Originally Posted By: MParr
Could be an older model Mann. The newer Mann W7015 for the Escape is exactly the same as a Motorcraft 910s, down to the white can paint, red silicone ADBV and base end bypass. Or should I say North American model of the Mann is exactly the same as the 910s?
that's b/c Purolator makes 'em both.(as long as the Mann filter says Made in the USA that is...)most likely on the same line..
