dad owns several rental properties and he puts this in all of them. Some of his are section 8 and have been holding up really well with this flooring. Its also easy to install.
He generally uses the ones that look like wood planks, but the squares work well also for a "tile look"
2008 Silverado Z71 LT 90k Maxlife FS 5w30
2010 Ford Escape 172k QSUD 5w20
2016 Yamaha XSR900 12k, Rotella 15w40 Yamaha Filter.
Re: Abuse proof rental home flooring [Re: Oldtom] #4673872
02/21/18 10:12 PM
02/21/18 10:12 PM
Washington for now
WhyMe Offline
WhyMe  Offline
Washington for now
i have a few rentals and put cheap laminate in all of them. holds up well to people who don't care.
Re: Abuse proof rental home flooring [Re: Oldtom] #4673876
02/21/18 10:16 PM
02/21/18 10:16 PM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
Mine:
13 Ford C-MAX hybrid: MC 5w20, & FL910s (in theory)
Re: Abuse proof rental home flooring [Re: Oldtom] #4673885
02/21/18 10:25 PM
02/21/18 10:25 PM
WI.
dblshock Offline
dblshock  Offline
WI.
original laminate swells then peaks with moisture and the proper cleaner is $12 per qt. that's the problem. The new vinyl plank click flooring solves that but it's more money and all of these 'floating' floors require flat subfloors. Your sub floors were probably ruined by the steam extraction carpet cleaner bozo who went nuts with the water.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Abuse proof rental home flooring [Re: Oldtom] #4673903
02/21/18 10:45 PM
02/21/18 10:45 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
If your subfloor is trashed, there are no quick fixes that are not going to be completely obvious hack jobs. Just replace the subfloor, all you need is a killsaw, nails and subfloor adhesive. Toss some laminated vinyl plank on there and be done with it. They make waterproof varieties.
Brand new floors means increase in rent right?
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Abuse proof rental home flooring [Re: Oldtom] #4673920
02/21/18 11:20 PM
02/21/18 11:20 PM
South Carolina
eyeofthetiger Offline
South Carolina
Pour some self leveler down, and just leave it like that.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
