Blotter Spot Test
Venezuela, South America
Is the fact that the center of the spot is clearer than the medium ring a good or a bad thing?
Both spots were taken at the same time, I wanted to compare 2 drops vs 1 drop.
288k miles 7AFE Corolla
2500 miles on Oil with 2 qts of Makeup
Originally Posted By: Linctex
How did you make out on your engine repair?
Was the head gasket the only item needed?
The head gasket was burnt between cylinders 1 and 2, my 100k miles timing belt had cracks so we bought a timing kit and replaced the camshaft seal and front crankshaft seal.
The coolant consumption is gone. Now I wanna see if oil consumption lowers because of the new seals.
Clear and whitish center spot is a good thing as it indicates low levels of contaminants,
BUT observance/presence of medium ring (of about 8 mm annulus) is a 'bad' thing as it indicates commencement of dispersancy failure.
What's the oil spec in question ?
4 qts of Motorcraft 15w40 CJ4 with 2 qts of Makeup Oil of Venezuelan 15w40 CI4
